PV2W121MNN1640
PV2W121MNN1640
    CHINSAN(金山)
    插件
    120 µF 450 V 铝电解电容器 径向,Can 105°C 时为 5000 小时
PV2W121MNN1640 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 PV    Series Downsize and high ripple current Load life 2,000 ~ 5,000 hours at 105℃ SPECIFICATIONS Performance Characteristics Item Category Temperature Range -25 ~ +105℃ Working Voltage Range 160 ~ 500Vdc Capacitance Range 33 ~ 560 μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Rated Voltage (V) 160 200 250 400 420 450 500 tanδ(Max) 0.20 0.20 0.20 0.20 0.20 0.20 0.24 The above values should be increased by 0.02 for every additional 1000μF I=0.02CV or 3000μA whichever is smaller I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 2 minutes V : Rated voltage (V) Rated voltage (V) 160~250 400 420 ~ 450 500 Z(-25℃)/Z(+20℃) 3 5 6 6 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 2,000 ~5,000 hours at 105°C Endurance Capacitance change Dissipation factor(tanδ) ≦ ±20% of the initial value Leakage current ≦ specified value Size ФD≦12.5Ф ФD≧ 16 Ф ≦ 200% of the specified value Life time (hours) 2,000 5,000 The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Shelf Life Capacitance change ≦ ±20% of the initial value Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current Others  ≦ 200% of the specified value Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD 10 ФD V 16 18 Фd 0.6 0.6 0.8 0.8 F 5.0 5.0 7.5 7.5 L + 1.5 Max ≤ 35 L+1.5Max ≥ 40 L+2.0 Max a  P 12.5 ФD +0.5 Max PART NUMBER SYSTEM( Example : 420V 68µF ) 2 S 6 8 0 M N N 1 6 4 0 Special Request Size code(1640 : 16×40) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (68μF) Voltage code (420V) Series code (PV) L + 1.5 Max Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PV NO.: FIG-1 FIG-2 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ 120Hz) 100kHz) Dimensions (mm) Endurance @ 105℃ (Hours) 120Hz 100kHz 1 PV2G330ML41225F8R / 33 µF ±20% 400 V / -25~+105 / / 310 / / / 8000 2 PV2W101MLT1640EZ / 100 µF ±20% 450 V / -25~+105 / / 800 1600 1700 / 5000 Appearance D Φ Drawing L a d F No 12.5 25 / / 5 FIG-1 / / 7.5 FIG-2 16 40 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Suffix F8 indicates the life of the capacitor is 8000 hrs. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PV NO.: FIG-1 FIG-2 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance @ 105℃ (Hours) Appearance D Φ Drawing L a d F No 1 PV2W121MRT1845R / 120 µF ±20% 450 V / -25~+105 / / 950 / / / 5000 18 45 / / 7.5 FIG-1 2 PV2G101MNN2030R / 100 µF ±20% 400 V / -25~+105 / / 800 / / 650 5000 20 30 / / 10 FIG-2 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PV NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=30.0±1.0 P0=15.0±0.2 P1=3.75±0.5 P2=7.5±1.0 F=7.5+0.8/-0.2 Original FIG-1 Tolerance No. 1 2 3 4 5 6 7 8 9 10 11 12 CHINSAN Part No. PV2C681MNN1850 PV2E330MNN1220 PV2F270MNN1620 PV2G121MNN1830S PV2W680MNN1825RA PV2W820MNN1835 PV2W151MNN1840R PV2W101MNN1635 PV2W121MNN1640 PV2H330MNN1820E PV2H470MNN1825 PV2H220MPI1625 Customer Capacitance Part No. / / / / / / / / / / / / (uF) 680 µF 33 µF 27 µF 120 µF 68 µF 82 µF 150 µF 100 µF 120 µF 33 µF 47 µF 22 µF H=18.5±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% 160 V 250 V 315 V 400 V 450 V 450 V 450 V 450 V 450 V 500 V 500 V 500 V Surge Voltage (Vdc) / / / / / / / / / / / / Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) -25~+105 -25~+105 -25~+105 -25~+105 -25~+105 -25~+105 -25~+105 -40~+105 -40~+105 -25~+105 -25~+105 -25~+105 / / / / / / / / / / / / (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ / / / / / / / / / / / / 120Hz 100kHz 1520 245 730 800 580 635 970 730 820 320 / 350 / / / / / / / / / / 1200 / 120Hz) 100kHz) / / / 2510 4440 / / / / 9100 / 10500 / / / 1510 2390 / / / / / / / Dimensions (mm) Endurance Appearance @ 105℃ (Hours) 5000 2000 5000 5000 5000 5000 5000 5000 5000 5000 5000 5000 Drawing DΦ L a d F No 18 12.5 16 18.5 18.5 18 18 16 16 18 18 16 / / / / / / / / / / / / / / / / / / / / / / / / 7.5 5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 Original Original Original Original Original Original Original Original Original Original Original FIG-1 50 20 20 30 25 35 40 35 40 20 25 25 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: Sleeve Color: Black. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍
PV2W121MNN1640 价格&库存
很抱歉,暂时无法提供与“PV2W121MNN1640”相匹配的价格&库存,您可以联系我们找货
