PG2W391MND3040R
PG2W391MND3040R
    CHINSAN(金山)
    插件
    390 µF 450 V 铝电解电容器 径向,Can - 卡入式 105°C 时为 5000 小时
PG2W391MND3040R 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 PG Series  Smaller size with higher ripple current  Load life 7,000 hours at 105℃  SPECIFICATIONS Performance Characteristics Item Category Temperature Range -25 ~ +105℃ Working Voltage Range 200 ~ 500Vdc Capacitance Range 56 ~ 1,800μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Rated Voltage (V) 200 220 250 400 420 450 500 tanδ(Max) 0.20 0.20 0.20 0.25 0.25 0.25 0.25 I=0.02CV or 3000μA,whichever is smaller I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 5 minutes Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Rated voltage (V) 200 ~250 400 420~ 450 500 Z(-25℃)/Z(+20℃) 4 4 8 8 Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 105℃ without voltage applied. ≦ ±20% of the initial value Capacitance change Shelf Life Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Others Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) Terminal Code : ND : Standard Terminal Code :K6 (ø35) D+1 Max 6 2- 2 L±2 Max 4.0±0.5 0 b o a r d ° 6 0 B * - Safety vent G .5 ±0 10 + P C S l e e v e A * p i n - o u t ° 2 2 . 5 PC board Pin-out M a x Negative mark D + 1 Sleeve  P (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 7,000 hours at 105°C. ≦ ±20% of the initial value Capacitance change Endurance  V : Rated voltage (V) C - V e n t L±2 M a x 6 ± . 13 . 0 T e r m i n a l T e r m i n a l PART NUMBER SYSTEM( Example : 450V 470µF ) 2 W 4 7 1 M N D 3 5 5 0 Special Request Size code(3550 : 35×50) Terminal length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (470μF) Voltage code (450V) Series code (PG) 4 - 2 B = p o s i t i v e A & C = b l a n k Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PG NO.: FIG-1 FIG-2 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance @ 105℃ (Hours) Appearance D Φ Drawing L a d F No 1 PG2S271MND2545Y / 270 µF ±20% 420 V / -25~+105 / / 1270 / / / 5000 25 45 / / 10 FIG-1 2 PG2D471MNN2535 / 470 µF ±20% 200 V / -25~+105 / / 1320 / / / 2000 25 35 / / 10 FIG-2 3 PG2G681MNN3550E / 680 µF ±20% 400 V / -25~+105 / / 2000 / 280 / 5000 35 50 / / 10 FIG-2 4 PG2G221MNN2541 / 220 µF ±20% 400 V / -25~+105 / / 1000 / / / 5000 25 41 / / 10 FIG-2 5 PG2S331MND2545Y / 330 µF ±20% 420 V / -25~+105 / / 1470 / / / 5000 25 45 / / 10 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Suffix Y represents assembly without gasket. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Capacitance Voltage (%) 1 PG2E391MW42532A / 390 µF Working ±20% (Vdc) 250 V Surge Voltage (Vdc) / PG NO.: Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) -40~+105 / (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ / 2022-03-25 PUBLISH DATE 120Hz 100kHz 1850 / 120Hz) 100kHz) / / Dimensions (mm) Endurance @ 105℃ (Hours) 5000 Appearance D Φ Drawing L a d F No 25 32 / / 10 --- ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black.
PG2W391MND3040R 价格&库存
很抱歉,暂时无法提供与“PG2W391MND3040R”相匹配的价格&库存,您可以联系我们找货
