PW2E181MC51630
PW2E181MC51630
    CHINSAN(金山)
    插件
    180 µF 250 V 铝电解电容器 径向,Can 105°C 时为 2000 小时
PW2E181MC51630 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 PW    Series Downsize and high ripple version of PF series Load life 2,000 hours at 105℃ SPECIFICATIONS Performance Characteristics Item Category Temperature Range -25 ~ +105℃ Working Voltage Range 160 ~ 600Vdc Capacitance Range 10 ~ 470 μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Rated Voltage (V) 160 ~ 250 400 ~ 600 tanδ(Max) 0.15 0.20 The above values should be increased by 0.02 for every additional 1000μF Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) I=0.03CV + 10μA I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 2 minutes V : Rated voltage (V) Rated voltage (V) 160 ~ 250 400 420 450 475 500 550 600 Z(-25℃)/Z(+20℃) 3 5 6 6 6 6 6 6 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 2,000 hours at 105°C Endurance Capacitance change ≦ ±20% of the initial value Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 1,000 hours at 105℃ without voltage applied. Shelf Life Capacitance change ≦ ±20% of the initial value Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Others  Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD 12.5 ФD Фd 16 18 ФD + 0.5 Max 0.6 0.8 0.8 F 5.0 7.5 7.5 a ≤ 35 L+1.5Max ≥ 40 L+2.0 Max  PART NUMBER SYSTEM( Example : 500V 22µF ) P W 2 H 2 2 0 M N N 1 2 3 0 Special Request Size code(1230 : 12.5×30) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (22μF) Voltage code(500V) Series code(PW) L +1.5 Max Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PW NO.: FIG-1 FIG-2 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ 120Hz) 100kHz) Dimensions (mm) Endurance @ 105℃ Appearance Drawing (Hours) D Φ L a d F No 16 30 / / 7.5 FIG-1 12.5 12 / / 5 FIG-2 120Hz 100kHz 1 PW2E181MC51630 / 180 µF ±20% 250 V / -25~+105 / / 680 / / / 2000 2 PW2E220MCE1212F3 / 22 µF ±20% 250 V / -25~+105 / / / 600 / / 3000 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Suffix F3 indicates the life of the capacitor is 3000 hrs. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PW NO.: FIG-1 FIG-2 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ 120Hz) 100kHz) Dimensions (mm) Endurance @ 105℃ (Hours) Appearance D Φ Drawing L a d F No 18.5 45 / / 7.5 FIG-1 120Hz 100kHz 1 PW2W181MCM1845E / 180 µF ±20% 450 V / -40~+105 / / 860 / / 1100 2000 2 PW2W680MRT1636F3R / 68 µF ±20% 450 V / -25~+105 / / 600 / / / 3000 16 36 / / 7.5 FIG-2 3 PW2W680MRT1832 / 68 µF ±20% 450 V / -25~+105 / / 550 / / / 2000 18 32 / / 7.5 FIG-2 4 PW2W470MRT1625R / 47 µF ±20% 450 V / -25~+105 / / 350 / / / 2000 16 25 / / 7.5 FIG-2 5 PW2W101MRT1840F3R / 100 µF ±20% 450 V / -25~+105 / / 850 / / / 3000 18 40 / / 7.5 FIG-2 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Suffix F3 indicates the life of the capacitor is 3000 hrs. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PW NO.: FIG-1 FIG-2 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ 120Hz) 100kHz) Dimensions (mm) Endurance @ 105℃ Appearance Drawing (Hours) D Φ L a d F No 120Hz 100kHz 1 PW2W470MS31632 / 47 µF ±20% 450 V / -25~+105 / / 430 / 4000 3850 2000 16 32 / / 7.5 FIG-1 2 PW2W560MS31635 / 56 µF ±20% 450 V / -25~+105 / / 500 / / / 2000 16 35 / / 7.5 FIG-1 3 PW2D560MSD1020 / 56 µF ±20% 200 V / -25~+105 / / / 760 / / 2000 10 20 / / 5 FIG-2 4 PW2E330MSD1020 / 33 µF ±20% 250 V / -25~+105 / / / 375 / / 2000 10 20 / / 5 FIG-2 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PW NO.: FIG-1 FIG-2 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ 120Hz) 100kHz) Dimensions (mm) Endurance @ 105℃ Appearance Drawing (Hours) D Φ L a d F No 120Hz 100kHz 1 PW2W121MST1840 / 120 µF ±20% 450 V / -25~+105 / / 850 / 2510 / 2000 18 40 / / 7.5 FIG-1 2 PW2G101MU01632E / 100 µF ±20% 400 V / -25~+105 / / 550 / / 700 2000 16 32 / / 7.5 FIG-2 3 PW2H470MU01632 / 47 µF ±20% 500 V / -25~+105 / / 550 / / / 2000 16 32 / / 7.5 FIG-2 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PW NO.: FIG-1 FIG-2 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 120Hz 100kHz 1 PW2C680MNN1220 / 68 µF ±20% 160 V / -25~+105 / / 770 / / / 2000 12.5 20 / / 5 FIG-1 2 PW2P121MNN1236 / 120 µF ±20% 220 V / -25~+105 / / 750 / / / 2000 12.5 36 / / 5 FIG-1 3 PW2E221MNN1830 / 220 µF ±20% 250 V / -25~+105 / / 810 / / / 2000 18 30 / / 7.5 FIG-1 4 PW2G101MNN1630 / 100 µF ±20% 400 V / -25~+105 / / 530 / / / 2000 16 30 / / 7.5 FIG-1 5 PW2G330MNN1620 / 33 µF ±20% 400 V / -25~+105 / / 350 / / / 2000 16 20 / / 7.5 FIG-1 6 PW2G470MNN1230 / 47 µF ±20% 400 V / -25~+105 / / 300 / / / 2000 12.5 30 / / 5 FIG-1 7 PW2G680MNN1825 / 68 µF ±20% 400 V / -25~+105 / / 440 / / / 2000 18 25 / / 7.5 FIG-1 8 PW2G8R2MNN0816 / 8.2 µF ±20% 400 V / -25~+105 / / 80 / / / 2000 8 16 / / 3.5 FIG-1 9 PW2G470MNN1632 / 47 µF ±20% 400 V / -25~+105 / / 250 / / 2000 16 32 / / 7.5 FIG-1 10 PW2G820MNN1625EF3J / 82 µF ±20% 400 V / -25~+105 / / 650 / / 620 3000 16.5 25 / / 7.5 FIG-1 11 PW2S121MNN1830 / 120 µF ±20% 420 V / -25~+105 / / 600 / / / 2000 18.5 30 / / 7.5 FIG-1 12 PW2S151MNN1835 / 150 µF ±20% 420 V / -25~+105 / / 720 / / / 2000 / / 7.5 FIG-1 18 35 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ 13 PW2S181MNN1845P5 / 180 µF ±20% 420 V / -25~+105 / / 900 2000 / 500 2000 18 45 / / 7.5 FIG-1 14 PW2W101MNN1635A4 / 100 µF ±20% 450 V / -25~+105 / / 520 / / / 2000 16 35 / / 7.5 FIG-1 15 PW2W101MNN1830 / 100 µF ±20% 450 V / -25~+105 / / 580 / / / 2000 18 30 / / 7.5 FIG-1 16 PW2W121MNN1835 / 120 µF ±20% 450 V / -25~+105 / / 600 / / / 2000 18 35 / / 7.5 FIG-1 17 PW2W151MNN1840 / 150 µF ±20% 450 V / -25~+105 / / 1050 / / / 2000 18.5 40 / / 7.5 FIG-1 18 PW2W220MNN1625 / 22 µF ±20% 450 V / -25~+105 / / 250 / / / 2000 16 25 / / 7.5 FIG-1 19 PW2W330MNN1618 / 33 µF ±20% 450 V / -25~+105 / / 350 / / / 2000 16 18 / / 7.5 FIG-1 20 PW2W470MNN1236 / 47 µF ±20% 450 V / -25~+105 / / 420 / / / 2000 12.5 36 / / 5 FIG-1 21 PW2W470MNN1818 / 47 µF ±20% 450 V / -25~+105 / / 350 / / / 2000 18.5 18 / / 7.5 FIG-1 22 PW2W560MNN1240 / 56 µF ±20% 450 V / -25~+105 / / 500 / / / 2000 12.5 40 / / 5 FIG-1 23 PW2H101MNN1836A4ES / 100 µF ±20% 500 V / -25~+105 / / 600 / / 700 2000 18 36 / / 7.5 FIG-1 24 PW2H121MNN1845AEF3 / 120 µF ±20% 500 V / -25~+105 / / 900 / 600 / 3000 18 45 / / 7.5 FIG-1 25 PW2D330MVW1016F3R / 33 µF ±20% 200 V / -25~+105 / / / 650 / / 3000 10 16 / / 5 FIG-2 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: Sleeve Color: Black. Suffix F3 indicates the life of the capacitor is 3000 hrs. Suffix J indicates the limit of external diameter is 16.5+0.5mm(Max). Suffix P5 : indicates Back PET sleeve. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍
PW2E181MC51630 价格&库存
很抱歉,暂时无法提供与“PW2E181MC51630”相匹配的价格&库存,您可以联系我们找货
