SC2W562MLS90A0
SC2W562MLS90A0
    CHINSAN(金山)
    Radial, Can - Screw Terminals
    ALUMINUM ELECTROLYTIC CAPACITORS
SC2W562MLS90A0 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 SC   http://www.chinsan.com/products/ Series High ripple, suitable to use in industrial power supplies for inverter circuitry, etc SPECIFICATIONS Performance Characteristics Item Category Temperature Range -25 ~ +85℃ Working Voltage Range 200 ~ 600Vdc Capacitance Range 820 ~ 33,000μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Rated Voltage (V) 200 ~ 250 350 ~ 450 500 ~600 tanδ(Max) 0.20 0.20 0.25 I=0.01CV or 5000μA,whichever is smaller I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 5 minutes Leakage Current The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 2,000 hours at 85°C. ≦ ±15% of the initial value Capacitance change Endurance Dissipation factor(tanδ) ≦ 175% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 500 hours at 85℃ without voltage applied. ≦ ±15% of the initial value Capacitance change Shelf Life Dissipation factor(tanδ) ≦ 175% of the specified value Leakage current ≦ specified value Others  V : Rated voltage (V) Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) Sleeve Hexagenal headed bolt Bottom plate  S L±3Max D+2Max P±1 Pressure recief vent ФD P±1 51 22.4 7±1 PART NUMBER SYSTEM( Example : 450V 8200µF ) C 2 W 8 2 2 M L S 9 0 F 0 Special Request Size code (90F0:90×150) Terminal code Capacitance tolerance code (M:±20%) Capacitance code (8200μF) Voltage code (450V) Series code (SC) 64 28.0 76 31.5 90 31.5 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) SC NO.: 2022-03-25 PUBLISH DATE Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mA rms) (mΩ max/ (mΩ max/ @ 85℃ @ 85℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance @ 85℃ Appearance Drawing (Hours) D Φ L a d P No 1 SC2W562MLS90A0 / 5600 µF ±20% 450 V / -25~+85 / / 13900 / / / 2000 90 100 / / 31.5 --- 2 SC2W682MLS76E3 / 6800 µF ±20% 450 V / -25~+85 / / 16000 / / / 2000 76 143 / / 31.5 --- ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black.
SC2W562MLS90A0 价格&库存
很抱歉,暂时无法提供与“SC2W562MLS90A0”相匹配的价格&库存,您可以联系我们找货
