UGV1E221MP26311U
UGV1E221MP26311U
    CHINSAN(金山)
    插件
    CONDUCTIVE POLYMER SOLID CAPACIT
UGV1E221MP26311U 数据手册
CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor UGV       Series 2021 Change series code GV → UGV Low ESR at a high frequency range High ripple current capability High voltage 25~100V 2,000 hours at 105°C SPECIFICATIONS Item Performance Characteristics Category Temperature Range -55 ~ +105℃ Working Voltage Range 20 ~ 100Vdc Surge Voltage Rated Voltage x1.15 Capacitance Tolerance M: ±20% ESR (at 25℃ and 120Hz) See the standard ratings table (at 25℃, 100~300KHz) Dissipation Factor (Tanδ) See the standard ratings table (at 25℃, 120Hz) Leakage Current ※1 See the standard ratings table (Impress the rated voltage for 2 minutes) Low Temperature Characteristics Impedance Ratio Z(-25℃)/Z(+25℃) ≤1.15 at 100KHz Z(-55℃)/Z(+25℃) ≤1.25 at 100KHz The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 2,000 hours at 105°C Endurance Capacitance change ≦ ±20% of the initial value ESR ≦ 150% of the specified value Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 60℃ 90 to 95% RH Damp Heat (Steady State) Capacitance change ≦ ±20% of the initial value ESR ≦ 150% of the specified value Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦ specified value ※1 In case of some problems for measured values, measure after applying rated voltage for 120 minutes at105°C ※2 ESR should be measured at both of the terminal ends closest to the capacitor body ◆DIMENSIONS (mm) ◆Lead 6.3 ФD  PART NUMBER SYSTEM ◆Marking 8 0.6 8 0.6 Фd 0.45 0.6 0.6 L 5 8 11 8 α 1 1 1.5 1 F 2.5 2.5 2.5 3.5 10 0.6 0.6 11 7 10 12 1.5 1.5 1.5 1.5 3.5 5.0 5.0 5.0 0.6 CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor UGV ◆ Series Standard Ratings Rated Voltage (Vdc) Rated Capacitance (μF) Case Size ФD×L (mm) ESR 100~300KHz (mΩ max) Rated Ripple Current 105℃,100KHz (mArms max) 20(1D) 820 10×12 16 47 6.3×5 30 100 6.3×8 150 6.3×8 25(1E) 35(1V) 50(1H) 63(1J) 100(2A) Tan δ max Leakage Current (μA max) 4650 0.12 3280 UGV1D821MNN1012U 2600 0.12 300 UGV1E470MNN6305 28 2700 0.12 500 UGV1E101MNN6308 18 3200 0.12 750 UGV1E151MNN6308 Part Number 180 8×8 18 4100 0.12 900 UGV1E181MNN0808U 180 8×11 16 4650 0.12 900 UGV1E181MNN0811U 180 8×11 16 4650 0.12 900 UGV1E181MNN0811TU 220 6.3×11 30 2600 0.12 1100 UGV1E221MNN6311U 220 8×8 18 4100 0.12 1100 UGV1E221MNN0808U 220 8×11 16 4650 0.12 1100 UGV1E221MNN0811U 220 10×7 25 2800 0.12 1100 UGV1E221MNN1007U 270 10×12 16 5000 0.12 1350 UGV1E271MNN1012U 330 8×11 16 4650 0.12 1650 UGV1E331MNN0811U 330 10×12 14 5000 0.12 1650 UGV1E331MNN1012U 390 10×12 14 5000 0.12 1950 UGV1E391MNN1012U 470 8×11 16 4650 0.12 2350 UGV1E471MNN0811U 470 10×10 30 3400 0.12 2350 UGV1E471MNN1010SU 470 10×12 14 5000 0.12 2350 UGV1E471MNN1012U 680 10×12 20 3100 0.12 3400 UGV1E681MNN1012U 680 10×12 18 5000 0.12 3400 UGV1E681MNN1012RU 18 8×11 34 2100 0.12 300 UGV1V180MNN0811U 39 8×11 30 2100 0.12 300 UGV1V390MNN0811U 47 8×11 30 2100 0.12 329 UGV1V470MNN0811U 82 8×11 27 2300 0.12 574 UGV1V820MNN0811U 100 8×11 27 2300 0.12 700 UGV1V101MNN0811U 100 10×12 26 2700 0.12 700 UGV1V101MNN1012U 120 10×12 26 2700 0.12 840 UGV1V121MNN1012U 150 10×12 26 2700 0.12 1050 UGV1V151MNN1012U 220 10×12 26 2700 0.12 1540 UGV1V221MNN1012U 27 8×11 33 2000 0.12 300 UGV1H270MNN0811U 39 8×11 29 2200 0.12 390 UGV1H390MNN0811U 47 10×12 29 2500 0.12 470 UGV1H470MNN1012U 68 10×12 28 2600 0.12 680 UGV1H680MNN1012U 47 10×12 29 2600 0.12 592 UGV1J470MNN1012U 68 10×12 29 2600 0.12 857 UGV1J680MNN1012U 18 8×11 40 1850 0.12 360 UGV2A180MNN0811U 47 10×12 38 2100 0.12 940 UGV2A470MNN1012U CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor PA RT N U M B E R S Y S T E M  RADIAL LEAD TYPE Series Rated Voltage Capacitance Tolerance Lead Forming Type Lead Length Case Dimension Special Request (1) (2) (3) (4) (5) (6) (7) (8) (1) Series Series DIP UPS UPR UUL UPE SMD VSG VSP VSU VSE URP URH UGP UGS UGV UPC (2) Rated Voltage Code 0E 0J 6K 7H 1A 1B AG 1C 1D 1P 1E 1F 1V 1H 1J 2A WV 2.5 6.3 6.8 7.5 10 12 14 16 20 22 25 30 35 50 63 100 (3) Capacitance Code 6R8 μF 6.8 100 10 180 560 101 181 561 102 182 18 56 100 180 560 1000 1800 (4) Capacitance Tolerance Code J Q R K V M H % ±5 +30 / -10 +20 / -0 ± 10 +20 / -10 ± 20 +20 / -5 (5) Lead Type Code C P Description Cutting Taping Drawing Fig 1 Fig 2 (6) Lead Length (Cut / Formed lead) Code 3 4 U 7 D X R B E G 2 M T N Length 3.5 4.5 5.5 7 4 2.3 2.5 2.8 3.1 3.3 2.5 3.5 3.8 +20mm min Tolerance ±0.5 ±0.2 ±0.3 -15mm min Taping Code Code Z 2 3 7 5 S Lead Pitch:+0.8/-0.2 2.0 2.5 3.5 3.5 5.0 5.0 (7) Case Dimension DIP Code 0508 6305 6308 6316 0807 0808 0811 0816 0820 1012 1016 1020 10×16 10×20 Size 5×8 6.3×5 6.3×8 6.3×16 8×7 8×8 8×11 8×16 8×20 10×12 SMD Code 5057 6343 6357 6377 6309 0867 0897 08C7 1077 10C4 Size 5×5.7 6.3×4.3 6.3×5.7 6.3×7.7 6.3×9 8×6.7 8×9.7 8×12.7 10×7.7 10×12.4 (8) Special Request Code R F5 L T Description High Rated ripple current Endurance 5000 hrous Low Leakage Current Terminal strength Code U E X S Description Convex Rubber Low ESR Pitch 2.5mm Limit high CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor  MARKING AND DATE CODE Trade Mark "CS" Chinsan Solid Capacitor, Show on Dimension ≧8 Ф Code (Date Code) (1)DAY (1) (2) (3) Code 1 2 3 4 5 1 1 0 Week The first week The second week The third week The fourth week The fifth week (2)Month Code 1 2 3 4 5 6 Month Jan Feb Mar Apr May Jun Code 7 8 9 X Y Z Month July Aug Sep Oct Nov Dec Code 9 0 1 2 3 4 Year 2019 2020 2021 2022 2023 2024 (3)Year Series (Print Code) Series UPS UPR UUL UPE URP URH UGP UGV UGS Ф 5~ Ф 6.3 -- R L E Ф 8~ Ф 10 UPS -- UL UPE RP -- H P V -- RH GP GV GS UPC VSG VSP C G UPC SG VSU VSE P U E SP SU SE  LEAD FORMING TYPE Dimensions (Unit: mm) Part Number ΦD F ι 3 4 U 7 D X R B E G 2 M T 3.5 4.5 5.5 7 4 2.3 2.5 2.8 3.1 3.3 2.5 3.5 3.8 Cut 2 ---- 6.3 2.5 ---- 8 3.5 ---- 10 5 ---- ±0.2 ±0.3 D ±0.5 5 (Part number for lead length and pitch for taping) F Type L C L CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor  TAPING Figure 1 Ф8 Фd ±0.05 0.45 0.45/0.6 0.6 P ±0.1 12.7 12.7 12.7 P0 ±0.2 12.7 12.7 12.7 P1 ±0.5 3.85 3.85 3.85 P2 ±1.0 6.35 6.35 6.35 5 5 5 PS P5 0.8 -0.2 H ±0.5 H0 ±0.5 17.5 18.5 PS P5 17.5 16 18.5 PS P5 17.5 16 18.5 16 W ±0.5 18 18 18 W0 Minimum 12.5 12.5 12.5 D0 ±0.2 4 4 4 t ±0.2 0.7 0.7 0.7 Symbol Tolerance Фd ±0.05 0.45/0.6 0.6 0.6 P ±0.1 12.7 12.7 12.7 P0 ±0.2 12.7 12.7 12.7 P1 ±0.5 5.1 4.6 3.85 P2 ±1.0 6.35 6.35 6.35 2.5 3.5 5 F Figure 3 Ф 6.3 Tolerance F Figure 2 Ф5 Symbol +0.8 -0.2 Ф 6.3 P2 H ±0.5 118.5 H0 ±0.5 - Ф8 P3 18.5 H3 20 - Ф 10 P7 17.5 P5 18.5 H5 20 - W ±0.5 18 18 18 W0 Minimum 12.5 12.5 12.5 D0 ±0.2 4 4 4 t ±0.2 0.7 0.7 0.7 Symbol Tolerance Фd ±0.05 0.45 P ±0.1 12.7 P0 ±0.2 12.7 P1 ±0.5 5.35 P2 ±1.0 6.35 F +0.8 -0.2 Ф5 PZ 2.0 H ±0.5 18.5 H0 ±0.5 - W ±0.5 18 W0 Minimum 12.5 D0 ±0.2 4 t ±0.2 0.7 J5 21
UGV1E221MP26311U 价格&库存
很抱歉,暂时无法提供与“UGV1E221MP26311U”相匹配的价格&库存,您可以联系我们找货
