SS1C101MP26307HU
SS1C101MP26307HU
    CHINSAN(金山)
    插件
    100 µF 16 V 铝电解电容器 径向,Can 105°C 时为 1000 小时
SS1C101MP26307HU 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 SS & SS-H Series  Standard miniature series with 7mm height at 85 ℃ &105℃  SPECIFICATIONS Performance Characteristics Item Series SS Category Temperature Range -40 ~ +85℃ -40 ~ +105℃ Working Voltage Range 6.3 ~ 63 Vdc Capacitance Range 0.1 ~ 330 μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Rated Voltage (V) 6.3 10 16 25 35 50 63 tanδ(Max) 0.24 0.20 0.16 0.14 0.12 0.10 0.10 The above values should be increased by 0.02 for every additional 1000μF I=0.01CV or 3μA whichever is greater I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 2 minutes V : Rated voltage (V) Rated voltage (V) 6.3 10 16 25 35 50 63 Z(-40℃)/Z(+20℃) 10 8 6 4 4 3 3 (at 120Hz) Endurance The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 1,000 hours at 85℃(SS), or 1,000 hours at 105℃(SS-H). ≦ ±25% of the initial value Capacitance change Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ specified value Shelf Life The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 500 hours at 85℃(SS), or 500 hours at 105℃(SS-H) without voltage applied. Capacitance change ≦ ±25% of the initial value Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Others  SS-H Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD 4 5 Фd 0.45 0.45 0.45 0.45 F 1.5 2.0 2.5 3.5 ФD a  6.3 8×7 ФD + 0.5 Max L + 1.0 Max PART NUMBER SYSTEM( Example : 35V 22µF ) S S 1 V 2 2 0 M N N 0 5 0 7 Special Request Size code(0507 : 5×7) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (22μF) Voltage code (35V) Series code (SS) Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES SS-H NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 P0=12.7±0.2 P2=6.35±1.0 F=2.5+0.8 /-0.2 ΦD0=4.0±0.2 t=0.7±0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated SS1C101MP26307HU / 100 µF Working Capacitance Voltage (%) 1 H=18.5±0.5 P1=3.85±0.5 W =18.0±0.5 W0=12.5MIN Φd=0.5±0.05 ±20% (Vdc) 16 V Surge Voltage (Vdc) / Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) -40~+105 / (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ / 120Hz 100kHz 90 / 120Hz) 100kHz) / / Dimensions (mm) Endurance @ 105℃ Appearance Drawing (Hours) D Φ L a d F No 1000 6.3 7 / / 2.5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES SS-H NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 H0=16.0±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0±0.2 F1=5.0+0.8/-0.2 t=0.7±0.2 H=18.5±0.5 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Capacitance Voltage (%) 1 SS1E470MPN6307H / 47 µF Working ±20% (Vdc) 25 V Surge Voltage (Vdc) / Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) -40~+105 / (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ / 120Hz 100kHz 61 / 120Hz) 100kHz) / / Dimensions (mm) Endurance @ 105℃ Appearance Drawing (Hours) D Φ L a d F1 No 1000 6.3 7 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Capacitance Voltage (%) 1 SS1V101MNN0809H / 100 µF Working ±20% (Vdc) 35 V Surge Voltage (Vdc) / SS-H NO.: Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) -40~+105 / (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ / 2022-03-25 PUBLISH DATE 120Hz 100kHz 155 / 120Hz) 100kHz) / / Dimensions (mm) Endurance @ 105℃ Appearance Drawing (Hours) D Φ L a d F No 1000 8 9 / / 3.5 --- ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES SS-H NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 H0=16.0±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0±0.2 F1=5.0+0.8/-0.2 H=18.5±0.5 t=0.7±0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Capacitance Voltage (%) 1 SS0J331MPN0807H / 330 µF Working ±20% (Vdc) 6.3 V Surge Voltage (Vdc) / Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) -40~+105 / (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ / 120Hz 100kHz 130 / 120Hz) 100kHz) / / Dimensions (mm) Endurance @ 105℃ Appearance Drawing (Hours) D Φ L a d F1 No 1000 8 7 / / 5 --- ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black.
SS1C101MP26307HU 价格&库存
很抱歉,暂时无法提供与“SS1C101MP26307HU”相匹配的价格&库存,您可以联系我们找货
