Taiwan Chinsan Electronic Ind., Co., Ltd.
Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan
http://www.chinsan.com/products/
TEL: +886 2 2995 0535
PG
Series
Smaller size with higher ripple current
Load life 7,000 hours at 105℃
SPECIFICATIONS
Performance Characteristics
Item
Category Temperature Range
-25 ~ +105℃
Working Voltage Range
200 ~ 500Vdc
Capacitance Range
56 ~ 1,800μF
Capacitance Tolerance
±20% (at 25℃ and 120Hz)
Dissipation Factor
(tanδ)
(at 25℃, 120Hz)
Rated Voltage (V)
200
220
250
400
420
450
500
tanδ(Max)
0.20
0.20
0.20
0.25
0.25
0.25
0.25
I=0.02CV or 3000μA,whichever is smaller
I : Leakage current (μA) C : Rated capacitance (μF)
Impress the rated voltage for 5 minutes
Leakage Current
Low Temperature Characteristics
Impedance Ratio(MAX)
Rated voltage (V)
200 ~250
400
420~ 450
500
Z(-25℃)/Z(+20℃)
4
4
8
8
Dissipation factor(tanδ)
≦ 200% of the specified value
Leakage current
≦ specified value
The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000
hours at 105℃ without voltage applied.
≦ ±20% of the initial value
Capacitance change
Shelf Life
Leakage current
Others
Conforms to JIS-C-5101-4 (1998), characteristic W
DIMENSIONS (mm)
Terminal Code : ND : Standard
Terminal Code :K6 (ø35)
D+1 Max
6
2- 2
L±2 Max
4.0±0.5
b o a r d
6
B
Safety vent
G
.5
±0
10
P C
S l e e v e
A
p i n - o u t
2 2 . 5
PC board Pin-out
M a x
Negative mark
D + 1
Sleeve
P
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage
with the rated ripple current is applied for 7,000 hours at 105°C.
Capacitance change
Endurance
V : Rated voltage (V)
C
V e n t
L±2
M a x
6 ±
. 13 . 0
T e r m i n a l
T e r m i n a l
PART NUMBER SYSTEM( Example : 450V 470µF )
2 W 4 7 1 M N D 3 5 5 0
Special Request
Size code(3550 : 35×50)
Terminal length code
Lead forming Type code
Capacitance tolerance code(M:±20%)
Capacitance code (470μF)
Voltage code (450V)
Series code (PG)
4 -
2
B = p o s i t i v e
A & C = b l a n k
Aluminum Electrolytic Capacitor
Customer
Digi-Key
SERIES
PG
NO.:
FIG-1
FIG-2
Tolerance
No.
CHINSAN
Part No.
Customer Capacitance
Part No.
(uF)
2022-03-25
PUBLISH DATE
On rated
Working
Capacitance Voltage
(Vdc)
Surge
Voltage
(Vdc)
Rated
Rated
Category
Tanδ
Leakage
Ripple
Ripple
ESR
Impedance
Temp
@ 25℃
Current
Current
Current
@25℃
@20℃
Range
(120Hz)
(uA)
(Max)
(mA rms) (mA rms) (mΩ max/ (mΩ max/
(2 min.) @ 105℃ @105℃
120Hz
100kHz
120Hz)
100kHz)
Dimensions (mm)
Endurance
@ 105℃
(Hours)
Appearance
D
Φ
Drawing
L
a
d
F
No
1
PG2S271MND2545Y
270 µF
±20%
420 V
-25~+105
1270
5000
25 45
10
FIG-1
2
PG2D471MNN2535
470 µF
±20%
200 V
-25~+105
1320
2000
25 35
10
FIG-2
3
PG2G681MNN3550E
680 µF
±20%
400 V
-25~+105
2000
280
5000
35 50
10
FIG-2
4
PG2G221MNN2541
220 µF
±20%
400 V
-25~+105
1000
5000
25 41
10
FIG-2
5
PG2S331MND2545Y
330 µF
±20%
420 V
-25~+105
1470
5000
25 45
10
FIG-1
※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test.
REMARKS:
APPROVED BY
CHECKED BY
PREPARED BY
张洪斌
曾爱娥
梁慧妍
Sleeve Color: Black.
Suffix Y represents assembly without gasket.
Customer
Digi-Key
SERIES
Tolerance
No.
CHINSAN
Part No.
Part No.
(uF)
On rated
Capacitance Voltage
1
PG2E391MW42532A
390 µF
Working
±20%
(Vdc)
250 V
Surge
Voltage
(Vdc)
PG
NO.:
Rated
Rated
Category
Tanδ
Leakage
Ripple
Ripple
ESR
Impedance
Temp
@ 25℃
Current
Current
Current
@25℃
@20℃
Range
(120Hz)
(uA)
(Max)
-40~+105
2022-03-25
PUBLISH DATE
120Hz
100kHz
1850
120Hz)
100kHz)
Dimensions (mm)
Endurance
@ 105℃
(Hours)
5000
Appearance
D
Φ
Drawing
L
a
d
F
No
25 32
10
REMARKS:
APPROVED BY
CHECKED BY
PREPARED BY
张洪斌
曾爱娥
梁慧妍
很抱歉,暂时无法提供与“PG2W331MND3040”相匹配的价格&库存,您可以联系我们找货
