URP1C331MPN1012
URP1C331MPN1012
    CHINSAN(金山)
    插件
    CONDUCTIVE POLYMER SOLID CAPACIT
URP1C331MPN1012 数据手册
CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor URP      Series 2021 Change series code RP → URP Low ESR at a high frequency range High ripple current capability 2,000 hours at 105°C SPECIFICATIONS Item Performance Characteristics Category Temperature Range -55 ~ +105℃ Working Voltage Range 2.5 ~ 16Vdc Surge Voltage Rated Voltage x1.15 Capacitance Tolerance M: ±20% ESR (at 25℃ and 120Hz) See the standard ratings table (at 25℃, 100~300KHz) Dissipation Factor (Tanδ) See the standard ratings table (at 25℃, 120Hz) Leakage Current ※1 See the standard ratings table (Impress the rated voltage for 2 minutes) Low Temperature Characteristics Impedance Ratio Z(-25℃)/Z(+25℃) ≤1.15 at 100KHz Z(-55℃)/Z(+25℃) ≤1.25 at 100KHz The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 2,000 hours at 105°C Endurance Capacitance change ≦ ±20% of the initial value ESR ≦ 150% of the specified value Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 60℃ 90 to 95% RH Damp Heat (Steady State) Capacitance change ≦ ±20% of the initial value ESR ≦ 150% of the specified value Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦ specified value ※1 In case of some problems for measured values, measure after applying rated voltage for 120 minutes at105°C ※2 ESR should be measured at both of the terminal ends closest to the capacitor body ◆DIMENSIONS (mm)  PART NUMBER SYSTEM ◆Lead ◆Marking ФD 8 8 10 Фd 0.6 0.6 0.6 L 8 11 12 α 1 1.5 1.5 F 3.5 3.5 5 CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor URP ◆ Series Standard Ratings Rated Voltage (Vdc) 2.5(0E) 4(0G) 6.3(0J) 10(1A) 16(1C) Rated Capacitance (μF) Case Size ФD×L (mm) ESR 100~300KHz (mΩ max) Rated Ripple Current 105℃,100KHz (mArms max) Tan δ max Leakage Current (μA max) 680 8×11 12 4520 0.12 340 URP0E681MNN0811U 820 8×11 12 5440 0.12 410 URP0E821MNN0811U 560 8×11 12 4520 0.12 448 URP0G561MNN0811U Part Number 820 10×12 12 5040 0.12 656 URP0G821MNN1012U 1200 10×12 12 5040 0.12 960 URP0G122MNN1012U 270 8×8 12 3600 0.12 340 URP0J271MNN0808U 470 8×8 12 4770 0.12 592 URP0J471MNN0808U 680 10×12 12 5040 0.12 857 URP0J681MNN1012U 820 10×12 12 5040 0.12 1033 URP0J821MNN1012U 1000 10×12 12 5040 0.12 1260 URP0J102MNN1012U 1200 8×11 12 5040 0.12 1512 URP0J122MNN0811U 1500 8×11 12 5040 0.12 1890 URP0J152MNN0811U 1500 10×12 12 5560 0.12 1890 URP0J152MNN1012U 220 8×8 12 4700 0.12 440 URP1A221MNN0808U 270 8×11 12 4420 0.12 540 URP1A271MNN0811U 330 8×8 12 4700 0.12 660 URP1A331MNN0808U 470 8×8 12 5100 0.12 940 URP1A471MNN0808U 470 10×12 12 5300 0.12 940 URP1A471MNN1012U 560 8×11 12 4500 0.12 1260 URP1A561MNN0811U 560 10×12 12 5300 0.12 1120 URP1A561MNN1012U 680 8×11 12 4500 0.12 1360 URP1A681MNN0811U 680 10×12 12 5300 0.12 1360 URP1A681MNN1012U 820 8×11 12 5000 0.12 1640 URP1A821MNN0811U 1000 10×12 12 5300 0.12 2000 URP1A102MNN1012U 1200 10×12 12 5300 0.12 2400 URP1A122MNN1012U 100 8×11 12 4850 0.12 320 URP1C101MNN0811U 180 8×8 12 3840 0.12 576 URP1C181MNN0808U 180 8×11 12 4850 0.12 576 URP1C181MNN0811U 270 8×8 12 4300 0.12 864 URP1C271MNN0808U 270 8×11 12 5000 0.12 864 URP1C271MNN0811U 270 10×12 12 5300 0.12 864 URP1C271MNN1012RU 330 8×8 12 4700 0.12 1056 URP1C331MNN0808U 330 8×11 12 5000 0.12 1056 URP1C331MNN0811U 330 10×12 12 5300 0.12 1056 URP1C331MNN1012U 470 8×8 12 4700 0.12 1504 URP1C471MNN0808U 470 8×11 12 5300 0.12 1504 URP1C471MNN0811U 470 8×11 11 5400 0.12 1504 URP1C471MNN0811ERU 470 10×12 12 5300 0.12 1504 URP1C471MNN1012U 470 10×12 10 6100 0.12 1504 URP1C471MNN1012ERU 560 8×11 12 5000 0.12 1792 URP1C561MNN0811U 560 10×12 12 5300 0.12 1792 URP1C561MNN1012U 680 8×11 12 5000 0.12 2176 URP1C681MNN0811U 680 10×12 12 5300 0.12 2176 URP1C681MNN1012U 820 8×11 12 5000 0.12 1312 URP1C821MNN0811U 820 10×12 12 5300 0.12 2624 URP1C821MNN1012U 820 10×12 11 5400 0.12 2634 URP1C821MNN1012ERU 1000 10×12 12 5400 0.12 3200 URP1C102MNN1012U 1200 10×12 12 5400 0.12 3840 URP1C122MNN1012U CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor PA RT N U M B E R S Y S T E M  RADIAL LEAD TYPE Series Rated Voltage Capacitance Tolerance Lead Forming Type Lead Length Case Dimension Special Request (1) (2) (3) (4) (5) (6) (7) (8) (1) Series Series DIP UPS UPR UUL UPE SMD VSG VSP VSU VSE URP URH UGP UGS UGV UPC (2) Rated Voltage Code 0E 0J 6K 7H 1A 1B AG 1C 1D 1P 1E 1F 1V 1H 1J 2A WV 2.5 6.3 6.8 7.5 10 12 14 16 20 22 25 30 35 50 63 100 (3) Capacitance Code 6R8 μF 6.8 100 10 180 560 101 181 561 102 182 18 56 100 180 560 1000 1800 (4) Capacitance Tolerance Code J Q R K V M H % ±5 +30 / -10 +20 / -0 ± 10 +20 / -10 ± 20 +20 / -5 (5) Lead Type Code C P Description Cutting Taping Drawing Fig 1 Fig 2 (6) Lead Length (Cut / Formed lead) Code 3 4 U 7 D X R B E G 2 M T N Length 3.5 4.5 5.5 7 4 2.3 2.5 2.8 3.1 3.3 2.5 3.5 3.8 +20mm min Tolerance ±0.5 ±0.2 ±0.3 -15mm min Taping Code Code Z 2 3 7 5 S Lead Pitch:+0.8/-0.2 2.0 2.5 3.5 3.5 5.0 5.0 (7) Case Dimension DIP Code 0508 6305 6308 6311 0807 0808 0811 0816 0820 1012 1016 1020 10×16 10×20 Size 5×8 6.3×5 6.3×8 6.3×11 8×7 8×8 8×11 8×16 8×20 10×12 SMD Code 5057 6343 6357 6377 6309 0867 0897 08C7 1077 10C4 Size 5×5.7 6.3×4.3 6.3×5.7 6.3×7.7 6.3×9 8×6.7 8×9.7 8×12.7 10×7.7 10×12.4 (8) Special Request Code R F L D Description High Rated ripple current Endurance Low Leakage Current Low Dissipation Factor Code U E --- --- Description Convex Rubber Low ESR --- --- CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor  MARKING AND DATE CODE Trade Mark "CS" Chinsan Solid Capacitor, Show on Dimension ≧8 Ф Code (Date Code) (1)DAY (1) (2) (3) Code 1 2 3 4 5 1 1 0 Week The first week The second week The third week The fourth week The fifth week (2)Month Code 1 2 3 4 5 6 Month Jan Feb Mar Apr May Jun Code 7 8 9 X Y Z Month July Aug Sep Oct Nov Dec Code 9 0 1 2 3 4 Year 2019 2020 2021 2022 2023 2024 (3)Year Series (Print Code) Series UPS UPR UUL UPE URP URH UGP UGV UGS Ф 5~ Ф 6.3 -- R L E Ф 8~ Ф 10 UPS -- UL UPE RP -- H P V -- RH GP GV GS UPC VSG VSP C G UPC SG VSU VSE P U E SP SU SE  LEAD FORMING TYPE Dimensions (Unit: mm) Part Number ΦD F ι 3 4 U 7 D X R B E G 2 M T 3.5 4.5 5.5 7 4 2.3 2.5 2.8 3.1 3.3 2.5 3.5 3.8 Cut 2 ---- 6.3 2.5 ---- 8 3.5 ---- 10 5 ---- ±0.2 ±0.3 D ±0.5 5 (Part number for lead length and pitch for taping) F Type L C L CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor  TAPING Figure 1 Ф8 Фd ±0.05 0.45 0.45/0.6 0.6 P ±0.1 12.7 12.7 12.7 P0 ±0.2 12.7 12.7 12.7 P1 ±0.5 3.85 3.85 3.85 P2 ±1.0 6.35 6.35 6.35 5 5 5 PS P5 0.8 -0.2 H ±0.5 H0 ±0.5 17.5 18.5 PS P5 17.5 16 18.5 PS P5 17.5 16 18.5 16 W ±0.5 18 18 18 W0 Minimum 12.5 12.5 12.5 D0 ±0.2 4 4 4 t ±0.2 0.7 0.7 0.7 Symbol Tolerance Фd ±0.05 0.45/0.6 0.6 0.6 P ±0.1 12.7 12.7 12.7 P0 ±0.2 12.7 12.7 12.7 P1 ±0.5 5.1 4.6 3.85 P2 ±1.0 6.35 6.35 6.35 2.5 3.5 5 F Figure 3 Ф 6.3 Tolerance F Figure 2 Ф5 Symbol +0.8 -0.2 Ф 6.3 P2 H ±0.5 118.5 H0 ±0.5 - Ф8 P3 18.5 H3 20 - Ф 10 P7 17.5 P5 18.5 H5 20 - W ±0.5 18 18 18 W0 Minimum 12.5 12.5 12.5 D0 ±0.2 4 4 4 t ±0.2 0.7 0.7 0.7 Symbol Tolerance Фd ±0.05 0.45 P ±0.1 12.7 P0 ±0.2 12.7 P1 ±0.5 5.35 P2 ±1.0 6.35 F +0.8 -0.2 Ф5 PZ 2.0 H ±0.5 18.5 H0 ±0.5 - W ±0.5 18 W0 Minimum 12.5 D0 ±0.2 4 t ±0.2 0.7 J5 21
URP1C331MPN1012 价格&库存
很抱歉,暂时无法提供与“URP1C331MPN1012”相匹配的价格&库存,您可以联系我们找货
