UPS1C331MQ30811
UPS1C331MQ30811
    CHINSAN(金山)
    插件
    CONDUCTIVE POLYMER SOLID CAPACIT
UPS1C331MQ30811 数据手册
CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor UPS Series  Super low ESR at a high frequency range  High ripple current capability  2,000 hours at 105℃  SPECIFICATIONS Item Performance Characteristics Category Temperature Range -55 ~ +105℃ Working Voltage Range 2.5 ~ 16Vdc Surge Voltage Rated Voltage x1.15 Capacitance Tolerance M: ±20% ESR (at 25℃ and 120Hz) See the standard ratings table (at 25℃, 100~300KHz) Dissipation Factor (Tanδ) See the standard ratings table (at 25℃, 120Hz) Leakage Current ※1 See the standard ratings table.(Impress the rated voltage for 2 minutes) Low Temperature Characteristics Impedance Ratio Z(-25℃)/Z(+25℃) ≤1.15 at 100KHz Z(-55℃)/Z(+25℃) ≤1.25 at 100KHz The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 2,000 hours at 105°C Endurance Capacitance change ≦ ±20% of the initial value ESR ≦ 150% of the specified value Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 60℃ 90 to 95% RH Damp Heat ( Steady State) Capacitance change ≦ ±20% of the initial value ESR ≦ 150% of the specified value Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦ specified value ※1 In case of some problems for measured values, measure after applying rated voltage for 120 minutes at105°C ※2 ESR should be measured at both of the terminal ends closest to the capacitor body ◆ DIMENSIONS (mm)  PART NUMBER SYSTEM ◆ Lead ◆ Marking ФD 8 8 10 Фd 0.6 0.6 0.6 L 8 11 12 α 1.0 1.5 1.5 F 3.5 3.5 5.0 CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor UPS ◆ Series Standard Ratings Rated Voltage (Vdc) 2.5(0E) 4(0G) 6.3(0J) 10(1A) 16(1C) Rated Capacitance (μF) Case Size ΦD×L (mm) ESR 100~300KHz (mΩmax) Rated Ripple Current 105℃,100KHz (mArms max) Tanδ max Leakage Current (μA max) 560 8×8 7 4700 0.12 350 UPS0E561MNN0808U 680 8×8 7 5580 0.12 425 UPS0E681MNN0808U 820 8×8 7 6100 0.12 512 UPS0E821MNN0808U Part Number 820 8×11 7 6100 0.12 410 UPS0E821MNN0811U 1000 8×8 7 6100 0.12 500 UPS0E102MNN0808U 1000 8×11 7 6100 0.12 500 UPS0E102MNN0811U 1200 8×8 7 6100 0.12 600 UPS0E122MNN0808U 1500 8×11 7 6100 0.12 750 UPS0E152MNN0811U 1500 10×12 7 6100 0.12 750 UPS0E152MNN1012U 1800 8×11 7 6100 0.12 900 UPS0E182MNN0811U 470 8×8 7 5600 0.12 470 UPS0G471MNN0808U 560 8×8 7 6100 0.12 560 UPS0G561MNN0808U 680 8×8 7 6100 0.12 544 UPS0G681MNN0808U 820 10×12 7 6100 0.12 656 UPS0G821MNN1012U 1200 10×12 7 6100 0.12 960 UPS0G122MNN1012U 220 8×8 7 3700 0.12 347 UPS0J221MNN0808U 330 8×8 7 3700 0.12 520 UPS0J331MNN0808U 390 8×8 7 5700 0.12 491 UPS0J391MNN0808U 470 8×8 7 5700 0.12 740 UPS0J471MNN0808U 470 8×8 8 5700 0.10 592 UPS0J471MNN0808EU 560 8×8 7 5700 0.12 882 UPS0J561MNN0808U 680 8×8 7 5860 0.12 857 UPS0J681MNN0808U 680 8×8 9 5700 0.12 1071 UPS0J681MNN0808EU 820 8×11 7 6100 0.12 1033 UPS0J821MNN0811U 820 8×8 9 5700 0.12 1033 UPS0J821MNN0808U 820 10×12 7 6100 0.12 1033 UPS0J821MNN1012U 1000 8×8 7 6100 0.12 1260 UPS0J102MNN0808U 1000 10×12 7 6100 0.12 1260 UPS0J102MNN1012U 1200 8×11 7 5700 0.12 1512 UPS0J122MNN0811U 1500 10×12 7 6100 0.12 1890 UPS0J152MNN1012U 2000 10×12 7 7100 0.12 2520 UPS0J202MNN1012U 270 8×11 7 5600 0.12 540 UPS1A271MNN0811U 470 10×12 7 6100 0.12 940 UPS1A471MNN1012U 560 8×11 7 5700 0.12 882 UPS1A561MNN0811U 560 10×12 7 6100 0.12 1120 UPS1A561MNN1012U 680 8×11 7 5600 0.12 1360 UPS1A681MNN0811U 820 8×11 7 5700 0.12 1640 UPS1A821MNN0811U 820 10×12 7 6100 0.12 1640 UPS1A821MNN1012U 1000 10×12 7 6100 0.12 2000 UPS1A102MNN1012U 150 8×11 7 5600 0.12 480 UPS1C151MNN0811U 180 8×8 7 5600 0.12 576 UPS1C181MNN0808U 180 8×11 7 5600 0.12 576 UPS1C181MNN0811U 270 8×11 7 5600 0.12 864 UPS1C271MNN0811U 330 8×11 7 5600 0.12 1056 UPS1C331MNN0811U 330 10×12 7 6100 0.12 1056 UPS1C331MNN1012U CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor Rated Voltage (Vdc) 16(1C) Rated Capacitance (μF) Case Size ΦD×L (mm) ESR 100~300KHz (mΩmax) Rated Ripple Current 105℃,100KHz (mArms max) Tanδ max Leakage Current (μA max) Part Number 470 8×11 7 5600 0.12 1504 UPS1C471MNN0811U 470 10×12 7 6100 0.12 1504 UPS1C471MNN1012U 820 10×12 7 6100 0.12 2000 UPS1C821MNN1012U 820 10×12 8 6100 0.12 2000 UPS1C821MNN1012EU 1000 10×12 7 6100 0.12 3200 UPS1C102MNN1012U 1200 10×12 8 6100 0.12 1920 UPS1C122MNN1012LU CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor PA RT N U M B E R S Y S T E M  RADIAL LEAD TYPE Series Rated Voltage Capacitance Tolerance Lead Forming Type Lead Length Case Dimension Special Request (1) (2) (3) (4) (5) (6) (7) (8) (1) Series Series DIP UPS UPR UUL UPE SMD VSG VSP VSU VSE URP URH UGP UGS UGV UPC (2) Rated Voltage Code 0E 0J 6K 7H 1A 1B AG 1C 1D 1P 1E 1F 1V 1H 1J 2A WV 2.5 6.3 6.8 7.5 10 12 14 16 20 22 25 30 35 50 63 100 (3) Capacitance Code 6R8 μF 6.8 100 10 180 560 101 181 561 102 182 18 56 100 180 560 1000 1800 (4) Capacitance Tolerance Code J Q R K V M H % ±5 +30 / -10 +20 / -0 ± 10 +20 / -10 ± 20 +20 / -5 (5) Lead Type Code C P Description Cutting Taping Drawing Fig 1 Fig 2 (6) Lead Length (Cut / Formed lead) Code 3 4 U 7 D X R B E G 2 M T N Length 3.5 4.5 5.5 7 4 2.3 2.5 2.8 3.1 3.3 2.5 3.5 3.8 +20mm min Tolerance ±0.5 ±0.2 ±0.3 -15mm min Taping Code Code Z 2 3 7 5 S Lead Pitch:+0.8/-0.2 2.0 2.5 3.5 3.5 5.0 5.0 (7) Case Dimension DIP Code 0508 6305 6308 6311 0807 0808 0811 0816 0820 1012 1016 1020 10×16 10×20 Size 5×8 6.3×5 6.3×8 6.3×11 8×7 8×8 8×11 8×16 8×20 10×12 SMD Code 5057 6343 6357 6377 6309 0867 0897 08C7 1077 10C4 Size 5×5.7 6.3×4.3 6.3×5.7 6.3×7.7 6.3×9 8×6.7 8×9.7 8×12.7 10×7.7 10×12.4 (8) Special Request Code R F L D Description High Rated ripple current Endurance Low Leakage Current Low Dissipation Factor Code U E --- --- Description Convex Rubber Low ESR --- ---  MARKING AND DATE CODE CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor Trade Mark "CS" Chinsan Solid Capacitor, Show on Dimension ≧8 Ф Code (Date Code) (1)DAY (1) (2) (3) Code 1 2 3 4 5 1 1 0 Week The first week The second week The third week The fourth week The fifth week (2)Month Code 1 2 3 4 5 6 Month Jan Feb Mar Apr May Jun Code 7 8 9 X Y Z Month July Aug Sep Oct Nov Dec Code 9 0 1 2 3 4 Year 2019 2020 2021 2022 2023 2024 (3)Year Series (Print Code) Series UPS UPR UUL UPE URP URH UGP UGV UGS Ф 5~ Ф 6.3 -- R L E Ф 8~ Ф 10 UPS -- UL UPE RP -- H P V -- RH GP GV GS UPC VSG VSP C G UPC SG VSU VSE P U E SP SU SE  LEAD FORMING TYPE Dimensions (Unit: mm) Type Part Number L ΦD F ι (Part number for lead length and pitch for taping) 3 4 U 7 D X R B E G 2 M T 3.5 4.5 5.5 7 4 2.3 2.5 2.8 3.1 3.3 2.5 3.5 3.8 Cut  2 ---- 6.3 2.5 ---- 8 3.5 ---- 10 5 ---- ±0.3 F 5 ±0.2 D ±0.5 C L TAPING Figure 1 Symbol Tolerance Ф5 Ф 6.3 Ф8 CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid CapacitorPS P5 PS P5 ±0.05 0.45 0.45/0.6 0.6 P ±0.1 12.7 12.7 12.7 P0 ±0.2 12.7 12.7 12.7 P1 ±0.5 3.85 3.85 3.85 P2 ±1.0 6.35 6.35 6.35 5 5 5 0.8 -0.2 H ±0.5 H0 ±0.5 16 16 16 W ±0.5 18 18 18 W0 Minimum 12.5 12.5 12.5 D0 ±0.2 4 4 4 t ±0.2 0.7 0.7 0.7 Symbol Tolerance Фd ±0.05 0.45/0.6 0.6 0.6 P ±0.1 12.7 12.7 12.7 P0 ±0.2 12.7 12.7 12.7 P1 ±0.5 5.1 4.6 3.85 P2 ±1.0 6.35 6.35 6.35 2.5 3.5 5 F Figure 3 PS Фd F Figure 2 P5 +0.8 -0.2 17.5 18.5 Ф 6.3 P2 17.5 18.5 17.5 Ф8 P3 118.5 ±0.5 - - - W ±0.5 18 18 18 W0 Minimum 12.5 12.5 12.5 D0 ±0.2 4 4 4 t ±0.2 0.7 0.7 0.7 Symbol Tolerance Фd ±0.05 0.45 P ±0.1 12.7 P0 ±0.2 12.7 P1 ±0.5 5.35 P2 ±1.0 6.35 F -0.2 2.0 H ±0.5 H0 ±0.5 18.5 - W ±0.5 18 W0 Minimum 12.5 D0 ±0.2 4 t ±0.2 0.7 18.5 H5 ±0.5 +0.8 17.5 P5 H PZ 20 Ф 10 P7 H0 Ф5 18.5 H3 18.5 20 J5 21
UPS1C331MQ30811 价格&库存
很抱歉,暂时无法提供与“UPS1C331MQ30811”相匹配的价格&库存,您可以联系我们找货
