VQ2W330MRT1620Z
VQ2W330MRT1620Z
    CHINSAN(金山)
    插件
    ALUMINUM ELECTROLYTIC CAPACITORS
VQ2W330MRT1620Z 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 VQ    Series Capacitor For Over Voltage Application Load life 5,000 hours at 105℃ SPECIFICATIONS Performance Characteristics Item Category Temperature Range Working Voltage Range Capacitance Range Capacitance Tolerance Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Charge and Discharge -25 ~ +105℃ 160 ~ 450Vdc 22 ~ 680 μF ±20% (at 25℃ and 120Hz) Rated Voltage (V) tanδ(Max) 160 ~ 250 0.12 I=0.02CV or 3000 μA whichever is smaller I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 2 minutes  V V : Rated voltage (V) Rated voltage (V) 160~250 400 420 ~ 450 Z(-25℃)/Z(+20℃) 3 5 6 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25℃ after subjected to charge and discharge test with the voltage waveform shown below at room temperature(15 to 35℃) Number of Voltage waveform Frequency cycles ≦ ±20% of the Capacitance change initial value ≦ 200% of the Dissipation factor(tanδ) specified value 200million 5Hz times Leakage current ≦ specified value Endurance The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 5,000 hours at 105°C. ≦ ±20% of the initial value Capacitance change Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ specified value Shelf Life The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 1,000 hours at 105℃ without voltage applied. ≦ ±20% of the initial value Capacitance change Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Others  400 ~ 450 0.15 Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD ФD Фd F 0.6 5.0 a L + 1.5 Max 10 12.5 ФD + 0.5 Max 0.6 5.0 ≤35 L+1.5Max ≥40 L+2.0 Max PART NUMBER SYSTEM( Example : 450V 47µF ) Q 2 W 4 7 0 M N N 1 2 4 5 Special Request Size code(1245 : 12.5×45) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (47μF) Voltage code (450V) Series code (VQ) 16 18 0.8 7.5 0.8 7.5 L +1.5 Max Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES VQ NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=30.0±1.0 P0=15.0±0.2 P1=3.75±0.5 P2=7.5±1.0 F=7.5+0.8/-0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 1 VQ2W680MNN1440 / 68 µF ±20% 450 V / -25~+105 / / 650 / / / 5000 14.5 40 / / 7.5 Original 2 VQ2E121MPI1620E / 120 µF ±20% 250 V / -25~+105 / / 700 / / 40 5000 16 20 / / 7.5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Capacitance Voltage (%) 1 VQ2W330MRT1620Z / 33 µF Working ±20% (Vdc) 450 V Surge Voltage (Vdc) / VQ NO.: Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) -25~+105 / (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ / 2022-03-25 PUBLISH DATE 120Hz 100kHz 350 / 120Hz) 100kHz) / / Dimensions (mm) Endurance Appearance @ 105℃ (Hours) 5000 Drawing DΦ L a d F No 16 20 / / 7.5 --- ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black.
VQ2W330MRT1620Z 价格&库存
很抱歉,暂时无法提供与“VQ2W330MRT1620Z”相匹配的价格&库存,您可以联系我们找货
