PK1K332MND3035
PK1K332MND3035
    CHINSAN(金山)
    插件
    3300 µF 80 V 铝电解电容器 径向,Can - 卡入式 105°C 时为 3000 小时
PK1K332MND3035 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 PK Series  Long life and high temperature, down size and high ripple current  Load life 3,000 hours at 105℃  SPECIFICATIONS Performance Characteristics Item Category Temperature Range Working Voltage Range -25 ~ +105℃ 200 ~ 500Vdc Capacitance Range 56 ~ 2,200μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Rated Voltage (V) 200 220 250 350 400 420 450 500 tanδ(Max) 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.20 The above values should be increased by 0.02 for every additional 1000μF I=0.02CV or 3000μA,whichever is smaller I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 5 minutes Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Rated voltage (V) 200~250 350 400 420 ~ 450 500 Z(-25℃)/Z(+20℃) 4 4 4 8 8 Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 105℃ without voltage applied. ≦ ±20% of the initial value Capacitance change Shelf Life Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Others Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) Terminal Code : ND : Standard Terminal Code :K6 (ø35) D+1 Max .5 ±0 10 + P C S l e e v e 6 2- 2 L±2 Max 4.0±0.5 b o a r d ° 6 0 B * - Safety vent 0 A * p i n - o u t ° 2 2 . 5 PC board Pin-out M a x Negative mark D + 1 Sleeve  P (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 3,000 hours at 105°C ≦ ±20% of the initial value Capacitance change Endurance  V : Rated voltage (V) C - V e n t L±2 M a x 6 ± . 13 . 0 PART NUMBER SYSTEM( Example : 420V 470µF ) K 2 S 4 7 1 M N D 3 5 4 5 Special Request Size code(3545 : 35×45) Terminal length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (470μF) Voltage code (420V) Series code (PK) T e r m i n a l T e r m i n a l 4 - 2 B = p o s i t i v e A & C = b l a n k Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Capacitance Voltage (%) 1 PK2G121MW42230RY / 120 µF Working ±20% (Vdc) 400 V Surge Voltage (Vdc) / PK NO.: Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) -25~+105 / (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ / 2022-03-25 PUBLISH DATE 120Hz 100kHz 770 / 120Hz) 100kHz) / / Dimensions (mm) Endurance @ 105℃ Appearance Drawing (Hours) D Φ L a d F No 3000 22 30 / / 10 --- ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Suffix Y represents assembly without gasket. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PK NO.: FIG-2 FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance @ 105℃ (Hours) Appearance D Φ Drawing L a d F No 1 PK2W221MND2535E / 220 µF ±20% 450 V / -25~+105 / / 1520 / 1210 / 3000 25 35 / / 10 FIG-1 2 PK2S221MND2545 / 220 µF ±20% 420 V / -25~+105 / / 1200 / / / 3000 25 45 / / 10 FIG-2 3 PK2D152MND3540 / 1500 µF ±20% 200 V / -25~+105 / / 3340 / / / 3000 35 40 / / 10 FIG-1 4 PK2D471MND2530 / 470 µF ±20% 200 V / -25~+105 / / 1500 / / / 3000 25 30 / / 10 FIG-1 5 PK2F471MND2551 / 470 µF ±20% 315 V / -25~+105 / / 2000 / / / 3000 25 51 / / 10 FIG-1 6 PK2G101MND2230 / 100 µF ±20% 400 V / -25~+105 / / 700 / / / 3000 22 30 / / 10 FIG-1 7 PK2W121MND2230 / 120 µF ±20% 450 V / -25~+105 / / 720 / / / 3000 22 30 / / 10 FIG-1 8 PK2W101MND2230RY / 100 µF ±20% 450 V / -25~+105 / / 1300 / / / 3000 22 30 / / 10 FIG-2 9 PK2W680MND2225R / 68 µF ±20% 450 V / -25~+105 / / 600 / / 2230 3000 22 25 / / 10 FIG-1 10 PK2E471MND2535 / 470 µF ±20% 250 V / -25~+105 / / 1650 / 430 / 3000 25 35 / / 10 FIG-1 11 PK2E102MND3040R / 1000 µF ±20% 250 V / -40~+105 / / 3060 / / 156 3000 30 40 / / 10 FIG-1 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ 12 PK2W121MND2230R / 120 µF ±20% 450 V / -25~+105 / / 820 / / / 3000 22 30 / / 10 FIG-1 13 PK2D102MND3035 / 1000 µF ±20% 200 V / -25~+105 / / 1975 / / / 3000 30 35 / / 10 FIG-1 14 PK2W561MND3045Y / 560 µF ±20% 450 V / -25~+105 / / 2240 / 420 290 3000 30 45 / / 10 FIG-2 15 PK2W331MND2545RY / 330 µF ±20% 450 V / -25~+105 / / 1700 / / 460 3000 25 45 / / 10 FIG-2 16 PK2G221MND3025 / 220 µF ±20% 400 V / -25~+105 / / 1100 / / / 3000 30 25 / / 10 FIG-1 17 PK2W331MND3040ER / 330 µF ±20% 450 V / -25~+105 / / 1600 / 250 / 3000 30 40 / / 10 FIG-1 18 PK2H101MND2230Y / 100 µF ±20% 500 V / -25~+105 / / 650 / / / 3000 22 30 / / 10 FIG-2 19 PK2F681MND3050 / 680 µF ±20% 315 V / -25~+105 / / 2170 / / / 3000 30 50 / / 10 FIG-1 20 PK2H680MND2225RY / 68 µF ±20% 500 V / -25~+105 / / 600 / / / 3000 22 25 / / 10 FIG-2 21 PK2W391MND2553 / 390 µF ±20% 450 V / -25~+105 / / 2300 / 480 / 3000 25 53 / / 10 FIG-1 22 PK2W681MND3050RY / 680 µF ±20% 450 V / -25~+105 / / 2500 / / 400 3000 30 50 / / 10 FIG-2 23 PK2W221MND3030R / 220 µF ±20% 450 V / -25~+105 / / 1360 / 900 550 3000 30 30 / / 10 FIG-1 24 PK2E152MND3551RP / 1500 µF ±20% 250 V / -25~+105 / / 3000 / 160 / 3000 35 51 / / 10 FIG-1 25 PK2W151MND2530RY / 150 µF ±20% 450 V / -25~+105 / / 1100 / / / 3000 25 30 / / 10 FIG-2 26 PK2W151MND2235Y / 150 µF ±20% 450 V / -25~+105 / / 920 / 1770 / 3000 22 35 / / 10 FIG-2 27 PK1K332MND3035 / 3300 µF ±20% 80 V / -25~+105 / / 2780 / / / 3000 30 35 / / 10 FIG-1 28 PK2G471MND2550 / 470 µF ±20% 400 V / -25~+105 / / 1450 / / / 3000 25 50 / / 10 FIG-1 29 PK2S271MND2540Y / 270 µF ±20% 420 V / -40~+105 / / 1250 / / / 3000 25 40 / / 10 FIG-2 30 PK2W181MND2245 / 180 µF ±20% 450 V / -25~+105 / / 850 / / / 3000 22 45 / / 10 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: Sleeve Color: Black. Suffix Y represents assembly without gasket. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍
PK1K332MND3035 价格&库存
很抱歉,暂时无法提供与“PK1K332MND3035”相匹配的价格&库存,您可以联系我们找货
