PY1H4R7MP20511U
PY1H4R7MP20511U
    CHINSAN(金山)
    插件
    4.7 µF 50 V 铝电解电容器 径向,Can 12 欧姆 @ 120Hz 125°C 时为 2000 小时
PY1H4R7MP20511U 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 PY    Series High-temperature 125℃, High reliability Load life 2,000 hours at 125℃ SPECIFICATIONS Performance Characteristics Item Category Temperature Range -40 ~ +125℃ -25 ~ +125℃ Working Voltage Range 10 ~ 100Vdc 160 ~ 450Vdc Capacitance Range 4.7 ~ 1000 μF 4.7~ 150 μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Rated Voltage (V) 10 16 25 35 50 63 100 tanδ(Max) 0.20 0.16 0.14 0.12 0.10 0.10 0.09 The above values should be increased by 0.02 for every additional 1000μF Leakage Current I≦0.01CV or 2μA whichever is greater(10 ~ 100V) I≦0.03CV +10μA(160 ~ 450V) I : Leakage current (μA) C : Rated capacitance (μF) V : Rated voltage (V) Impress the rated voltage for 2 minutes Low Temperature Characteristics Impedance Ratio(MAX) Rated voltage (V) 10 16 25 35 50 63 100 Z(-40℃)/Z(+20℃) 6 — 4 — 4 — 4 — 4 — 4 — 4 — Z(-25℃)/Z(+20℃) 160 ~ 250 0.20 350 ~ 450 0.24 160 ~ 250 350 400 ~ 450 — — — 3 6 6 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 2,000 hours at 125°C Endurance Capacitance change ≦ ±25% of the initial value Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 1,000 hours at 125℃ without voltage applied. After test : UR to be applied for 30 minutes, 24 to 48 hours before measurement. Shelf Life Capacitance change ≦ ±25% of the initial value Dissipation factor(tanδ) Leakage current ≦ 200% of the specified value ≦ 200% of the specified value Others  Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD 6.3 8 10 ФD Y 16 Фd 0.5 0.6 0.6 0.6 0.8 F 2.5 3.5 5.0 5.0 ≤ 35 L+1.5Max ≥ 40 L+2.0 Max 7.5 a  P 12.5 ФD + 0.5 Max L + 1.5 Max PART NUMBER SYSTEM( Example : 10V 1000µF ) 1 A 1 0 2 M N N 1 0 2 0 Special Request Size code(1020 : 10×20) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (1000μF) Voltage code (10V) Series code (PY) L + 1.5 Max Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PY NO.: 2022-03-25 PUBLISH DATE Unit (mm): Original No. Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 W =18.0±0.5 F=2.5+0.8/-0.2 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 FIG-1 Tolerance CHINSAN P=12.7±1.0 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 125℃ @125℃ 120Hz) 100kHz) Dimensions (mm) Endurance @ 125℃ Appearance Drawing (Hours) D Φ L a d F No 120Hz 100kHz 1 PY1H4R7MP20511U / 4.7 µF ±20% 50 V / -40~+125 / / 80 160 12000 2200 2000 5 11 / / 2.5 FIG-1 2 PY1H100MP20511EU / 10 µF ±20% 50 V / -40~+125 / / / 300 / 650 2000 5 11 / / 2.5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Suffix U indicates convex rubber cover.
PY1H4R7MP20511U 价格&库存
很抱歉,暂时无法提供与“PY1H4R7MP20511U”相匹配的价格&库存,您可以联系我们找货
