CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS
CAPACITOR Aluminum Solid Capacitor
UPR
Series
Super low ESR at a high frequency range
High ripple current capability
2,000 hours at 105℃
SPECIFICATIONS
Item
Performance Characteristics
Category Temperature Range
-55 ~ +105℃
Working Voltage Range
2.5 ~ 16Vdc
Surge Voltage
Rated Voltage x1.15
Capacitance Tolerance
M: ±20%
(at 25℃ and 120Hz)
ESR
See the standard ratings table (at 25℃, 100~300KHz)
Dissipation Factor (Tanδ)
See the standard ratings table (at 25℃, 120Hz)
Leakage Current ※1
See the standard ratings table (Impress the rated voltage for 2 minutes)
Low Temperature Characteristics
Impedance Ratio
Z(-25℃)/Z(+25℃) ≤1.15 at 100KHz
Z(-55℃)/Z(+25℃) ≤1.25 at 100KHz
The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage
with the rated ripple current is applied for 2,000 hours at 105°C
Endurance
Capacitance change
≦ ±20% of the initial value
ESR
≦ 150% of the specified value
Dissipation factor(tanδ)
Leakage current
≦ specified value
The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000
hours at 60℃ 90 to 95% RH
Damp Heat
(Steady State)
Capacitance change
ESR
Leakage current
≦ specified value
※1 In case of some problems for measured values, measure after applying rated voltage for 120 minutes at105°C
※2 ESR should be measured at both of the terminal ends closest to the capacitor body
◆ DIMENSIONS (mm)
PART NUMBER SYSTEM
◆ Lead
◆ Marking
ФD
5
6.3
8
Фd
0.45
0.45
0.6
0.6
0.6
L
8
5
8
12~13
6
α
1
1
1
1.5
1
F
2
2.5
2.5
2.5
3.5
UPR
Series
Standard Ratings
Rated
Voltage
(Vdc)
2.5(0E)
4(0G)
6.3(0J)
10(1A)
16(1C)
Rated
Capacitance
(μF)
Case Size
ΦD×L
(mm)
ESR
100~300KHz
(mΩmax)
Rated Ripple Current
105℃,100KHz
(mArms max)
Tanδ
max
Leakage
Current
(μA max)
220
5×8
8
4340
0.10
500
UPR0E221MNN0508
330
5×8
8
4340
0.10
500
UPR0E331MNN0508
560
5×8
8
4340
0.10
500
UPR0E561MNN0508
560
6.3×8
8
4700
0.10
500
UPR0E561MNN6308
680
6.3×8
8
4900
0.10
500
UPR0E681MNN6308
820
6.3×8
8
5000
0.10
513
UPR0E821MNN6308
820
6.3×8
5
5900
0.10
513
UPR0E821MNN6308E
820
6.3×8
6
5000
0.1
513
UPR0E821MNN6308E6
560
6.3×8
8
4700
0.10
560
UPR0G561MNN6308
560
6.3×8
7
5600
0.1
560
UPR0G561MNN6308RU
220
5×8
11
3200
0.10
300
UPR0J221MNN0508
220
6.3×8
9
3900
0.10
500
UPR0J221MNN6308
270
5×8
8
4050
0.10
500
UPR0J271MNN0508
270
6.3×8
8
4180
0.10
500
UPR0J271MNN6308
330
5×8
8
4050
0.10
500
UPR0J331MNN0508
330
5×8
15
3390
0.1
500
UPR0J331MNN0508E
330
6.3×8
8
4700
0.10
500
UPR0J331MNN6308
390
6.3×8
8
4700
0.10
530
UPR0J391MNN6308
470
6.3×8
8
4700
0.10
592
UPR0J471MNN6308(U)
470
6.3×8
7
5600
0.10
592
UPR0J471MNN6308R
560
5×8
7
4180
0.10
500
UPR0J561MNN0508
560
6.3×8
8
4700
0.10
706
UPR0J561MNN6308
560
6.3×8
7
5600
0.10
706
UPR0J561MNN6308E
680
6.3×8
8
4700
0.10
856
UPR0J681MNN6308
820
6.3×8
8
4700
0.10
1033
UPR0J821MNN6308
1000
6.3×12
8
6100
0.10
1260
UPR0J102MNN6312
Part Number
100
5×8
35
2200
0.10
300
UPR1A101MNN0508
150
6.3×8
24
2820
0.10
480
UPR1A151MNN6308
220
6.3×8
8
4700
0.10
550
UPR1A221MNN6308
270
6.3×8
8
4700
0.10
540
UPR1A271MNN6308
330
6.3×8
8
4700
0.10
660
UPR1A331MNN6308
39
6.3×5
50
1620
0.12
312
UPR1C390MNN6305
100
6.3×5
24
2490
0.10
320
UPR1C101MNN6305
100
6.3×8
10
4680
0.10
320
UPR1C101MNN6308
220
6.3×8
10
4700
0.12
704
UPR1C221MNN6308U
220
8×6
12
4150
0.12
704
UPR1C221MNN0806
270
6.3×8
10
5080
0.10
864
UPR1C271MNN6308
330
6.3×12
10
5000
0.10
1056
UPR1C331MNN6312
470
6.3×12
11
5300
0.12
200
UPR1C471MNN6312L
470
6.3×13
11
5300
0.12
1504
UPR1C471MNN6313SU
PA RT N U M B E R S Y S T E M
RADIAL LEAD TYPE
Series
Rated Voltage
Capacitance
Tolerance
Lead Forming Type
Lead Length
Case Dimension
Special Request
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
(1) Series
Series
DIP
UPS
UPR
UUL
UPE
SMD
VSG
VSP
VSU
VSE
URP
URH
UGP
UGS
UGV
UPC
(2) Rated Voltage
Code
0E
0J
6K
7H
1A
1B
AG
1C
1D
1P
1E
1F
1V
1H
1J
2A
WV
2.5
6.3
6.8
7.5
10
12
14
16
25
30
35
50
63
100
(3) Capacitance
Code
6R8
μF
6.8
100
10
180
560
101
181
561
102
182
18
56
100
180
560
1000
1800
(4) Capacitance Tolerance
Code
J
Q
R
K
V
M
H
±5
+30 / -10
+20 / -0
± 10
+20 / -10
± 20
+20 / -5
(5) Lead Type
Code
C
P
Description
Cutting
Taping
Drawing
Fig 1
Fig 2
(6) Lead Length (Cut / Formed lead)
Code
3
4
U
7
D
X
R
B
E
G
2
M
T
N
Length
3.5
4.5
5.5
7
4
2.3
2.5
2.8
3.1
3.3
2.5
3.5
3.8
+20mm min
Tolerance
±0.5
±0.2
±0.3
-15mm min
Taping Code
Code
Z
2
3
7
5
S
Lead Pitch:+0.8/-0.2
2.0
2.5
3.5
3.5
5.0
5.0
(7) Case Dimension
DIP Code
0508
6305
6308
6311
0807
0808
0811
0816
0820
1012
1016
1020
10×16
10×20
Size
5×8
6.3×5
6.3×8
6.3×11
8×7
8×8
8×11
8×16
8×20
10×12
SMD Code
5057
6343
6357
6377
6309
0867
0897
08C7
1077
10C4
Size
5×5.7
6.3×4.3
6.3×5.7
6.3×7.7
6.3×9
8×6.7
8×9.7
8×12.7
10×7.7
10×12.4
(8) Special Request
Code
R
F
L
D
Description
High Rated ripple current
Endurance
Low Leakage Current
Low Dissipation Factor
Code
U
E
Description
Convex Rubber
Low ESR
MARKING AND DATE CODE
Trade Mark "CS"
Chinsan Solid Capacitor, Show on Dimension ≧8 Ф
Code (Date Code)
(1)DAY
(1)
(2)
(3)
Code
1
2
3
4
5
1
1
Week
The first week
The second week
The third week
The fourth week
The fifth week
(2)Month
Code
1
2
3
4
5
6
Month
Jan
Feb
Mar
Apr
May
Jun
Code
7
8
9
X
Y
Z
Month
July
Aug
Sep
Oct
Nov
Dec
Code
9
2
3
4
Year
2019
2020
2021
2022
2023
2024
(3)Year
Series (Print Code)
Series
UPS UPR UUL UPE URP URH UGP UGV UGS
Ф 5~ Ф 6.3
R
L
E
Ф 8~ Ф 10
UPS
UL
UPE RP
H
P
V
RH
GP
GV
GS
UPC VSG VSP
C
G
UPC SG
VSU VSE
P
U
E
SP
SU
SE
LEAD FORMING TYPE
Dimensions (Unit: mm)
Part
Number
ΦD
F
ι
3
4
U
7
D
X
R
B
E
G
2
M
T
3.5
4.5
5.5
7
4
2.3
2.5
2.8
3.1
3.3
2.5
3.5
3.8
Cut
2
6.3
2.5
8
3.5
10
5
±0.2
±0.3
D
±0.5
5
(Part number for lead length and pitch for taping)
F
Type
L
C
L
TAPING
Figure 1
Ф8
Фd
±0.05
0.45
0.45/0.6
0.6
P
±0.1
12.7
12.7
12.7
P0
±0.2
12.7
12.7
12.7
P1
±0.5
3.85
3.85
3.85
P2
±1.0
6.35
6.35
6.35
5
5
5
PS
P5
0.8
-0.2
H
±0.5
H0
±0.5
17.5
18.5
PS
P5
17.5
16
18.5
PS
P5
17.5
16
18.5
16
W
±0.5
18
18
18
W0
Minimum
12.5
12.5
12.5
D0
±0.2
4
4
4
t
±0.2
0.7
0.7
0.7
Symbol
Tolerance
Фd
±0.05
0.45/0.6
0.6
0.6
P
±0.1
12.7
12.7
12.7
P0
±0.2
12.7
12.7
12.7
P1
±0.5
5.1
4.6
3.85
P2
±1.0
6.35
6.35
6.35
2.5
3.5
5
F
Figure 3
Ф 6.3
Tolerance
F
Figure 2
Ф5
Symbol
+0.8
-0.2
Ф 6.3
P2
H
±0.5
118.5
H0
±0.5
Ф8
P3
18.5
H3
Ф 10
P7
17.5
P5
18.5
H5
W
±0.5
18
18
18
W0
Minimum
12.5
12.5
12.5
D0
±0.2
4
4
4
t
±0.2
0.7
0.7
0.7
Symbol
Tolerance
Фd
±0.05
0.45
P
±0.1
12.7
P0
±0.2
12.7
P1
±0.5
5.35
P2
±1.0
6.35
F
+0.8
-0.2
Ф5
PZ
2.0
H
±0.5
18.5
H0
±0.5
W
±0.5
18
W0
Minimum
12.5
D0
±0.2
4
t
±0.2
0.7
J5
21
很抱歉,暂时无法提供与“UPR0J331MNN6308”相匹配的价格&库存,您可以联系我们找货
