VJ2W680MNN1825R
VJ2W680MNN1825R
    CHINSAN(金山)
    插件
    68 µF 450 V 铝电解电容器 径向,Can 105°C 时为 10000 小时
VJ2W680MNN1825R 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 VJ    Series Capacitor For Over Voltage Application Load life 10,000 hours at 105℃ SPECIFICATIONS Performance Characteristics Item Category Temperature Range -25 ~ +105℃ 160 ~ 450Vdc Working Voltage Range Capacitance Range 22 ~ 680 μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Charge and Discharge Rated Voltage (V) 160 ~ 250 400 ~ 450 tanδ(Max) 0.12 0.15 I=0.02CV or 3000 μA whichever is smaller I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 2 minutes Rated voltage (V) 160~250 400 420 ~ 450 Z(-25℃)/Z(+20℃) 3 5 6 Dissipation factor(tanδ) 200million times Leakage current ≦ 200% of the specified value ≦ specified value Endurance The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 10,000 hours at 105°C. ≦ ±20% of the initial value Capacitance change Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦specified value Shelf Life The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 1,000 hours at 105℃ without voltage applied. ≦ ±20% of the initial value Capacitance change Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Others  V (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25℃ after subjected to charge and discharge test with the voltage waveform shown below at room temperature(15 to 35℃) Number of Voltage waveform Frequency cycles ≦ ±20% of the Capacitance change initial value 5Hz  V : Rated voltage (V) Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) J ФD ФD Фd F 0.6 5.0 a L + 1.5 Max 10 12.5 ФD + 0.5 Max 0.6 5.0 ≤35 L+1.5Max ≥40 L+2.0 Max PART NUMBER SYSTEM( Example : 160V 560µF ) 2 C 5 6 1 M N N 1 8 4 5 Special Request Size code(1845 : 18×45) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (560μF) Voltage code (160V) Series code (VJ) 16 18 0.8 7.5 0.8 7.5 L + 1.5 Max Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES VJ NO.: FIG-1 FIG-2 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 1 VJ2W330MRL1625A6 / 33 µF ±20% 450 V / -40~+105 / / 300 / / / 10000 16 25 / / 7.5 FIG-1 2 VJ2W220MNN1220A4E / 22 µF ±20% 450 V / -40~+105 / / 200 / / 6200 10000 12.5 20 / / 5 FIG-2 3 VJ2W680MNN1825R / 68 µF ±20% 450 V / -25~+105 / / 650 975 / 3200 10000 18 25 / / 7.5 FIG-2 4 VJ2W470MNN1625A6 / 47 µF ±20% 450 V / -40~+105 / / 500 675 / 1200 10000 16 25 / / 7.5 FIG-2 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black.
VJ2W680MNN1825R 价格&库存
很抱歉,暂时无法提供与“VJ2W680MNN1825R”相匹配的价格&库存,您可以联系我们找货
