CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS
CAPACITOR Aluminum Solid Capacitor
UPS
Series
Super low ESR at a high frequency range
High ripple current capability
2,000 hours at 105℃
SPECIFICATIONS
Item
Performance Characteristics
Category Temperature Range
-55 ~ +105℃
Working Voltage Range
2.5 ~ 16Vdc
Surge Voltage
Rated Voltage x1.15
Capacitance Tolerance
M: ±20%
ESR
(at 25℃ and 120Hz)
See the standard ratings table (at 25℃, 100~300KHz)
Dissipation Factor (Tanδ)
See the standard ratings table (at 25℃, 120Hz)
Leakage Current ※1
See the standard ratings table.(Impress the rated voltage for 2 minutes)
Low Temperature Characteristics
Impedance Ratio
Z(-25℃)/Z(+25℃) ≤1.15 at 100KHz
Z(-55℃)/Z(+25℃) ≤1.25 at 100KHz
The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage
with the rated ripple current is applied for 2,000 hours at 105°C
Endurance
Capacitance change
≦ ±20% of the initial value
ESR
≦ 150% of the specified value
Dissipation factor(tanδ)
Leakage current
≦ specified value
The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000
hours at 60℃ 90 to 95% RH
Damp Heat
( Steady State)
Capacitance change
ESR
Leakage current
≦ specified value
※1 In case of some problems for measured values, measure after applying rated voltage for 120 minutes at105°C
※2 ESR should be measured at both of the terminal ends closest to the capacitor body
◆ DIMENSIONS (mm)
PART NUMBER SYSTEM
◆ Lead
◆ Marking
ФD
8
8
10
Фd
0.6
0.6
0.6
L
8
11
12
α
1.0
1.5
1.5
F
3.5
3.5
5.0
UPS
Series
Standard Ratings
Rated
Voltage
(Vdc)
2.5(0E)
4(0G)
6.3(0J)
10(1A)
16(1C)
Rated
Capacitance
(μF)
Case Size
ΦD×L
(mm)
ESR
100~300KHz
(mΩmax)
Rated Ripple Current
105℃,100KHz
(mArms max)
Tanδ
max
Leakage
Current
(μA max)
560
8×8
7
4700
0.12
350
UPS0E561MNN0808U
680
8×8
7
5580
0.12
425
UPS0E681MNN0808U
820
8×8
7
6100
0.12
512
UPS0E821MNN0808U
Part Number
820
8×11
7
6100
0.12
410
UPS0E821MNN0811U
1000
8×8
7
6100
0.12
500
UPS0E102MNN0808U
1000
8×11
7
6100
0.12
500
UPS0E102MNN0811U
1200
8×8
7
6100
0.12
600
UPS0E122MNN0808U
1500
8×11
7
6100
0.12
750
UPS0E152MNN0811U
1500
10×12
7
6100
0.12
750
UPS0E152MNN1012U
1800
8×11
7
6100
0.12
900
UPS0E182MNN0811U
470
8×8
7
5600
0.12
470
UPS0G471MNN0808U
560
8×8
7
6100
0.12
560
UPS0G561MNN0808U
680
8×8
7
6100
0.12
544
UPS0G681MNN0808U
820
10×12
7
6100
0.12
656
UPS0G821MNN1012U
1200
10×12
7
6100
0.12
960
UPS0G122MNN1012U
220
8×8
7
3700
0.12
347
UPS0J221MNN0808U
330
8×8
7
3700
0.12
520
UPS0J331MNN0808U
390
8×8
7
5700
0.12
491
UPS0J391MNN0808U
470
8×8
7
5700
0.12
740
UPS0J471MNN0808U
470
8×8
8
5700
0.10
592
UPS0J471MNN0808EU
560
8×8
7
5700
0.12
882
UPS0J561MNN0808U
680
8×8
7
5860
0.12
857
UPS0J681MNN0808U
680
8×8
9
5700
0.12
1071
UPS0J681MNN0808EU
820
8×11
7
6100
0.12
1033
UPS0J821MNN0811U
820
8×8
9
5700
0.12
1033
UPS0J821MNN0808U
820
10×12
7
6100
0.12
1033
UPS0J821MNN1012U
1000
8×8
7
6100
0.12
1260
UPS0J102MNN0808U
1000
10×12
7
6100
0.12
1260
UPS0J102MNN1012U
1200
8×11
7
5700
0.12
1512
UPS0J122MNN0811U
1500
10×12
7
6100
0.12
1890
UPS0J152MNN1012U
2000
10×12
7
7100
0.12
2520
UPS0J202MNN1012U
270
8×11
7
5600
0.12
540
UPS1A271MNN0811U
470
10×12
7
6100
0.12
940
UPS1A471MNN1012U
560
8×11
7
5700
0.12
882
UPS1A561MNN0811U
560
10×12
7
6100
0.12
1120
UPS1A561MNN1012U
680
8×11
7
5600
0.12
1360
UPS1A681MNN0811U
820
8×11
7
5700
0.12
1640
UPS1A821MNN0811U
820
10×12
7
6100
0.12
1640
UPS1A821MNN1012U
1000
10×12
7
6100
0.12
2000
UPS1A102MNN1012U
150
8×11
7
5600
0.12
480
UPS1C151MNN0811U
180
8×8
7
5600
0.12
576
UPS1C181MNN0808U
180
8×11
7
5600
0.12
576
UPS1C181MNN0811U
270
8×11
7
5600
0.12
864
UPS1C271MNN0811U
330
8×11
7
5600
0.12
1056
UPS1C331MNN0811U
330
10×12
7
6100
0.12
1056
UPS1C331MNN1012U
Rated
Voltage
(Vdc)
16(1C)
Rated
Capacitance
(μF)
Case Size
ΦD×L
(mm)
ESR
100~300KHz
(mΩmax)
105℃,100KHz
(mArms max)
Tanδ
max
Leakage
Current
(μA max)
Part Number
470
8×11
7
5600
0.12
1504
UPS1C471MNN0811U
470
10×12
7
6100
0.12
1504
UPS1C471MNN1012U
820
10×12
7
6100
0.12
2000
UPS1C821MNN1012U
820
10×12
8
6100
0.12
2000
UPS1C821MNN1012EU
1000
10×12
7
6100
0.12
3200
UPS1C102MNN1012U
1200
10×12
8
6100
0.12
1920
UPS1C122MNN1012LU
PA RT N U M B E R S Y S T E M
RADIAL LEAD TYPE
Series
Rated Voltage
Capacitance
Tolerance
Lead Forming Type
Lead Length
Case Dimension
Special Request
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
(1) Series
Series
DIP
UPS
UPR
UUL
UPE
SMD
VSG
VSP
VSU
VSE
URP
URH
UGP
UGS
UGV
UPC
(2) Rated Voltage
Code
0E
0J
6K
7H
1A
1B
AG
1C
1D
1P
1E
1F
1V
1H
1J
2A
WV
2.5
6.3
6.8
7.5
10
12
14
16
25
30
35
50
63
100
(3) Capacitance
Code
6R8
μF
6.8
100
10
180
560
101
181
561
102
182
18
56
100
180
560
1000
1800
(4) Capacitance Tolerance
Code
J
Q
R
K
V
M
H
±5
+30 / -10
+20 / -0
± 10
+20 / -10
± 20
+20 / -5
(5) Lead Type
Code
C
P
Description
Cutting
Taping
Drawing
Fig 1
Fig 2
(6) Lead Length (Cut / Formed lead)
Code
3
4
U
7
D
X
R
B
E
G
2
M
T
N
Length
3.5
4.5
5.5
7
4
2.3
2.5
2.8
3.1
3.3
2.5
3.5
3.8
+20mm min
Tolerance
±0.5
±0.2
±0.3
-15mm min
Taping Code
Code
Z
2
3
7
5
S
Lead Pitch:+0.8/-0.2
2.0
2.5
3.5
3.5
5.0
5.0
(7) Case Dimension
DIP Code
0508
6305
6308
6311
0807
0808
0811
0816
0820
1012
1016
1020
10×16
10×20
Size
5×8
6.3×5
6.3×8
6.3×11
8×7
8×8
8×11
8×16
8×20
10×12
SMD Code
5057
6343
6357
6377
6309
0867
0897
08C7
1077
10C4
Size
5×5.7
6.3×4.3
6.3×5.7
6.3×7.7
6.3×9
8×6.7
8×9.7
8×12.7
10×7.7
10×12.4
(8) Special Request
Code
R
F
L
D
Description
High Rated ripple current
Endurance
Low Leakage Current
Low Dissipation Factor
Code
U
E
Description
Convex Rubber
Low ESR
MARKING AND DATE CODE
Trade Mark "CS"
Chinsan Solid Capacitor, Show on Dimension ≧8 Ф
Code (Date Code)
(1)DAY
(1)
(2)
(3)
Code
1
2
3
4
5
1
1
Week
The first week
The second week
The third week
The fourth week
The fifth week
(2)Month
Code
1
2
3
4
5
6
Month
Jan
Feb
Mar
Apr
May
Jun
Code
7
8
9
X
Y
Z
Month
July
Aug
Sep
Oct
Nov
Dec
Code
9
2
3
4
Year
2019
2020
2021
2022
2023
2024
(3)Year
Series (Print Code)
Series
UPS UPR UUL UPE URP URH UGP UGV UGS
Ф 5~ Ф 6.3
R
L
E
Ф 8~ Ф 10
UPS
UL
UPE RP
H
P
V
RH
GP
GV
GS
UPC VSG VSP
C
G
UPC SG
VSU VSE
P
U
E
SP
SU
SE
LEAD FORMING TYPE
Dimensions (Unit: mm)
Type
Part
Number
L
ΦD
F
ι
(Part number for lead length and pitch for taping)
3
4
U
7
D
X
R
B
E
G
2
M
T
3.5
4.5
5.5
7
4
2.3
2.5
2.8
3.1
3.3
2.5
3.5
3.8
Cut
2
6.3
2.5
8
3.5
10
5
±0.3
F
5
±0.2
D
±0.5
C
L
TAPING
Figure 1
Symbol
Tolerance
Ф5
Ф 6.3
Ф8
CAPACITOR Aluminum Solid CapacitorPS
P5
PS
P5
±0.05
0.45
0.45/0.6
0.6
P
±0.1
12.7
12.7
12.7
P0
±0.2
12.7
12.7
12.7
P1
±0.5
3.85
3.85
3.85
P2
±1.0
6.35
6.35
6.35
5
5
5
0.8
-0.2
H
±0.5
H0
±0.5
16
16
16
W
±0.5
18
18
18
W0
Minimum
12.5
12.5
12.5
D0
±0.2
4
4
4
t
±0.2
0.7
0.7
0.7
Symbol
Tolerance
Фd
±0.05
0.45/0.6
0.6
0.6
P
±0.1
12.7
12.7
12.7
P0
±0.2
12.7
12.7
12.7
P1
±0.5
5.1
4.6
3.85
P2
±1.0
6.35
6.35
6.35
2.5
3.5
5
F
Figure 3
PS
Фd
F
Figure 2
P5
+0.8
-0.2
17.5
18.5
Ф 6.3
P2
17.5
18.5
17.5
Ф8
P3
118.5
±0.5
W
±0.5
18
18
18
W0
Minimum
12.5
12.5
12.5
D0
±0.2
4
4
4
t
±0.2
0.7
0.7
0.7
Symbol
Tolerance
Фd
±0.05
0.45
P
±0.1
12.7
P0
±0.2
12.7
P1
±0.5
5.35
P2
±1.0
6.35
F
-0.2
2.0
H
±0.5
H0
±0.5
18.5
W
±0.5
18
W0
Minimum
12.5
D0
±0.2
4
t
±0.2
0.7
18.5
H5
±0.5
+0.8
17.5
P5
H
PZ
Ф 10
P7
H0
Ф5
18.5
H3
18.5
J5
21
很抱歉,暂时无法提供与“UPS0J102MNN0808”相匹配的价格&库存,您可以联系我们找货
