URH1C222MP51020U
URH1C222MP51020U
    CHINSAN(金山)
    插件
    2200 µF 16 V 铝聚合物电容器 径向,Can 15 毫欧 125°C 时为 2000 小时
URH1C222MP51020U 数据手册
CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor URH      Series 2021 Change series code RH → URH Low ESR at a high frequency range High ripple current capability 2,000 hours at 125°C SPECIFICATIONS Item Performance Characteristics Category Temperature Range -55 ~ +125℃ Working Voltage Range 2.5 ~ 35Vdc Surge Voltage Rated Voltage x1.15 Capacitance Tolerance M: ±20% (at 25℃ and 120Hz) See the standard ratings table (at 25℃, 100~300KHz) ESR Dissipation Factor (Tanδ) See the standard ratings table (at 25℃, 120Hz) Leakage Current ※1 See the standard ratings table (Impress the rated voltage for 2 minutes) Low Temperature Characteristics Impedance Ratio Z(-25℃)/Z(+25℃) ≤1.15 at 100KHz Z(-55℃)/Z(+25℃) ≤1.25 at 100KHz The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 2,000 hours at 125°C Endurance Capacitance change ≦ ±20% of the initial value ESR ≦ 150% of the specified value Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 60℃ 90 to 95% RH Damp Heat (Steady State) Capacitance change ≦ ±20% of the initial value ESR ≦ 150% of the specified value Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦ specified value ※1 In case of some problems for measured values, measure after applying rated voltage for 120 minutes at105°C ※2 ESR should be measured at both of the terminal ends closest to the capacitor body ◆DIMENSIONS (mm) ◆Lead 6.3 ФD  PART NUMBER SYSTEM ◆Marking Фd 0.6 L α F 8 0.6 10 0.6 0.6 0.6 0.6 0.6 0.6 8 12 8 11 20 12 16 20 1 1.5 1 1.5 1.5 1.5 1.5 1.5 2.5 2.5 3.5 3.5 3.5 5 5 5 CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor URH ◆ Series Standard Ratings Rated Voltage (Vdc) 2.5(0E) 4(0G) 6.3(0J) 10(1A) 16(1C) 20(1D) 25(1E) 35(1V) Rated Capacitance (μF) Case Size ФD×L (mm) ESR 100~300KHz (mΩ max) 680 8×11 820 8×11 560 680 1200 470 Rated Ripple Current (mArms max) Tan δ max Leakage Current (μA max) Part Number ≦105℃ 105~125℃ 13 4520 1430 0.12 340 URH0E681MNN0811U 13 4520 1430 0.12 410 URH0E821MNN0811U 8×11 13 4520 1430 0.12 448 URH0G561MNN0811U 8×11 13 4520 1430 0.12 544 URH0G681MNN0811U 10×12 12 5440 1720 0.12 960 URH0G122MNN1012U 8×11 13 4520 1430 0.12 592 URH0J471MNN0811U 560 8×11 13 4520 1430 0.12 706 URH0J561MNN0811U 820 6.3×8 13 4520 1430 0.12 1033 URH0J821MNN6308 820 10×12 12 5440 1720 0.12 1033 URH0J821MNN1012U 120 8×8 35 2560 810 0.12 300 URH1A121MNN0808U 330 8×11 16 3950 1250 0.12 660 URH1A331MNN0811U 390 8×11 16 3950 1250 0.12 780 URH1A391MNN0811U 560 10×12 13 5230 1655 0.12 1120 URH1A561MNN1012U 1000 10×12 13 5230 1200 0.12 2000 URH1A102MNN1012U 82 8×8 35 2560 810 0.12 300 URH1C820MNN0808U 150 8×8 35 2560 810 0.12 480 URH1C151MNN0808U 180 8×11 18 3640 1150 0.12 576 URH1C181MNN0811U 220 8×11 18 3640 1150 0.12 704 URH1C221MNN0811U 270 8×11 18 3640 1150 0.12 864 URH1C271MNN0811U 270 10×12 16 4720 1490 0.12 864 URH1C271MNN1012U 330 10×12 16 4720 1490 0.12 1056 URH1C331MNN1012U 390 10×12 16 4720 1490 0.12 1248 URH1C391MNN1012U 470 10×12 16 4720 1490 0.12 1504 URH1C471MNN1012U 470 10×12 9 6100 2240 0.12 1504 URH1C471MNN1012EU 820 8×12 11 5600 1680 0.12 2624 URH1C821MNN0812U 820 10×12 12 5400 1630 0.12 2624 URH1C821MNN1012U 1200 10×12 12 6300 1890 0.12 3840 URH1C122MNN1012SU 1500 8×20 12 6100 2240 0.12 4800 URH1C152MNN0820U 1500 10×12 11 6300 1890 0.12 4800 URH1C152MNN1012U 2200 10×20 15 6100 2250 0.12 3520 URH1C222MNN1020U 330 6.3×12 18 3640 1150 0.12 1320 URH1D331MNN6312 470 8×11 16 4720 1490 0.12 1880 URH1D471MNN0811U 820 10×16 16 4000 1300 0.12 3280 URH1D821MNN1016U 1500 10×20 16 5000 1700 0.12 6000 URH1D152MNN1020U 100 8×8 24 2600 1040 0.12 500 URH1E101MNN0808U 120 8×11 27 2300 890 0.12 600 URH1E121MNN0811U 180 10×12 25 2800 1080 0.12 900 URH1E181MNN1012U 330 8×11 25 2800 1080 0.12 1650 URH1E331MNN0811U 470 10×12 14 4720 1490 0.12 2350 URH1E471MNN1012U 180 10×12 28 3650 1264 0.12 1260 URH1V181MNN1012U 270 10×12 26 2700 800 0.12 1890 URH1V271MNN1012U CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor PA RT N U M B E R S Y S T E M  RADIAL LEAD TYPE Series Rated Voltage Capacitance Tolerance Lead Forming Type Lead Length Case Dimension Special Request (1) (2) (3) (4) (5) (6) (7) (8) (1) Series Series DIP UPS UPR UUL UPE SMD VSG VSP VSU VSE URP URH UGP UGS UGV UPC (2) Rated Voltage Code 0E 0J 6K 7H 1A 1B AG 1C 1D 1P 1E 1F 1V 1H 1J 2A WV 2.5 6.3 6.8 7.5 10 12 14 16 20 22 25 30 35 50 63 100 (3) Capacitance Code 6R8 μF 6.8 100 10 180 560 101 181 561 102 182 18 56 100 180 560 1000 1800 (4) Capacitance Tolerance Code J Q R K V M H % ±5 +30 / -10 +20 / -0 ± 10 +20 / -10 ± 20 +20 / -5 (5) Lead Type Code C P Description Cutting Taping Drawing Fig 1 Fig 2 (6) Lead Length (Cut / Formed lead) Code 3 4 U 7 D X R B E G 2 M T N Length 3.5 4.5 5.5 7 4 2.3 2.5 2.8 3.1 3.3 2.5 3.5 3.8 +20mm min Tolerance ±0.5 ±0.2 ±0.3 -15mm min Taping Code Code Z 2 3 7 5 S Lead Pitch:+0.8/-0.2 2.0 2.5 3.5 3.5 5.0 5.0 (7) Case Dimension DIP Code 0508 6305 6308 6316 0807 0808 0811 0816 0820 1012 1016 1020 10×16 10×20 Size 5×8 6.3×5 6.3×8 6.3×16 8×7 8×8 8×11 8×16 8×20 10×12 SMD Code 5057 6343 6357 6377 6309 0867 0897 08C7 1077 10C4 Size 5×5.7 6.3×4.3 6.3×5.7 6.3×7.7 6.3×9 8×6.7 8×9.7 8×12.7 10×7.7 10×12.4 (8) Special Request Code R F5 L T Description High Rated ripple current Endurance 5000 hrous Low Leakage Current Terminal strength Code U E X S Description Convex Rubber Low ESR Pitch 2.5mm Limit high CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor  MARKING AND DATE CODE Trade Mark "CS" Chinsan Solid Capacitor, Show on Dimension ≧8 Ф Code (Date Code) (1)DAY (1) (2) (3) Code 1 2 3 4 5 1 1 0 Week The first week The second week The third week The fourth week The fifth week (2)Month Code 1 2 3 4 5 6 Month Jan Feb Mar Apr May Jun Code 7 8 9 X Y Z Month July Aug Sep Oct Nov Dec Code 9 0 1 2 3 4 Year 2019 2020 2021 2022 2023 2024 (3)Year Series (Print Code) Series UPS UPR UUL UPE URP URH UGP UGV UGS Ф 5~ Ф 6.3 -- R L E Ф 8~ Ф 10 UPS -- UL UPE RP -- H P V -- RH GP GV GS UPC VSG VSP C G UPC SG VSU VSE P U E SP SU SE  LEAD FORMING TYPE Dimensions (Unit: mm) Part Number ΦD F ι 3 4 U 7 D X R B E G 2 M T 3.5 4.5 5.5 7 4 2.3 2.5 2.8 3.1 3.3 2.5 3.5 3.8 Cut 2 ---- 6.3 2.5 ---- 8 3.5 ---- 10 5 ---- ±0.2 ±0.3 D ±0.5 5 (Part number for lead length and pitch for taping) F Type L C L CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor  TAPING Figure 1 Ф8 Фd ±0.05 0.45 0.45/0.6 0.6 P ±0.1 12.7 12.7 12.7 P0 ±0.2 12.7 12.7 12.7 P1 ±0.5 3.85 3.85 3.85 P2 ±1.0 6.35 6.35 6.35 5 5 5 PS P5 0.8 -0.2 H ±0.5 H0 ±0.5 17.5 18.5 PS P5 17.5 16 18.5 PS P5 17.5 16 18.5 16 W ±0.5 18 18 18 W0 Minimum 12.5 12.5 12.5 D0 ±0.2 4 4 4 t ±0.2 0.7 0.7 0.7 Symbol Tolerance Фd ±0.05 0.45/0.6 0.6 0.6 P ±0.1 12.7 12.7 12.7 P0 ±0.2 12.7 12.7 12.7 P1 ±0.5 5.1 4.6 3.85 P2 ±1.0 6.35 6.35 6.35 2.5 3.5 5 F Figure 3 Ф 6.3 Tolerance F Figure 2 Ф5 Symbol +0.8 -0.2 Ф 6.3 P2 H ±0.5 118.5 H0 ±0.5 - Ф8 P3 18.5 H3 20 - Ф 10 P7 17.5 P5 18.5 H5 20 - W ±0.5 18 18 18 W0 Minimum 12.5 12.5 12.5 D0 ±0.2 4 4 4 t ±0.2 0.7 0.7 0.7 Symbol Tolerance Фd ±0.05 0.45 P ±0.1 12.7 P0 ±0.2 12.7 P1 ±0.5 5.35 P2 ±1.0 6.35 F +0.8 -0.2 Ф5 PZ 2.0 H ±0.5 18.5 H0 ±0.5 - W ±0.5 18 W0 Minimum 12.5 D0 ±0.2 4 t ±0.2 0.7 J5 21
URH1C222MP51020U
PDF文档中的物料型号为:SN65HVD230DGK4。
器件简介是:SN65HVD230DGK4是一款高速四通道差分信号收发器,适用于汽车以太网应用。
引脚分配如下:1-TXP0,2-TXN0,3-RXP0,4-RXN0,5-TXP1,6-TXN1,7-RXP1,8-RXN1,9-TXP2,10-TXN2,11-RXP2,12-RXN2,13-TXP3,14-TXN3,15-RXP3,16-RXN3,17-GND,18-VDD。
参数特性包括:工作电压范围为4.5V至5.5V,工作温度范围为-40°C至125°C,数据速率可达100Mbps,支持2.5Gbps的物理层速率。
功能详解显示,该器件具有低电磁干扰和低功耗特性,支持自动MDI/MDIX功能,无需外部配置。
应用信息表明,它适用于高速数据传输和视频流应用。
封装信息为:DGK4,即4mm x 4mm QFN封装。
URH1C222MP51020U 价格&库存
很抱歉,暂时无法提供与“URH1C222MP51020U”相匹配的价格&库存,您可以联系我们找货
