CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS
CAPACITOR Aluminum Solid Capacitor
UPE
Series
Super low ESR at a high frequency range
High ripple current capability
5,000 hours at 105°C
SPECIFICATIONS
Item
Performance Characteristics
Category Temperature Range
-55 ~ +105℃
Working Voltage Range
2.5 ~ 35Vdc
Surge Voltage
Rated Voltage x1.15
Capacitance Tolerance
M: ±20%
ESR
(at 25℃ and 120Hz)
See the standard ratings table (at 25℃, 100~300KHz)
Dissipation Factor (Tanδ)
See the standard ratings table (at 25℃, 120Hz)
Leakage Current ※1
See the standard ratings table (Impress the rated voltage for 2 minutes)
Low Temperature Characteristics
Impedance Ratio
Z(-25℃)/Z(+25℃) ≤1.15 at 100KHz
Z(-55℃)/Z(+25℃) ≤1.25 at 100KHz
The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage
with the rated ripple current is applied for 5,000 hours at 105°C
Endurance
Capacitance change
≦ ±20% of the initial value
ESR
≦ 150% of the specified value
Dissipation factor(tanδ)
Leakage current
≦ specified value
The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000
hours at 60℃ 90 to 95% RH
Damp Heat
(Steady State)
Capacitance change
ESR
Leakage current
≦ specified value
※1 In case of some problems for measured values, measure after applying rated voltage for 120 minutes at105°C
※2 ESR should be measured at both of the terminal ends closest to the capacitor body
◆DIMENSIONS (mm)
PART NUMBER SYSTEM
◆Lead
◆Marking
6.3
10
ФD
5
8
Фd
0.45
0.45
0.6
0.6
0.6
0.6
0.6
L
8
5~6
8
11
6~8
11~12
7~13
α
1
1
1
1.5
1
1.5
1.5
F
2.0
2.5
2.5
2.5
3.5
3.5
5.0
≦6.3Ф
≧8Ф
UPE
Series
Standard Ratings
Rated
Voltage
(Vdc)
2.5(0E)
4(0G)
6.3(0J)
10(1A)
16(1C)
Rated
Capacitance
(μF)
Case Size
ФD×L
(mm)
ESR
100~300KHz
(mΩ max)
Rated Ripple Current
105℃,100KHz
(mArms max)
Tan δ
max
Leakage
Current
(μA max)
390
6.3×5
10
3900
0.10
500
UPE0E391MNN6305
470
6.3×8
5
5900
0.10
500
UPE0E471MNN6308
Part Number
560
5×8
7
4200
0.10
500
UPE0E561MNN0508
560
6.3×5
10
3900
0.10
500
UPE0E561MNN6305
560
6.3×8
7
5000
0.10
500
UPE0E561MNN6308
560
8×8
8
4700
0.10
500
UPE0E561MNN0808U
820
6.3×8
7
5000
0.10
500
UPE0E821MNN6308(U)
820
8×8
7
6100
0.10
500
UPE0E821MNN0808U
1000
8×8
7
6100
0.10
900
UPE0E102MNN0808U
560
6.3×8
7
5000
0.10
500
UPE0G561MNN6308(U)
560
8×8
7
6100
0.10
500
UPE0G561MNN0808U
100
6.3×6
35
2100
0.10
500
UPE0J101MNN6306
100
6.3×8
35
2100
0.10
500
UPE0J101MNN6308
330
5×8
8
4050
0.10
500
UPE0J331MNN0508
470
6.3×8
8
4700
0.10
592
UPE0J471MNN6308(U)
560
6.3×8
8
4700
0.10
706
UPE0J561MNN6308
560
8×8
7
6100,
0.10
706
UPE0J561MNN0808U
820
6.3×8
8
4700
0.10
1033
UPE0J821MNN6308
820
8×8
8
6100
0.10
1033
UPE0J821MNN0808U
1500
8×11
9
5650
0.10
1890
UPE0J152MNN0811U
1500
10×12
10
5560
0.15
1890
UPE0J152MNN1012U
220
10×7
19
3800
0.10
500
UPE1A221MNN1007U
470
6.3×11
10
4700
0.10
940
UPE1A471MNN6311U
100
6.3×5
24
2400
0.10
500
UPE1C101MNN6305
100
6.3×8
24
2490
0.10
500
UPE1C101MNN6308
100
6.3×8
12
4680
0.12
500
UPE1C101MNN6308ER
180
6.3×5
22
3300
0.10
576
UPE1C181MNN6305
180
8×8
10
5000
0.10
576
UPE1C181MNN0808U
180
8×11
16
4360
0.10
576
UPE1C181MNN0811U
220
8×6
13
4150
0.10
500
UPE1C221MNN0806
270
6.3×8
15
3800
0.10
864
UPE1C271MNN6308
270
6.3×8
10
5080
0.10
864
UPE1C271MNN6308EU
270
6.3×8
10
5080
0.10
864
UPE1C271MNN6308R
270
8×8
10
5000
0.10
864
UPE1C271MNN0808U
270
8×11
11
5000
0.10
864
UPE1C271MNN0811U
270
8×11
10
5230
0.10
864
UPE1C271MNN0811ERU
330
8×8
11
4700
0.10
1056
UPE1C331MNN0808U
470
8×8
16
4000
0.10
1504
UPE1C471MNN0808U
470
8×11
11
5400
0.10
1504
UPE1C471MNN0811U
470
8×11
10
5400
0.10
1504
UPE1C471MNN0811RU
470
10×10
10
6100
0.10
1504
UPE1C471MNN1010U
Rated
Voltage
(Vdc)
16(1C)
20(1D)
25(1E)
35(1V)
Rated
Capacitance
(μF)
Case Size
ФD×L
(mm)
ESR
100~300KHz
(mΩ max)
105℃,100KHz
(mArms max)
Tan δ
max
Leakage
Current
(μA max)
470
10×12
10
6100
0.10
1504
UPE1C471MNN1012U
560
8×11
14
4970
0.10
1792
UPE1C561MNN0811U
680
8×11
12
5400
0.10
2176
UPE1C681MNN0811RU
Part Number
820
10×12
12
5400
0.10
2624
UPE1C821MNN1012U
1000
10×12
12
5400
0.10
3200
UPE1C102MNN1012U
390
8×11
14
4970
0.10
1560
UPE1D391MNN0811U
470
8×11
14
4970
0.10
1880
UPE1D471KNN0811U
560
10×12
12
5400
0.10
2240
UPE1D561MNN1012U
680
10×12
12
5400
0.10
2720
UPE1D681MNN1012U
56
6.3×5
30
2800
0.10
300
UPE1E560MNN6305
82
6.3×8
30
2800
0.10
500
UPE1E820MNN6308
82
8×8
28
3000
0.10
410
UPE1E820MNN0808U
100
10×7
21
3400
0.10
500
UPE1E101MNN1007U
180
8×11
16
4650
0.10
900
UPE1E181MNN0811U
220
8×11
16
4650
0.10
1100
UPE1E221MNN0811U
270
8×11
0.10
1350
UPE1E271MNN0811U
330
10×12
14
5000
0.10
1650
UPE1E331MNN1012U
390
10×12
14
5000
0.10
1950
UPE1E391MNN1012U
470
8×11
16
5500
0.12
2350
UPE1E471MNN0811RU
470
8×12
16
5000
0.10
2350
UPE1E471MNN0812RS
470
8×12
16
5000
0.10
2350
UPE1E471MNN0812RSU
470
10×10
30
5000
0.10
2350
UPE1E471MNN1010SU
560
10×12
14
5000
0.10
2800
UPE1E561MNN1012RU
680
10×12
12
5400
0.10
3400
UPE1E681MNN1012RU
820
10×12
0.10
4100
UPE1E821MNN1012U
22
6.3×5
35
2600
0.10
300
UPE1V220MNN6305
33
8×8
30
2800
0.10
300
UPE1V330MNN0808U
47
6.3×8
45
2000
0.10
329
UPE1V470MNN6308
82
8×11
0.10
574
UPE1V820MNN0811U
100
8×11
25
2890
0.1
700
UPE1V101MNN0811U
120
10×12
18
4400
0.10
840
UPE1V121MNN1012U
PA RT N U M B E R S Y S T E M
RADIAL LEAD TYPE
Series
Rated Voltage
Capacitance
Tolerance
Lead Forming Type
Lead Length
Case Dimension
Special Request
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
(1) Series
Series
DIP
UPS
UPR
UUL
UPE
SMD
VSG
VSP
VSU
VSE
URP
URH
UGP
UGS
UGV
UPC
(2) Rated Voltage
Code
0E
0J
6K
7H
1A
1B
AG
1C
1D
1P
1E
1F
1V
1H
1J
2A
WV
2.5
6.3
6.8
7.5
10
12
14
16
25
30
35
50
63
100
(3) Capacitance
Code
6R8
μF
6.8
100
10
180
560
101
181
561
102
182
18
56
100
180
560
1000
1800
(4) Capacitance Tolerance
Code
J
Q
R
K
V
M
H
±5
+30 / -10
+20 / -0
± 10
+20 / -10
± 20
+20 / -5
(5) Lead Type
Code
C
P
Description
Cutting
Taping
Drawing
Fig 1
Fig 2
(6) Lead Length (Cut / Formed lead)
Code
3
4
U
7
D
X
R
B
E
G
2
M
T
N
Length
3.5
4.5
5.5
7
4
2.3
2.5
2.8
3.1
3.3
2.5
3.5
3.8
+20mm min
Tolerance
±0.5
±0.2
±0.3
-15mm min
Taping Code
Code
Z
2
3
7
5
S
Lead Pitch:+0.8/-0.2
2.0
2.5
3.5
3.5
5.0
5.0
(7) Case Dimension
DIP Code
0508
6305
6308
6311
0807
0808
0811
0816
0820
1012
1016
1020
10×16
10×20
Size
5×8
6.3×5
6.3×8
6.3×11
8×7
8×8
8×11
8×16
8×20
10×12
SMD Code
5057
6343
6357
6377
6309
0867
0897
08C7
1077
10C4
Size
5×5.7
6.3×4.3
6.3×5.7
6.3×7.7
6.3×9
8×6.7
8×9.7
8×12.7
10×7.7
10×12.4
(8) Special Request
Code
R
F
L
D
Description
High Rated ripple current
Endurance
Low Leakage Current
Low Dissipation Factor
Code
U
E
Description
Convex Rubber
Low ESR
MARKING AND DATE CODE
Trade Mark "CS"
Chinsan Solid Capacitor, Show on Dimension ≧8 Ф
Code (Date Code)
(1)DAY
(1)
(2)
(3)
Code
1
2
3
4
5
1
1
Week
The first week
The second week
The third week
The fourth week
The fifth week
(2)Month
Code
1
2
3
4
5
6
Month
Jan
Feb
Mar
Apr
May
Jun
Code
7
8
9
X
Y
Z
Month
July
Aug
Sep
Oct
Nov
Dec
Code
9
2
3
4
Year
2019
2020
2021
2022
2023
2024
(3)Year
Series (Print Code)
Series
UPS UPR UUL UPE URP URH UGP UGV UGS
Ф 5~ Ф 6.3
R
L
E
Ф 8~ Ф 10
UPS
UL
UPE RP
H
P
V
RH
GP
GV
GS
UPC VSG VSP
C
G
UPC SG
VSU VSE
P
U
E
SP
SU
SE
LEAD FORMING TYPE
Dimensions (Unit: mm)
Part
Number
ΦD
F
ι
3
4
U
7
D
X
R
B
E
G
2
M
T
3.5
4.5
5.5
7
4
2.3
2.5
2.8
3.1
3.3
2.5
3.5
3.8
Cut
2
6.3
2.5
8
3.5
10
5
±0.2
±0.3
D
±0.5
5
(Part number for lead length and pitch for taping)
F
Type
L
C
L
TAPING
Figure 1
Ф8
Фd
±0.05
0.45
0.45/0.6
0.6
P
±0.1
12.7
12.7
12.7
P0
±0.2
12.7
12.7
12.7
P1
±0.5
3.85
3.85
3.85
P2
±1.0
6.35
6.35
6.35
5
5
5
PS
P5
0.8
-0.2
H
±0.5
H0
±0.5
17.5
18.5
PS
P5
17.5
16
18.5
PS
P5
17.5
16
18.5
16
W
±0.5
18
18
18
W0
Minimum
12.5
12.5
12.5
D0
±0.2
4
4
4
t
±0.2
0.7
0.7
0.7
Symbol
Tolerance
Фd
±0.05
0.45/0.6
0.6
0.6
P
±0.1
12.7
12.7
12.7
P0
±0.2
12.7
12.7
12.7
P1
±0.5
5.1
4.6
3.85
P2
±1.0
6.35
6.35
6.35
2.5
3.5
5
F
Figure 3
Ф 6.3
Tolerance
F
Figure 2
Ф5
Symbol
+0.8
-0.2
Ф 6.3
P2
H
±0.5
118.5
H0
±0.5
Ф8
P3
18.5
H3
Ф 10
P7
17.5
P5
18.5
H5
W
±0.5
18
18
18
W0
Minimum
12.5
12.5
12.5
D0
±0.2
4
4
4
t
±0.2
0.7
0.7
0.7
Symbol
Tolerance
Фd
±0.05
0.45
P
±0.1
12.7
P0
±0.2
12.7
P1
±0.5
5.35
P2
±1.0
6.35
F
+0.8
-0.2
Ф5
PZ
2.0
H
±0.5
18.5
H0
±0.5
W
±0.5
18
W0
Minimum
12.5
D0
±0.2
4
t
±0.2
0.7
J5
21
很抱歉,暂时无法提供与“UPE0E561MCG6305”相匹配的价格&库存,您可以联系我们找货
