PZ2W470MNN1240
PZ2W470MNN1240
    CHINSAN(金山)
    插件
    ALUMINUM ELECTROLYTIC CAPACITORS
PZ2W470MNN1240 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 PZ     Series Rated voltage range: 200 to 450Vdc, Capacitance: 18 to 270μF Load life 2,000 hours at 105℃ Ideal for low profile power supply applications SPECIFICATIONS Performance Characteristics Item Category Temperature Range -40 ~ +105℃ -25 ~ +105℃ Working Voltage Range 200 ~ 400Vdc 420 ~ 450Vdc Capacitance Range 27 ~ 270 μF 18 ~ 100 μF Capacitance Tolerance Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) ±20% (at 25℃ and 120Hz) Rated Voltage (V) 200 400 420 450 tanδ(Max) 0.12 0.15 0.20 0.20 I=0.03CV + 10μA I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 2 minutes V : Rated voltage (V) Rated voltage (V) 200 400 420 ~ 450 Z(-40℃)/Z(+20℃) 6 6 — Z(-25℃)/Z(+20℃) 3 5 6 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 2,000 hours at 105°C. Endurance Capacitance change Dissipation factor(tanδ) ≦ ±20% of the initial value Leakage current ≦ specified value ≦ 200% of the specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 1,000 hours at 105℃ without voltage applied. Shelf Life Capacitance change ≦ ±20% of the initial value Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Others  Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD 10 12.5 ФD P ФD + 0.5 Max Фd 0.6 0.6 0.8 F 5.0 5.0 7.5 L+ 1.5 Max ≤ 35 L+1.5Max ≥ 40 L+2.0 Max L+ 2.0 Max a  PART NUMBER SYSTEM( Example : 450V 56µF ) Z 2 W 5 6 0 M N N 1 4 14.5 3 5 Special Request Size code(1435 : 14.5×35) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (56μF) Voltage code(450V) Series code(PZ) Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PZ NO.: FIG-1 FIG-2 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ (Hours) Drawing DΦ L a d F No 1 PZ2W470MSD1052R / 47 µF ±20% 450 V / -25~+105 / / 400 / 5000 3000 2000 10 52 / / 5 FIG-2 2 PZ2G270MSD1040R / 27 µF ±20% 400 V / -40~+105 / / 350 / / / 2000 10 40 / / 5 FIG-2 3 PZ2W330MNN1230 / 33 µF ±20% 450 V / -25~+105 / / 300 / / / 2000 12.5 30 / / 5 FIG-1 4 PZ2W470MNN1240 / 47 µF ±20% 450 V / -25~+105 / / 350 / / / 2000 12.5 40 / / 5 FIG-1 5 PZ2W680MNN1250 / 68 µF ±20% 450 V / -25~+105 / / 400 / / / 2000 12.5 50 / / 5 FIG-1 6 PZ2W820MNN1245A4 / 82 µF ±20% 450 V / -25~+105 / / 900 / / 1100 2000 12.5 45 / / 5 FIG-1 7 PZ2W390MNN1038 / 39 µF ±20% 450 V / -25~+105 / / 300 / / / 2000 / / 5 FIG-1 10 38 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: Sleeve Color: Black. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍
PZ2W470MNN1240 价格&库存
很抱歉,暂时无法提供与“PZ2W470MNN1240”相匹配的价格&库存,您可以联系我们找货
