Taiwan Chinsan Electronic Ind., Co., Ltd.
Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan
http://www.chinsan.com/products/
TEL: +886 2 2995 0535
PZ
Series
Rated voltage range: 200 to 450Vdc, Capacitance: 18 to 270μF
Load life 2,000 hours at 105℃
Ideal for low profile power supply applications
SPECIFICATIONS
Performance Characteristics
Item
Category Temperature Range
-40 ~ +105℃
-25 ~ +105℃
Working Voltage Range
200 ~ 400Vdc
420 ~ 450Vdc
Capacitance Range
27 ~ 270 μF
18 ~ 100 μF
Capacitance Tolerance
Dissipation Factor
(tanδ)
(at 25℃, 120Hz)
Leakage Current
Low Temperature Characteristics
Impedance Ratio(MAX)
±20% (at 25℃ and 120Hz)
Rated Voltage (V)
200
400
420
450
tanδ(Max)
0.12
0.15
0.20
0.20
I=0.03CV + 10μA
I : Leakage current (μA) C : Rated capacitance (μF)
Impress the rated voltage for 2 minutes
V : Rated voltage (V)
Rated voltage (V)
200
400
420 ~ 450
Z(-40℃)/Z(+20℃)
6
6
Z(-25℃)/Z(+20℃)
3
5
6
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with
the rated ripple current is applied for 2,000 hours at 105°C.
Endurance
Capacitance change
Dissipation factor(tanδ)
≦ ±20% of the initial value
Leakage current
≦ specified value
≦ 200% of the specified value
The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for
1,000 hours at 105℃ without voltage applied.
Shelf Life
Capacitance change
Leakage current
Others
Conforms to JIS-C-5101-4 (1998), characteristic W
DIMENSIONS (mm)
ФD
10
12.5
ФD
P
ФD + 0.5 Max
Фd
0.6
0.6
0.8
F
5.0
5.0
7.5
L+ 1.5 Max
≤ 35 L+1.5Max
≥ 40 L+2.0 Max
L+ 2.0 Max
a
PART NUMBER SYSTEM( Example : 450V 56µF )
Z
2 W 5 6 0 M N N 1 4
14.5
3 5
Special Request
Size code(1435 : 14.5×35)
Lead length code
Lead forming Type code
Capacitance tolerance code(M:±20%)
Capacitance code (56μF)
Voltage code(450V)
Series code(PZ)
Aluminum Electrolytic Capacitor
Customer
Digi-Key
SERIES
PZ
NO.:
FIG-1
FIG-2
Tolerance
No.
CHINSAN
Part No.
Customer Capacitance
Part No.
(uF)
2022-03-25
PUBLISH DATE
On rated
Working
Capacitance Voltage
(Vdc)
Surge
Voltage
(Vdc)
Rated
Rated
Category
Tanδ
Leakage
Ripple
Ripple
ESR
Impedance
Temp
@ 25℃
Current
Current
Current
@25℃
@20℃
Range
(120Hz)
(uA)
(Max)
(mA rms) (mA rms) (mΩ max/ (mΩ max/
(2 min.) @ 105℃ @105℃
120Hz
100kHz
120Hz)
100kHz)
Dimensions (mm)
Endurance
Appearance
@ 105℃
(Hours)
Drawing
DΦ L
a
d
F
No
1
PZ2W470MSD1052R
47 µF
±20%
450 V
-25~+105
400
5000
3000
2000
10
52
5
FIG-2
2
PZ2G270MSD1040R
27 µF
±20%
400 V
-40~+105
350
2000
10
40
5
FIG-2
3
PZ2W330MNN1230
33 µF
±20%
450 V
-25~+105
300
2000
12.5 30
5
FIG-1
4
PZ2W470MNN1240
47 µF
±20%
450 V
-25~+105
350
2000
12.5 40
5
FIG-1
5
PZ2W680MNN1250
68 µF
±20%
450 V
-25~+105
400
2000
12.5 50
5
FIG-1
6
PZ2W820MNN1245A4
82 µF
±20%
450 V
-25~+105
900
1100
2000
12.5 45
5
FIG-1
7
PZ2W390MNN1038
39 µF
±20%
450 V
-25~+105
300
2000
5
FIG-1
10
38
※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test.
REMARKS:
Sleeve Color: Black.
APPROVED BY
CHECKED BY
PREPARED BY
张洪斌
曾爱娥
梁慧妍
很抱歉,暂时无法提供与“PZ2W680MNN1250”相匹配的价格&库存,您可以联系我们找货
