UPE0E821MCG6308
UPE0E821MCG6308
    CHINSAN(金山)
    插件
    820 µF 2.5 V 铝聚合物电容器 径向,Can 7 毫欧 105°C 时为 5000 小时
UPE0E821MCG6308 数据手册
CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor UPE Series  Super low ESR at a high frequency range  High ripple current capability  5,000 hours at 105°C  SPECIFICATIONS Item Performance Characteristics Category Temperature Range -55 ~ +105℃ Working Voltage Range 2.5 ~ 35Vdc Surge Voltage Rated Voltage x1.15 Capacitance Tolerance M: ±20% ESR (at 25℃ and 120Hz) See the standard ratings table (at 25℃, 100~300KHz) Dissipation Factor (Tanδ) See the standard ratings table (at 25℃, 120Hz) Leakage Current ※1 See the standard ratings table (Impress the rated voltage for 2 minutes) Low Temperature Characteristics Impedance Ratio Z(-25℃)/Z(+25℃) ≤1.15 at 100KHz Z(-55℃)/Z(+25℃) ≤1.25 at 100KHz The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 5,000 hours at 105°C Endurance Capacitance change ≦ ±20% of the initial value ESR ≦ 150% of the specified value Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 60℃ 90 to 95% RH Damp Heat (Steady State) Capacitance change ≦ ±20% of the initial value ESR ≦ 150% of the specified value Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦ specified value ※1 In case of some problems for measured values, measure after applying rated voltage for 120 minutes at105°C ※2 ESR should be measured at both of the terminal ends closest to the capacitor body ◆DIMENSIONS (mm)  PART NUMBER SYSTEM ◆Lead ◆Marking 6.3 10 ФD 5 8 Фd 0.45 0.45 0.6 0.6 0.6 0.6 0.6 L 8 5~6 8 11 6~8 11~12 7~13 α 1 1 1 1.5 1 1.5 1.5 F 2.0 2.5 2.5 2.5 3.5 3.5 5.0 ≦6.3Ф ≧8Ф CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor UPE ◆ Series Standard Ratings Rated Voltage (Vdc) 2.5(0E) 4(0G) 6.3(0J) 10(1A) 16(1C) Rated Capacitance (μF) Case Size ФD×L (mm) ESR 100~300KHz (mΩ max) Rated Ripple Current 105℃,100KHz (mArms max) Tan δ max Leakage Current (μA max) 390 6.3×5 10 3900 0.10 500 UPE0E391MNN6305 470 6.3×8 5 5900 0.10 500 UPE0E471MNN6308 Part Number 560 5×8 7 4200 0.10 500 UPE0E561MNN0508 560 6.3×5 10 3900 0.10 500 UPE0E561MNN6305 560 6.3×8 7 5000 0.10 500 UPE0E561MNN6308 560 8×8 8 4700 0.10 500 UPE0E561MNN0808U 820 6.3×8 7 5000 0.10 500 UPE0E821MNN6308(U) 820 8×8 7 6100 0.10 500 UPE0E821MNN0808U 1000 8×8 7 6100 0.10 900 UPE0E102MNN0808U 560 6.3×8 7 5000 0.10 500 UPE0G561MNN6308(U) 560 8×8 7 6100 0.10 500 UPE0G561MNN0808U 100 6.3×6 35 2100 0.10 500 UPE0J101MNN6306 100 6.3×8 35 2100 0.10 500 UPE0J101MNN6308 330 5×8 8 4050 0.10 500 UPE0J331MNN0508 470 6.3×8 8 4700 0.10 592 UPE0J471MNN6308(U) 560 6.3×8 8 4700 0.10 706 UPE0J561MNN6308 560 8×8 7 6100, 0.10 706 UPE0J561MNN0808U 820 6.3×8 8 4700 0.10 1033 UPE0J821MNN6308 820 8×8 8 6100 0.10 1033 UPE0J821MNN0808U 1500 8×11 9 5650 0.10 1890 UPE0J152MNN0811U 1500 10×12 10 5560 0.15 1890 UPE0J152MNN1012U 220 10×7 19 3800 0.10 500 UPE1A221MNN1007U 470 6.3×11 10 4700 0.10 940 UPE1A471MNN6311U 100 6.3×5 24 2400 0.10 500 UPE1C101MNN6305 100 6.3×8 24 2490 0.10 500 UPE1C101MNN6308 100 6.3×8 12 4680 0.12 500 UPE1C101MNN6308ER 180 6.3×5 22 3300 0.10 576 UPE1C181MNN6305 180 8×8 10 5000 0.10 576 UPE1C181MNN0808U 180 8×11 16 4360 0.10 576 UPE1C181MNN0811U 220 8×6 13 4150 0.10 500 UPE1C221MNN0806 270 6.3×8 15 3800 0.10 864 UPE1C271MNN6308 270 6.3×8 10 5080 0.10 864 UPE1C271MNN6308EU 270 6.3×8 10 5080 0.10 864 UPE1C271MNN6308R 270 8×8 10 5000 0.10 864 UPE1C271MNN0808U 270 8×11 11 5000 0.10 864 UPE1C271MNN0811U 270 8×11 10 5230 0.10 864 UPE1C271MNN0811ERU 330 8×8 11 4700 0.10 1056 UPE1C331MNN0808U 470 8×8 16 4000 0.10 1504 UPE1C471MNN0808U 470 8×11 11 5400 0.10 1504 UPE1C471MNN0811U 470 8×11 10 5400 0.10 1504 UPE1C471MNN0811RU 470 10×10 10 6100 0.10 1504 UPE1C471MNN1010U CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor Rated Voltage (Vdc) 16(1C) 20(1D) 25(1E) 35(1V) Rated Capacitance (μF) Case Size ФD×L (mm) ESR 100~300KHz (mΩ max) Rated Ripple Current 105℃,100KHz (mArms max) Tan δ max Leakage Current (μA max) 470 10×12 10 6100 0.10 1504 UPE1C471MNN1012U 560 8×11 14 4970 0.10 1792 UPE1C561MNN0811U 680 8×11 12 5400 0.10 2176 UPE1C681MNN0811RU Part Number 820 10×12 12 5400 0.10 2624 UPE1C821MNN1012U 1000 10×12 12 5400 0.10 3200 UPE1C102MNN1012U 390 8×11 14 4970 0.10 1560 UPE1D391MNN0811U 470 8×11 14 4970 0.10 1880 UPE1D471KNN0811U 560 10×12 12 5400 0.10 2240 UPE1D561MNN1012U 680 10×12 12 5400 0.10 2720 UPE1D681MNN1012U 56 6.3×5 30 2800 0.10 300 UPE1E560MNN6305 82 6.3×8 30 2800 0.10 500 UPE1E820MNN6308 82 8×8 28 3000 0.10 410 UPE1E820MNN0808U 100 10×7 21 3400 0.10 500 UPE1E101MNN1007U 180 8×11 16 4650 0.10 900 UPE1E181MNN0811U 220 8×11 16 4650 0.10 1100 UPE1E221MNN0811U 270 8×11 20 4000 0.10 1350 UPE1E271MNN0811U 330 10×12 14 5000 0.10 1650 UPE1E331MNN1012U 390 10×12 14 5000 0.10 1950 UPE1E391MNN1012U 470 8×11 16 5500 0.12 2350 UPE1E471MNN0811RU 470 8×12 16 5000 0.10 2350 UPE1E471MNN0812RS 470 8×12 16 5000 0.10 2350 UPE1E471MNN0812RSU 470 10×10 30 5000 0.10 2350 UPE1E471MNN1010SU 560 10×12 14 5000 0.10 2800 UPE1E561MNN1012RU 680 10×12 12 5400 0.10 3400 UPE1E681MNN1012RU 820 10×12 20 3400 0.10 4100 UPE1E821MNN1012U 22 6.3×5 35 2600 0.10 300 UPE1V220MNN6305 33 8×8 30 2800 0.10 300 UPE1V330MNN0808U 47 6.3×8 45 2000 0.10 329 UPE1V470MNN6308 82 8×11 20 4000 0.10 574 UPE1V820MNN0811U 100 8×11 25 2890 0.1 700 UPE1V101MNN0811U 120 10×12 18 4400 0.10 840 UPE1V121MNN1012U CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor PA RT N U M B E R S Y S T E M  RADIAL LEAD TYPE Series Rated Voltage Capacitance Tolerance Lead Forming Type Lead Length Case Dimension Special Request (1) (2) (3) (4) (5) (6) (7) (8) (1) Series Series DIP UPS UPR UUL UPE SMD VSG VSP VSU VSE URP URH UGP UGS UGV UPC (2) Rated Voltage Code 0E 0J 6K 7H 1A 1B AG 1C 1D 1P 1E 1F 1V 1H 1J 2A WV 2.5 6.3 6.8 7.5 10 12 14 16 20 22 25 30 35 50 63 100 (3) Capacitance Code 6R8 μF 6.8 100 10 180 560 101 181 561 102 182 18 56 100 180 560 1000 1800 (4) Capacitance Tolerance Code J Q R K V M H % ±5 +30 / -10 +20 / -0 ± 10 +20 / -10 ± 20 +20 / -5 (5) Lead Type Code C P Description Cutting Taping Drawing Fig 1 Fig 2 (6) Lead Length (Cut / Formed lead) Code 3 4 U 7 D X R B E G 2 M T N Length 3.5 4.5 5.5 7 4 2.3 2.5 2.8 3.1 3.3 2.5 3.5 3.8 +20mm min Tolerance ±0.5 ±0.2 ±0.3 -15mm min Taping Code Code Z 2 3 7 5 S Lead Pitch:+0.8/-0.2 2.0 2.5 3.5 3.5 5.0 5.0 (7) Case Dimension DIP Code 0508 6305 6308 6311 0807 0808 0811 0816 0820 1012 1016 1020 10×16 10×20 Size 5×8 6.3×5 6.3×8 6.3×11 8×7 8×8 8×11 8×16 8×20 10×12 SMD Code 5057 6343 6357 6377 6309 0867 0897 08C7 1077 10C4 Size 5×5.7 6.3×4.3 6.3×5.7 6.3×7.7 6.3×9 8×6.7 8×9.7 8×12.7 10×7.7 10×12.4 (8) Special Request Code R F L D Description High Rated ripple current Endurance Low Leakage Current Low Dissipation Factor Code U E --- --- Description Convex Rubber Low ESR --- --- CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor  MARKING AND DATE CODE Trade Mark "CS" Chinsan Solid Capacitor, Show on Dimension ≧8 Ф Code (Date Code) (1)DAY (1) (2) (3) Code 1 2 3 4 5 1 1 0 Week The first week The second week The third week The fourth week The fifth week (2)Month Code 1 2 3 4 5 6 Month Jan Feb Mar Apr May Jun Code 7 8 9 X Y Z Month July Aug Sep Oct Nov Dec Code 9 0 1 2 3 4 Year 2019 2020 2021 2022 2023 2024 (3)Year Series (Print Code) Series UPS UPR UUL UPE URP URH UGP UGV UGS Ф 5~ Ф 6.3 -- R L E Ф 8~ Ф 10 UPS -- UL UPE RP -- H P V -- RH GP GV GS UPC VSG VSP C G UPC SG VSU VSE P U E SP SU SE  LEAD FORMING TYPE Dimensions (Unit: mm) Part Number ΦD F ι 3 4 U 7 D X R B E G 2 M T 3.5 4.5 5.5 7 4 2.3 2.5 2.8 3.1 3.3 2.5 3.5 3.8 Cut 2 ---- 6.3 2.5 ---- 8 3.5 ---- 10 5 ---- ±0.2 ±0.3 D ±0.5 5 (Part number for lead length and pitch for taping) F Type L C L CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor  TAPING Figure 1 Ф8 Фd ±0.05 0.45 0.45/0.6 0.6 P ±0.1 12.7 12.7 12.7 P0 ±0.2 12.7 12.7 12.7 P1 ±0.5 3.85 3.85 3.85 P2 ±1.0 6.35 6.35 6.35 5 5 5 PS P5 0.8 -0.2 H ±0.5 H0 ±0.5 17.5 18.5 PS P5 17.5 16 18.5 PS P5 17.5 16 18.5 16 W ±0.5 18 18 18 W0 Minimum 12.5 12.5 12.5 D0 ±0.2 4 4 4 t ±0.2 0.7 0.7 0.7 Symbol Tolerance Фd ±0.05 0.45/0.6 0.6 0.6 P ±0.1 12.7 12.7 12.7 P0 ±0.2 12.7 12.7 12.7 P1 ±0.5 5.1 4.6 3.85 P2 ±1.0 6.35 6.35 6.35 2.5 3.5 5 F Figure 3 Ф 6.3 Tolerance F Figure 2 Ф5 Symbol +0.8 -0.2 Ф 6.3 P2 H ±0.5 118.5 H0 ±0.5 - Ф8 P3 18.5 H3 20 - Ф 10 P7 17.5 P5 18.5 H5 20 - W ±0.5 18 18 18 W0 Minimum 12.5 12.5 12.5 D0 ±0.2 4 4 4 t ±0.2 0.7 0.7 0.7 Symbol Tolerance Фd ±0.05 0.45 P ±0.1 12.7 P0 ±0.2 12.7 P1 ±0.5 5.35 P2 ±1.0 6.35 F +0.8 -0.2 Ф5 PZ 2.0 H ±0.5 18.5 H0 ±0.5 - W ±0.5 18 W0 Minimum 12.5 D0 ±0.2 4 t ±0.2 0.7 J5 21
UPE0E821MCG6308
1. 物料型号:文档列出了多种额定电压和电容值的型号,例如UPE0E471MNN6308、UPE1A471MNN6311U等。
2. 器件简介:UPE系列电容器具有超低的高频ESR(等效串联电阻)和高纹波电流承受能力,并且能在105°C下持续5000小时。
3. 引脚分配:提供了引脚长度代码和成型类型代码,以及尺寸信息。
4. 参数特性:详细列出了电容器的工作电压范围、电容公差、ESR、损耗因子(Tan δ)、漏电流等参数。
5. 功能详解:介绍了电容器在不同温度下的特性,包括低温特性阻抗比、耐久性测试、电容变化、ESR、损耗因子和漏电流等。
6. 应用信息:虽未明确列出,但从电容器的特性来看,适用于高要求的电源滤波和电源管理应用。
7. 封装信息:提供了电容器的尺寸代码和封装类型,如径向引线类型和SMD(表面贴装)类型。
8. 特殊请求:可以针对高额定纹波电流、耐久性、低漏电流和低损耗因子等进行特殊定制。
9. 标记和日期代码:说明了如何识别电容器的品牌、系列代码、额定电容、额定电压和生产日期。
10. 包装数量:提供了不同尺寸电容器的内盒和外箱包装数量。
UPE0E821MCG6308 价格&库存
很抱歉,暂时无法提供与“UPE0E821MCG6308”相匹配的价格&库存,您可以联系我们找货
