PO2H271MND3035Y
PO2H271MND3035Y
    CHINSAN(金山)
    插件
    270 µF 500 V 铝电解电容器 径向,Can - 卡入式 840 毫欧 @ 120Hz 105°C 时为 2000 小时
PO2H271MND3035Y 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 PO http://www.chinsan.com/products/ Series  Endurance with ripple current: 2,000 hours at 105℃  SPECIFICATIONS Performance Characteristics Item Category Temperature Range -25 ~ +105℃ 400 ~ 450Vdc Working Voltage Range Capacitance Range 68 ~ 680μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Rated Voltage (V) 400 420 450 tanδ(Max) 0.15 0.20 0.20 I≤3 CV I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 5 minutes Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Rated voltage (V) 400 420 ~ 450 Z(-25℃)/Z(+20℃) 4 8 V : Rated voltage (V) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 2,000 hours at 105°C. Endurance Capacitance change ≦ ±20% of the initial value Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦The initial specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 105℃ without voltage applied. ≦ ±15% of the initial value Capacitance change Shelf Life Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦The initial specified value Others  Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) Terminal Code : ND : Standard Sleeve Terminal Code :K6 (ø35) Negative mark PC board pin-out Sleeve PC board Pin-out 60° 2- 2 L±2 M a x O 4.0±0.5 60° * A * 22.5 B D+1 Max D+1 Max - Safety vent  P .5 ±0 10 + C - Vent L±2 Max 6.3±1.0 PART NUMBER SYSTEM( Example : 420V 680µF ) 2 S 6 8 1 M N D 3 5 5 5 Special Request Size code(3555 : 35×55) Terminal length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (680μF) Voltage code (420V) Series code (PO) Terminal B=positive Terminal A&C=blank 4- 2 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PO NO.: FIG-2 FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance @ 105℃ Appearance Drawing (Hours) D Φ L a d F No 1 PO2H271MND3035Y / 270 µF ±20% 500 V / -25~+105 / / 1350 / 840 / 2000 30 35 / / 10 FIG-1 2 PO2G101MNN2225R / 100 µF ±20% 400 V / -25~+105 / / 1050 / / / 2000 22 25 / / 10 FIG-2 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Suffix Y represents assembly without gasket.
PO2H271MND3035Y 价格&库存
很抱歉,暂时无法提供与“PO2H271MND3035Y”相匹配的价格&库存,您可以联系我们找货
