CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS
CAPACITOR Aluminum Solid Capacitor
UGS
Series
2021 Change series code GS → UGS
Low ESR at a high frequency range
High ripple current capability
Large capacitance, size 8x16~10x20
2,000 hours at 105°C
SPECIFICATIONS
Item
Performance Characteristics
Category Temperature Range
-55 ~ +105℃
Working Voltage Range
10 ~ 35Vdc
Surge Voltage
Rated Voltage x1.15
Capacitance Tolerance
M: ±20%
ESR
(at 25℃ and 120Hz)
See the standard ratings table (at 25℃, 100~300KHz)
Dissipation Factor (Tanδ)
See the standard ratings table (at 25℃, 120Hz)
Leakage Current ※1
See the standard ratings table (Impress the rated voltage for 2 minutes)
Low Temperature Characteristics
Impedance Ratio
Z(-25℃)/Z(+25℃) ≤1.15 at 100KHz
Z(-55℃)/Z(+25℃) ≤1.25 at 100KHz
The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage
with the rated ripple current is applied for 2,000 hours at 105°C (Part code “F5” for 5000 hours)
Endurance
Capacitance change
≦ ±20% of the initial value
ESR
≦ 150% of the specified value
Dissipation factor(tanδ)
Leakage current
≦ specified value
The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000
hours at 60℃ 90 to 95% RH
Damp Heat
(Steady State)
Capacitance change
ESR
Leakage current
≦ specified value
※1 In case of some problems for measured values, measure after applying rated voltage for 120 minutes at105°C
※2 ESR should be measured at both of the terminal ends closest to the capacitor body
◆DIMENSIONS (mm)
PART NUMBER SYSTEM
◆Lead
◆Marking
ФD
6.3
8
10
Фd
0.6
0.6
0.6
L
16
16~22
16~22
α
1.5
1.5
1.5
F
2.5
3.5
5.0
UGS
Series
Standard Ratings
Rated
Voltage
(Vdc)
Rated
Capacitance
(μF)
Case Size
ФD×L
(mm)
10(1A)
1500
470
16(1C)
20(1D)
22(1P)
25(1E)
35(1V)
ESR
100~300KHz
(mΩ max)
Rated Ripple Current
105℃,100KHz
(mArms max)
Tan δ
max
Leakage
Current
(μA max)
8×20
19
8×16
10
4500
0.12
3000
UGS1A152MNN0820U
5300
0.12
1504
UGS1C471MNN0816U
680
6.3×16
820
8×16
16
4000
0.12
1088
UGS1C681MNN6316S
8
7000
0.12
2624
UGS1C821MNN0816F5ERU
1000
1000
8×16
10
6100
0.12
3200
UGS1C102MNN0816RU
8×20
8
6100
0.12
1600
UGS1C102MNN0820U
1200
8×20
8
6100
0.12
1920
UGS1C122MNN0820U
Part Number
1200
8×20
8
7500
0.12
1920
UGS1C122MNN0820RU
1500
10×16
8
6100
0.12
2400
UGS1C152MNN1016U
1500
10×16
8
6100
0.12
2400
UGS1C152MNN1016F5U
1800
10×16
8
6100
0.12
2880
UGS1C182MNN1016SU
1800
10×20
8
6100
0.12
2880
UGS1C182MNN1020U
2200
10×20
8
6100
0.12
3520
UGS1C222MNN1020U
2200
10×20
8
6100
0.12
3520
UGS1C222MNN1020F5U
2700
10×20
10
5700
0.12
4320
UGS1C272MNN1020U
2700
10×20
10
8100
0.12
4320
UGS1C272MNN1020F5RU
2700
10×22
10
5700
0.12
4320
UGS1C272MNN1022U
2700
10×22
10
5700
0.12
4320
UGS1C272MNN1022F5U
3000
10×22
10
7600
0.12
4800
UGS1C302MNN1022RU
680
8×16
16
4650
0.12
1360
UGS1D681RNN0816TU
820
8×16
16
4650
0.12
3280
UGS1D821MNN0816U
1000
10×16
16
4650
0.12
4000
UGS1D102MNN1016U
680
8×16
16
4650
0.12
1496
UGS1P681MNN0816U
470
8×16
16
4650
0.12
2350
UGS1E471MNN0816U
470
8×20
16
4650
0.12
2350
UGS1E471MNN0820U
680
8×16
16
4650
0.12
3400
UGS1E681MNN0816U
680
8×16
16
4650
0.12
3400
UGS1E681MNN0816UX
820
8×20
16
5000
0.12
4100
UGS1E821MNN0820U
820
8×21
16
5000
0.12
4100
UGS1E821MNN0821SU
820
10×16
0.12
4100
UGS1E821MNN1016F5U
1000
10×16
16
5000
0.1
5000
UGS1E102MNN1016F5RU
330
10×16
28
2600
0.12
2310
UGS1V331MNN1016U
680
10×20
28
2600
0.12
4760
UGS1V681MNN1020U
PA RT N U M B E R S Y S T E M
RADIAL LEAD TYPE
Series
Rated Voltage
Capacitance
Tolerance
Lead Forming Type
Lead Length
Case Dimension
Special Request
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
(1) Series
Series
DIP
UPS
UPR
UUL
UPE
SMD
VSG
VSP
VSU
VSE
URP
URH
UGP
UGS
UGV
UPC
(2) Rated Voltage
Code
0E
0J
6K
7H
1A
1B
AG
1C
1D
1P
1E
1F
1V
1H
1J
2A
WV
2.5
6.3
6.8
7.5
10
12
14
16
25
30
35
50
63
100
(3) Capacitance
Code
6R8
μF
6.8
100
10
180
560
101
181
561
102
182
18
56
100
180
560
1000
1800
(4) Capacitance Tolerance
Code
J
Q
R
K
V
M
H
±5
+30 / -10
+20 / -0
± 10
+20 / -10
± 20
+20 / -5
(5) Lead Type
Code
C
P
Description
Cutting
Taping
Drawing
Fig 1
Fig 2
(6) Lead Length (Cut / Formed lead)
Code
3
4
U
7
D
X
R
B
E
G
2
M
T
N
Length
3.5
4.5
5.5
7
4
2.3
2.5
2.8
3.1
3.3
2.5
3.5
3.8
+20mm min
Tolerance
±0.5
±0.2
±0.3
-15mm min
Taping Code
Code
Z
2
3
7
5
S
Lead Pitch:+0.8/-0.2
2.0
2.5
3.5
3.5
5.0
5.0
(7) Case Dimension
DIP Code
0508
6305
6308
6316
0807
0808
0811
0816
0820
1012
1016
1020
10×16
10×20
Size
5×8
6.3×5
6.3×8
6.3×16
8×7
8×8
8×11
8×16
8×20
10×12
SMD Code
5057
6343
6357
6377
6309
0867
0897
08C7
1077
10C4
Size
5×5.7
6.3×4.3
6.3×5.7
6.3×7.7
6.3×9
8×6.7
8×9.7
8×12.7
10×7.7
10×12.4
(8) Special Request
Code
R
F5
L
T
Description
High Rated ripple current
Endurance 5000 hrous
Low Leakage Current
Terminal strength
Code
U
E
X
S
Description
Convex Rubber
Low ESR
Pitch 2.5mm
Limit high
MARKING AND DATE CODE
Trade Mark "CS"
Chinsan Solid Capacitor, Show on Dimension ≧8 Ф
Code (Date Code)
(1)DAY
(1)
(2)
(3)
Code
1
2
3
4
5
1
1
Week
The first week
The second week
The third week
The fourth week
The fifth week
(2)Month
Code
1
2
3
4
5
6
Month
Jan
Feb
Mar
Apr
May
Jun
Code
7
8
9
X
Y
Z
Month
July
Aug
Sep
Oct
Nov
Dec
Code
9
2
3
4
Year
2019
2020
2021
2022
2023
2024
(3)Year
Series (Print Code)
Series
UPS UPR UUL UPE URP URH UGP UGV UGS
Ф 5~ Ф 6.3
R
L
E
Ф 8~ Ф 10
UPS
UL
UPE RP
H
P
V
S
RH
GP
GV
GS
UPC VSG VSP
C
G
UPC SG
VSU VSE
P
U
E
SP
SU
SE
LEAD FORMING TYPE
Dimensions (Unit: mm)
Part
Number
ΦD
F
ι
3
4
U
7
D
X
R
B
E
G
2
M
T
3.5
4.5
5.5
7
4
2.3
2.5
2.8
3.1
3.3
2.5
3.5
3.8
Cut
2
6.3
2.5
8
3.5
10
5
±0.2
±0.3
D
±0.5
5
(Part number for lead length and pitch for taping)
F
Type
L
C
L
TAPING
Figure 1
Ф8
Фd
±0.05
0.45
0.45/0.6
0.6
P
±0.1
12.7
12.7
12.7
P0
±0.2
12.7
12.7
12.7
P1
±0.5
3.85
3.85
3.85
P2
±1.0
6.35
6.35
6.35
5
5
5
PS
P5
0.8
-0.2
H
±0.5
H0
±0.5
17.5
18.5
PS
P5
17.5
16
18.5
PS
P5
17.5
16
18.5
16
W
±0.5
18
18
18
W0
Minimum
12.5
12.5
12.5
D0
±0.2
4
4
4
t
±0.2
0.7
0.7
0.7
Symbol
Tolerance
Фd
±0.05
0.45/0.6
0.6
0.6
P
±0.1
12.7
12.7
12.7
P0
±0.2
12.7
12.7
12.7
P1
±0.5
5.1
4.6
3.85
P2
±1.0
6.35
6.35
6.35
2.5
3.5
5
F
Figure 3
Ф 6.3
Tolerance
F
Figure 2
Ф5
Symbol
+0.8
-0.2
Ф 6.3
P2
H
±0.5
118.5
H0
±0.5
Ф8
P3
18.5
H3
Ф 10
P7
17.5
P5
18.5
H5
W
±0.5
18
18
18
W0
Minimum
12.5
12.5
12.5
D0
±0.2
4
4
4
t
±0.2
0.7
0.7
0.7
Symbol
Tolerance
Фd
±0.05
0.45
P
±0.1
12.7
P0
±0.2
12.7
P1
±0.5
5.35
P2
±1.0
6.35
F
+0.8
-0.2
Ф5
PZ
2.0
H
±0.5
18.5
H0
±0.5
W
±0.5
18
W0
Minimum
12.5
D0
±0.2
4
t
±0.2
0.7
J5
21
很抱歉,暂时无法提供与“UGS1C222MP51020F5”相匹配的价格&库存,您可以联系我们找货
