UGS1C272MP51022U
UGS1C272MP51022U
    CHINSAN(金山)
    插件
    2700 µF 16 V 铝聚合物电容器 径向,Can 10 毫欧 105°C 时为 2000 小时
UGS1C272MP51022U 数据手册
CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor UGS       Series 2021 Change series code GS → UGS Low ESR at a high frequency range High ripple current capability Large capacitance, size 8x16~10x20 2,000 hours at 105°C SPECIFICATIONS Item Performance Characteristics Category Temperature Range -55 ~ +105℃ Working Voltage Range 10 ~ 35Vdc Surge Voltage Rated Voltage x1.15 Capacitance Tolerance M: ±20% ESR (at 25℃ and 120Hz) See the standard ratings table (at 25℃, 100~300KHz) Dissipation Factor (Tanδ) See the standard ratings table (at 25℃, 120Hz) Leakage Current ※1 See the standard ratings table (Impress the rated voltage for 2 minutes) Low Temperature Characteristics Impedance Ratio Z(-25℃)/Z(+25℃) ≤1.15 at 100KHz Z(-55℃)/Z(+25℃) ≤1.25 at 100KHz The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 2,000 hours at 105°C (Part code “F5” for 5000 hours) Endurance Capacitance change ≦ ±20% of the initial value ESR ≦ 150% of the specified value Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 60℃ 90 to 95% RH Damp Heat (Steady State) Capacitance change ≦ ±20% of the initial value ESR ≦ 150% of the specified value Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦ specified value ※1 In case of some problems for measured values, measure after applying rated voltage for 120 minutes at105°C ※2 ESR should be measured at both of the terminal ends closest to the capacitor body ◆DIMENSIONS (mm)  PART NUMBER SYSTEM ◆Lead ◆Marking ФD 6.3 8 10 Фd 0.6 0.6 0.6 L 16 16~22 16~22 α 1.5 1.5 1.5 F 2.5 3.5 5.0 CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor UGS ◆ Series Standard Ratings Rated Voltage (Vdc) Rated Capacitance (μF) Case Size ФD×L (mm) 10(1A) 1500 470 16(1C) 20(1D) 22(1P) 25(1E) 35(1V) ESR 100~300KHz (mΩ max) Rated Ripple Current 105℃,100KHz (mArms max) Tan δ max Leakage Current (μA max) 8×20 19 8×16 10 4500 0.12 3000 UGS1A152MNN0820U 5300 0.12 1504 UGS1C471MNN0816U 680 6.3×16 820 8×16 16 4000 0.12 1088 UGS1C681MNN6316S 8 7000 0.12 2624 UGS1C821MNN0816F5ERU 1000 1000 8×16 10 6100 0.12 3200 UGS1C102MNN0816RU 8×20 8 6100 0.12 1600 UGS1C102MNN0820U 1200 8×20 8 6100 0.12 1920 UGS1C122MNN0820U Part Number 1200 8×20 8 7500 0.12 1920 UGS1C122MNN0820RU 1500 10×16 8 6100 0.12 2400 UGS1C152MNN1016U 1500 10×16 8 6100 0.12 2400 UGS1C152MNN1016F5U 1800 10×16 8 6100 0.12 2880 UGS1C182MNN1016SU 1800 10×20 8 6100 0.12 2880 UGS1C182MNN1020U 2200 10×20 8 6100 0.12 3520 UGS1C222MNN1020U 2200 10×20 8 6100 0.12 3520 UGS1C222MNN1020F5U 2700 10×20 10 5700 0.12 4320 UGS1C272MNN1020U 2700 10×20 10 8100 0.12 4320 UGS1C272MNN1020F5RU 2700 10×22 10 5700 0.12 4320 UGS1C272MNN1022U 2700 10×22 10 5700 0.12 4320 UGS1C272MNN1022F5U 3000 10×22 10 7600 0.12 4800 UGS1C302MNN1022RU 680 8×16 16 4650 0.12 1360 UGS1D681RNN0816TU 820 8×16 16 4650 0.12 3280 UGS1D821MNN0816U 1000 10×16 16 4650 0.12 4000 UGS1D102MNN1016U 680 8×16 16 4650 0.12 1496 UGS1P681MNN0816U 470 8×16 16 4650 0.12 2350 UGS1E471MNN0816U 470 8×20 16 4650 0.12 2350 UGS1E471MNN0820U 680 8×16 16 4650 0.12 3400 UGS1E681MNN0816U 680 8×16 16 4650 0.12 3400 UGS1E681MNN0816UX 820 8×20 16 5000 0.12 4100 UGS1E821MNN0820U 820 8×21 16 5000 0.12 4100 UGS1E821MNN0821SU 820 10×16 20 4000 0.12 4100 UGS1E821MNN1016F5U 1000 10×16 16 5000 0.1 5000 UGS1E102MNN1016F5RU 330 10×16 28 2600 0.12 2310 UGS1V331MNN1016U 680 10×20 28 2600 0.12 4760 UGS1V681MNN1020U CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor PA RT N U M B E R S Y S T E M  RADIAL LEAD TYPE Series Rated Voltage Capacitance Tolerance Lead Forming Type Lead Length Case Dimension Special Request (1) (2) (3) (4) (5) (6) (7) (8) (1) Series Series DIP UPS UPR UUL UPE SMD VSG VSP VSU VSE URP URH UGP UGS UGV UPC (2) Rated Voltage Code 0E 0J 6K 7H 1A 1B AG 1C 1D 1P 1E 1F 1V 1H 1J 2A WV 2.5 6.3 6.8 7.5 10 12 14 16 20 22 25 30 35 50 63 100 (3) Capacitance Code 6R8 μF 6.8 100 10 180 560 101 181 561 102 182 18 56 100 180 560 1000 1800 (4) Capacitance Tolerance Code J Q R K V M H % ±5 +30 / -10 +20 / -0 ± 10 +20 / -10 ± 20 +20 / -5 (5) Lead Type Code C P Description Cutting Taping Drawing Fig 1 Fig 2 (6) Lead Length (Cut / Formed lead) Code 3 4 U 7 D X R B E G 2 M T N Length 3.5 4.5 5.5 7 4 2.3 2.5 2.8 3.1 3.3 2.5 3.5 3.8 +20mm min Tolerance ±0.5 ±0.2 ±0.3 -15mm min Taping Code Code Z 2 3 7 5 S Lead Pitch:+0.8/-0.2 2.0 2.5 3.5 3.5 5.0 5.0 (7) Case Dimension DIP Code 0508 6305 6308 6316 0807 0808 0811 0816 0820 1012 1016 1020 10×16 10×20 Size 5×8 6.3×5 6.3×8 6.3×16 8×7 8×8 8×11 8×16 8×20 10×12 SMD Code 5057 6343 6357 6377 6309 0867 0897 08C7 1077 10C4 Size 5×5.7 6.3×4.3 6.3×5.7 6.3×7.7 6.3×9 8×6.7 8×9.7 8×12.7 10×7.7 10×12.4 (8) Special Request Code R F5 L T Description High Rated ripple current Endurance 5000 hrous Low Leakage Current Terminal strength Code U E X S Description Convex Rubber Low ESR Pitch 2.5mm Limit high CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor  MARKING AND DATE CODE Trade Mark "CS" Chinsan Solid Capacitor, Show on Dimension ≧8 Ф Code (Date Code) (1)DAY (1) (2) (3) Code 1 2 3 4 5 1 1 0 Week The first week The second week The third week The fourth week The fifth week (2)Month Code 1 2 3 4 5 6 Month Jan Feb Mar Apr May Jun Code 7 8 9 X Y Z Month July Aug Sep Oct Nov Dec Code 9 0 1 2 3 4 Year 2019 2020 2021 2022 2023 2024 (3)Year Series (Print Code) Series UPS UPR UUL UPE URP URH UGP UGV UGS Ф 5~ Ф 6.3 -- R L E Ф 8~ Ф 10 UPS -- UL UPE RP -- H P V S RH GP GV GS UPC VSG VSP C G UPC SG VSU VSE P U E SP SU SE  LEAD FORMING TYPE Dimensions (Unit: mm) Part Number ΦD F ι 3 4 U 7 D X R B E G 2 M T 3.5 4.5 5.5 7 4 2.3 2.5 2.8 3.1 3.3 2.5 3.5 3.8 Cut 2 ---- 6.3 2.5 ---- 8 3.5 ---- 10 5 ---- ±0.2 ±0.3 D ±0.5 5 (Part number for lead length and pitch for taping) F Type L C L CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor  TAPING Figure 1 Ф8 Фd ±0.05 0.45 0.45/0.6 0.6 P ±0.1 12.7 12.7 12.7 P0 ±0.2 12.7 12.7 12.7 P1 ±0.5 3.85 3.85 3.85 P2 ±1.0 6.35 6.35 6.35 5 5 5 PS P5 0.8 -0.2 H ±0.5 H0 ±0.5 17.5 18.5 PS P5 17.5 16 18.5 PS P5 17.5 16 18.5 16 W ±0.5 18 18 18 W0 Minimum 12.5 12.5 12.5 D0 ±0.2 4 4 4 t ±0.2 0.7 0.7 0.7 Symbol Tolerance Фd ±0.05 0.45/0.6 0.6 0.6 P ±0.1 12.7 12.7 12.7 P0 ±0.2 12.7 12.7 12.7 P1 ±0.5 5.1 4.6 3.85 P2 ±1.0 6.35 6.35 6.35 2.5 3.5 5 F Figure 3 Ф 6.3 Tolerance F Figure 2 Ф5 Symbol +0.8 -0.2 Ф 6.3 P2 H ±0.5 118.5 H0 ±0.5 - Ф8 P3 18.5 H3 20 - Ф 10 P7 17.5 P5 18.5 H5 20 - W ±0.5 18 18 18 W0 Minimum 12.5 12.5 12.5 D0 ±0.2 4 4 4 t ±0.2 0.7 0.7 0.7 Symbol Tolerance Фd ±0.05 0.45 P ±0.1 12.7 P0 ±0.2 12.7 P1 ±0.5 5.35 P2 ±1.0 6.35 F +0.8 -0.2 Ф5 PZ 2.0 H ±0.5 18.5 H0 ±0.5 - W ±0.5 18 W0 Minimum 12.5 D0 ±0.2 4 t ±0.2 0.7 J5 21
UGS1C272MP51022U 价格&库存
很抱歉,暂时无法提供与“UGS1C272MP51022U”相匹配的价格&库存,您可以联系我们找货
