CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS
CAPACITOR Aluminum Solid Capacitor
UGV
Series
2021 Change series code GV → UGV
Low ESR at a high frequency range
High ripple current capability
High voltage 25~100V
2,000 hours at 105°C
SPECIFICATIONS
Item
Performance Characteristics
Category Temperature Range
-55 ~ +105℃
Working Voltage Range
20 ~ 100Vdc
Surge Voltage
Rated Voltage x1.15
Capacitance Tolerance
M: ±20%
ESR
(at 25℃ and 120Hz)
See the standard ratings table (at 25℃, 100~300KHz)
Dissipation Factor (Tanδ)
See the standard ratings table (at 25℃, 120Hz)
Leakage Current ※1
See the standard ratings table (Impress the rated voltage for 2 minutes)
Low Temperature Characteristics
Impedance Ratio
Z(-25℃)/Z(+25℃) ≤1.15 at 100KHz
Z(-55℃)/Z(+25℃) ≤1.25 at 100KHz
The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage
with the rated ripple current is applied for 2,000 hours at 105°C
Endurance
Capacitance change
≦ ±20% of the initial value
ESR
≦ 150% of the specified value
Dissipation factor(tanδ)
Leakage current
≦ specified value
The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000
hours at 60℃ 90 to 95% RH
Damp Heat
(Steady State)
Capacitance change
ESR
Leakage current
≦ specified value
※1 In case of some problems for measured values, measure after applying rated voltage for 120 minutes at105°C
※2 ESR should be measured at both of the terminal ends closest to the capacitor body
◆DIMENSIONS (mm)
◆Lead
6.3
ФD
PART NUMBER SYSTEM
◆Marking
8
0.6 8 0.6
Фd
0.45
0.6
0.6
L
5
8
11
8
α
1
1
1.5
1
F
2.5
2.5
2.5
3.5
10
0.6
0.6
11
7
10
12
1.5
1.5
1.5
1.5
3.5
5.0
5.0
5.0
0.6
UGV
Series
Standard Ratings
Rated
Voltage
(Vdc)
Rated
Capacitance
(μF)
Case Size
ФD×L
(mm)
ESR
100~300KHz
(mΩ max)
Rated Ripple Current
105℃,100KHz
(mArms max)
20(1D)
820
10×12
16
47
6.3×5
30
100
6.3×8
150
6.3×8
25(1E)
35(1V)
50(1H)
63(1J)
100(2A)
Tan δ
max
Leakage
Current
(μA max)
4650
0.12
3280
UGV1D821MNN1012U
2600
0.12
300
UGV1E470MNN6305
28
2700
0.12
500
UGV1E101MNN6308
18
3200
0.12
750
UGV1E151MNN6308
Part Number
180
8×8
18
4100
0.12
900
UGV1E181MNN0808U
180
8×11
16
4650
0.12
900
UGV1E181MNN0811U
180
8×11
16
4650
0.12
900
UGV1E181MNN0811TU
220
6.3×11
30
2600
0.12
1100
UGV1E221MNN6311U
220
8×8
18
4100
0.12
1100
UGV1E221MNN0808U
220
8×11
16
4650
0.12
1100
UGV1E221MNN0811U
220
10×7
25
2800
0.12
1100
UGV1E221MNN1007U
270
10×12
16
5000
0.12
1350
UGV1E271MNN1012U
330
8×11
16
4650
0.12
1650
UGV1E331MNN0811U
330
10×12
14
5000
0.12
1650
UGV1E331MNN1012U
390
10×12
14
5000
0.12
1950
UGV1E391MNN1012U
470
8×11
16
4650
0.12
2350
UGV1E471MNN0811U
470
10×10
30
3400
0.12
2350
UGV1E471MNN1010SU
470
10×12
14
5000
0.12
2350
UGV1E471MNN1012U
680
10×12
0.12
3400
UGV1E681MNN1012U
680
10×12
18
5000
0.12
3400
UGV1E681MNN1012RU
18
8×11
34
2100
0.12
300
UGV1V180MNN0811U
39
8×11
30
2100
0.12
300
UGV1V390MNN0811U
47
8×11
30
2100
0.12
329
UGV1V470MNN0811U
82
8×11
27
2300
0.12
574
UGV1V820MNN0811U
100
8×11
27
2300
0.12
700
UGV1V101MNN0811U
100
10×12
26
2700
0.12
700
UGV1V101MNN1012U
120
10×12
26
2700
0.12
840
UGV1V121MNN1012U
150
10×12
26
2700
0.12
1050
UGV1V151MNN1012U
220
10×12
26
2700
0.12
1540
UGV1V221MNN1012U
27
8×11
33
2000
0.12
300
UGV1H270MNN0811U
39
8×11
29
2200
0.12
390
UGV1H390MNN0811U
47
10×12
29
2500
0.12
470
UGV1H470MNN1012U
68
10×12
28
2600
0.12
680
UGV1H680MNN1012U
47
10×12
29
2600
0.12
592
UGV1J470MNN1012U
68
10×12
29
2600
0.12
857
UGV1J680MNN1012U
18
8×11
40
1850
0.12
360
UGV2A180MNN0811U
47
10×12
38
2100
0.12
940
UGV2A470MNN1012U
PA RT N U M B E R S Y S T E M
RADIAL LEAD TYPE
Series
Rated Voltage
Capacitance
Tolerance
Lead Forming Type
Lead Length
Case Dimension
Special Request
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
(1) Series
Series
DIP
UPS
UPR
UUL
UPE
SMD
VSG
VSP
VSU
VSE
URP
URH
UGP
UGS
UGV
UPC
(2) Rated Voltage
Code
0E
0J
6K
7H
1A
1B
AG
1C
1D
1P
1E
1F
1V
1H
1J
2A
WV
2.5
6.3
6.8
7.5
10
12
14
16
25
30
35
50
63
100
(3) Capacitance
Code
6R8
μF
6.8
100
10
180
560
101
181
561
102
182
18
56
100
180
560
1000
1800
(4) Capacitance Tolerance
Code
J
Q
R
K
V
M
H
±5
+30 / -10
+20 / -0
± 10
+20 / -10
± 20
+20 / -5
(5) Lead Type
Code
C
P
Description
Cutting
Taping
Drawing
Fig 1
Fig 2
(6) Lead Length (Cut / Formed lead)
Code
3
4
U
7
D
X
R
B
E
G
2
M
T
N
Length
3.5
4.5
5.5
7
4
2.3
2.5
2.8
3.1
3.3
2.5
3.5
3.8
+20mm min
Tolerance
±0.5
±0.2
±0.3
-15mm min
Taping Code
Code
Z
2
3
7
5
S
Lead Pitch:+0.8/-0.2
2.0
2.5
3.5
3.5
5.0
5.0
(7) Case Dimension
DIP Code
0508
6305
6308
6316
0807
0808
0811
0816
0820
1012
1016
1020
10×16
10×20
Size
5×8
6.3×5
6.3×8
6.3×16
8×7
8×8
8×11
8×16
8×20
10×12
SMD Code
5057
6343
6357
6377
6309
0867
0897
08C7
1077
10C4
Size
5×5.7
6.3×4.3
6.3×5.7
6.3×7.7
6.3×9
8×6.7
8×9.7
8×12.7
10×7.7
10×12.4
(8) Special Request
Code
R
F5
L
T
Description
High Rated ripple current
Endurance 5000 hrous
Low Leakage Current
Terminal strength
Code
U
E
X
S
Description
Convex Rubber
Low ESR
Pitch 2.5mm
Limit high
MARKING AND DATE CODE
Trade Mark "CS"
Chinsan Solid Capacitor, Show on Dimension ≧8 Ф
Code (Date Code)
(1)DAY
(1)
(2)
(3)
Code
1
2
3
4
5
1
1
Week
The first week
The second week
The third week
The fourth week
The fifth week
(2)Month
Code
1
2
3
4
5
6
Month
Jan
Feb
Mar
Apr
May
Jun
Code
7
8
9
X
Y
Z
Month
July
Aug
Sep
Oct
Nov
Dec
Code
9
2
3
4
Year
2019
2020
2021
2022
2023
2024
(3)Year
Series (Print Code)
Series
UPS UPR UUL UPE URP URH UGP UGV UGS
Ф 5~ Ф 6.3
R
L
E
Ф 8~ Ф 10
UPS
UL
UPE RP
H
P
V
RH
GP
GV
GS
UPC VSG VSP
C
G
UPC SG
VSU VSE
P
U
E
SP
SU
SE
LEAD FORMING TYPE
Dimensions (Unit: mm)
Part
Number
ΦD
F
ι
3
4
U
7
D
X
R
B
E
G
2
M
T
3.5
4.5
5.5
7
4
2.3
2.5
2.8
3.1
3.3
2.5
3.5
3.8
Cut
2
6.3
2.5
8
3.5
10
5
±0.2
±0.3
D
±0.5
5
(Part number for lead length and pitch for taping)
F
Type
L
C
L
TAPING
Figure 1
Ф8
Фd
±0.05
0.45
0.45/0.6
0.6
P
±0.1
12.7
12.7
12.7
P0
±0.2
12.7
12.7
12.7
P1
±0.5
3.85
3.85
3.85
P2
±1.0
6.35
6.35
6.35
5
5
5
PS
P5
0.8
-0.2
H
±0.5
H0
±0.5
17.5
18.5
PS
P5
17.5
16
18.5
PS
P5
17.5
16
18.5
16
W
±0.5
18
18
18
W0
Minimum
12.5
12.5
12.5
D0
±0.2
4
4
4
t
±0.2
0.7
0.7
0.7
Symbol
Tolerance
Фd
±0.05
0.45/0.6
0.6
0.6
P
±0.1
12.7
12.7
12.7
P0
±0.2
12.7
12.7
12.7
P1
±0.5
5.1
4.6
3.85
P2
±1.0
6.35
6.35
6.35
2.5
3.5
5
F
Figure 3
Ф 6.3
Tolerance
F
Figure 2
Ф5
Symbol
+0.8
-0.2
Ф 6.3
P2
H
±0.5
118.5
H0
±0.5
Ф8
P3
18.5
H3
Ф 10
P7
17.5
P5
18.5
H5
W
±0.5
18
18
18
W0
Minimum
12.5
12.5
12.5
D0
±0.2
4
4
4
t
±0.2
0.7
0.7
0.7
Symbol
Tolerance
Фd
±0.05
0.45
P
±0.1
12.7
P0
±0.2
12.7
P1
±0.5
5.35
P2
±1.0
6.35
F
+0.8
-0.2
Ф5
PZ
2.0
H
±0.5
18.5
H0
±0.5
W
±0.5
18
W0
Minimum
12.5
D0
±0.2
4
t
±0.2
0.7
J5
21
很抱歉,暂时无法提供与“UGV1E681MJ51012RU”相匹配的价格&库存,您可以联系我们找货
