UPR0E821MCE6308E6
UPR0E821MCE6308E6
    CHINSAN(金山)
    插件
    820 µF 2.5 V 铝聚合物电容器 径向,Can 6 毫欧 105°C 时为 2000 小时
UPR0E821MCE6308E6 数据手册
CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor UPR Series  Super low ESR at a high frequency range  High ripple current capability  2,000 hours at 105℃  SPECIFICATIONS Item Performance Characteristics Category Temperature Range -55 ~ +105℃ Working Voltage Range 2.5 ~ 16Vdc Surge Voltage Rated Voltage x1.15 Capacitance Tolerance M: ±20% (at 25℃ and 120Hz) ESR See the standard ratings table (at 25℃, 100~300KHz) Dissipation Factor (Tanδ) See the standard ratings table (at 25℃, 120Hz) Leakage Current ※1 See the standard ratings table (Impress the rated voltage for 2 minutes) Low Temperature Characteristics Impedance Ratio Z(-25℃)/Z(+25℃) ≤1.15 at 100KHz Z(-55℃)/Z(+25℃) ≤1.25 at 100KHz The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 2,000 hours at 105°C Endurance Capacitance change ≦ ±20% of the initial value ESR ≦ 150% of the specified value Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 60℃ 90 to 95% RH Damp Heat (Steady State) Capacitance change ≦ ±20% of the initial value ESR ≦ 150% of the specified value Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦ specified value ※1 In case of some problems for measured values, measure after applying rated voltage for 120 minutes at105°C ※2 ESR should be measured at both of the terminal ends closest to the capacitor body ◆ DIMENSIONS (mm)  PART NUMBER SYSTEM ◆ Lead ◆ Marking ФD 5 6.3 8 Фd 0.45 0.45 0.6 0.6 0.6 L 8 5 8 12~13 6 α 1 1 1 1.5 1 F 2 2.5 2.5 2.5 3.5 CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor UPR ◆ Series Standard Ratings Rated Voltage (Vdc) 2.5(0E) 4(0G) 6.3(0J) 10(1A) 16(1C) Rated Capacitance (μF) Case Size ΦD×L (mm) ESR 100~300KHz (mΩmax) Rated Ripple Current 105℃,100KHz (mArms max) Tanδ max Leakage Current (μA max) 220 5×8 8 4340 0.10 500 UPR0E221MNN0508 330 5×8 8 4340 0.10 500 UPR0E331MNN0508 560 5×8 8 4340 0.10 500 UPR0E561MNN0508 560 6.3×8 8 4700 0.10 500 UPR0E561MNN6308 680 6.3×8 8 4900 0.10 500 UPR0E681MNN6308 820 6.3×8 8 5000 0.10 513 UPR0E821MNN6308 820 6.3×8 5 5900 0.10 513 UPR0E821MNN6308E 820 6.3×8 6 5000 0.1 513 UPR0E821MNN6308E6 560 6.3×8 8 4700 0.10 560 UPR0G561MNN6308 560 6.3×8 7 5600 0.1 560 UPR0G561MNN6308RU 220 5×8 11 3200 0.10 300 UPR0J221MNN0508 220 6.3×8 9 3900 0.10 500 UPR0J221MNN6308 270 5×8 8 4050 0.10 500 UPR0J271MNN0508 270 6.3×8 8 4180 0.10 500 UPR0J271MNN6308 330 5×8 8 4050 0.10 500 UPR0J331MNN0508 330 5×8 15 3390 0.1 500 UPR0J331MNN0508E 330 6.3×8 8 4700 0.10 500 UPR0J331MNN6308 390 6.3×8 8 4700 0.10 530 UPR0J391MNN6308 470 6.3×8 8 4700 0.10 592 UPR0J471MNN6308(U) 470 6.3×8 7 5600 0.10 592 UPR0J471MNN6308R 560 5×8 7 4180 0.10 500 UPR0J561MNN0508 560 6.3×8 8 4700 0.10 706 UPR0J561MNN6308 560 6.3×8 7 5600 0.10 706 UPR0J561MNN6308E 680 6.3×8 8 4700 0.10 856 UPR0J681MNN6308 820 6.3×8 8 4700 0.10 1033 UPR0J821MNN6308 1000 6.3×12 8 6100 0.10 1260 UPR0J102MNN6312 Part Number 100 5×8 35 2200 0.10 300 UPR1A101MNN0508 150 6.3×8 24 2820 0.10 480 UPR1A151MNN6308 220 6.3×8 8 4700 0.10 550 UPR1A221MNN6308 270 6.3×8 8 4700 0.10 540 UPR1A271MNN6308 330 6.3×8 8 4700 0.10 660 UPR1A331MNN6308 39 6.3×5 50 1620 0.12 312 UPR1C390MNN6305 100 6.3×5 24 2490 0.10 320 UPR1C101MNN6305 100 6.3×8 10 4680 0.10 320 UPR1C101MNN6308 220 6.3×8 10 4700 0.12 704 UPR1C221MNN6308U 220 8×6 12 4150 0.12 704 UPR1C221MNN0806 270 6.3×8 10 5080 0.10 864 UPR1C271MNN6308 330 6.3×12 10 5000 0.10 1056 UPR1C331MNN6312 470 6.3×12 11 5300 0.12 200 UPR1C471MNN6312L 470 6.3×13 11 5300 0.12 1504 UPR1C471MNN6313SU CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor PA RT N U M B E R S Y S T E M  RADIAL LEAD TYPE Series Rated Voltage Capacitance Tolerance Lead Forming Type Lead Length Case Dimension Special Request (1) (2) (3) (4) (5) (6) (7) (8) (1) Series Series DIP UPS UPR UUL UPE SMD VSG VSP VSU VSE URP URH UGP UGS UGV UPC (2) Rated Voltage Code 0E 0J 6K 7H 1A 1B AG 1C 1D 1P 1E 1F 1V 1H 1J 2A WV 2.5 6.3 6.8 7.5 10 12 14 16 20 22 25 30 35 50 63 100 (3) Capacitance Code 6R8 μF 6.8 100 10 180 560 101 181 561 102 182 18 56 100 180 560 1000 1800 (4) Capacitance Tolerance Code J Q R K V M H % ±5 +30 / -10 +20 / -0 ± 10 +20 / -10 ± 20 +20 / -5 (5) Lead Type Code C P Description Cutting Taping Drawing Fig 1 Fig 2 (6) Lead Length (Cut / Formed lead) Code 3 4 U 7 D X R B E G 2 M T N Length 3.5 4.5 5.5 7 4 2.3 2.5 2.8 3.1 3.3 2.5 3.5 3.8 +20mm min Tolerance ±0.5 ±0.2 ±0.3 -15mm min Taping Code Code Z 2 3 7 5 S Lead Pitch:+0.8/-0.2 2.0 2.5 3.5 3.5 5.0 5.0 (7) Case Dimension DIP Code 0508 6305 6308 6311 0807 0808 0811 0816 0820 1012 1016 1020 10×16 10×20 Size 5×8 6.3×5 6.3×8 6.3×11 8×7 8×8 8×11 8×16 8×20 10×12 SMD Code 5057 6343 6357 6377 6309 0867 0897 08C7 1077 10C4 Size 5×5.7 6.3×4.3 6.3×5.7 6.3×7.7 6.3×9 8×6.7 8×9.7 8×12.7 10×7.7 10×12.4 (8) Special Request Code R F L D Description High Rated ripple current Endurance Low Leakage Current Low Dissipation Factor Code U E --- --- Description Convex Rubber Low ESR --- --- CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor  MARKING AND DATE CODE Trade Mark "CS" Chinsan Solid Capacitor, Show on Dimension ≧8 Ф Code (Date Code) (1)DAY (1) (2) (3) Code 1 2 3 4 5 1 1 0 Week The first week The second week The third week The fourth week The fifth week (2)Month Code 1 2 3 4 5 6 Month Jan Feb Mar Apr May Jun Code 7 8 9 X Y Z Month July Aug Sep Oct Nov Dec Code 9 0 1 2 3 4 Year 2019 2020 2021 2022 2023 2024 (3)Year Series (Print Code) Series UPS UPR UUL UPE URP URH UGP UGV UGS Ф 5~ Ф 6.3 -- R L E Ф 8~ Ф 10 UPS -- UL UPE RP -- H P V -- RH GP GV GS UPC VSG VSP C G UPC SG VSU VSE P U E SP SU SE  LEAD FORMING TYPE Dimensions (Unit: mm) Part Number ΦD F ι 3 4 U 7 D X R B E G 2 M T 3.5 4.5 5.5 7 4 2.3 2.5 2.8 3.1 3.3 2.5 3.5 3.8 Cut 2 ---- 6.3 2.5 ---- 8 3.5 ---- 10 5 ---- ±0.2 ±0.3 D ±0.5 5 (Part number for lead length and pitch for taping) F Type L C L CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor  TAPING Figure 1 Ф8 Фd ±0.05 0.45 0.45/0.6 0.6 P ±0.1 12.7 12.7 12.7 P0 ±0.2 12.7 12.7 12.7 P1 ±0.5 3.85 3.85 3.85 P2 ±1.0 6.35 6.35 6.35 5 5 5 PS P5 0.8 -0.2 H ±0.5 H0 ±0.5 17.5 18.5 PS P5 17.5 16 18.5 PS P5 17.5 16 18.5 16 W ±0.5 18 18 18 W0 Minimum 12.5 12.5 12.5 D0 ±0.2 4 4 4 t ±0.2 0.7 0.7 0.7 Symbol Tolerance Фd ±0.05 0.45/0.6 0.6 0.6 P ±0.1 12.7 12.7 12.7 P0 ±0.2 12.7 12.7 12.7 P1 ±0.5 5.1 4.6 3.85 P2 ±1.0 6.35 6.35 6.35 2.5 3.5 5 F Figure 3 Ф 6.3 Tolerance F Figure 2 Ф5 Symbol +0.8 -0.2 Ф 6.3 P2 H ±0.5 118.5 H0 ±0.5 - Ф8 P3 18.5 H3 20 - Ф 10 P7 17.5 P5 18.5 H5 20 - W ±0.5 18 18 18 W0 Minimum 12.5 12.5 12.5 D0 ±0.2 4 4 4 t ±0.2 0.7 0.7 0.7 Symbol Tolerance Фd ±0.05 0.45 P ±0.1 12.7 P0 ±0.2 12.7 P1 ±0.5 5.35 P2 ±1.0 6.35 F +0.8 -0.2 Ф5 PZ 2.0 H ±0.5 18.5 H0 ±0.5 - W ±0.5 18 W0 Minimum 12.5 D0 ±0.2 4 t ±0.2 0.7 J5 21
UPR0E821MCE6308E6 价格&库存
很抱歉,暂时无法提供与“UPR0E821MCE6308E6”相匹配的价格&库存,您可以联系我们找货
