VSP0E561MCB6357E
VSP0E561MCB6357E
    CHINSAN(金山)
    SMD
    560 µF 2.5 V 铝聚合物电容器 径向,Can - SMD 10 毫欧 105°C 时为 2000 小时
VSP0E561MCB6357E 数据手册
CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS VSP      Series 2021 Change series code SP → VSP Super Low ESR at a high frequency range High ripple current capability 2,000 hours at 105°C SPECIFICATIONS Item Performance Characteristics Category Temperature Range -55 ~ +105℃ Working Voltage Range 2.5 ~ 25Vdc Surge Voltage Rated Voltage x1.15 Capacitance Tolerance M: ±20% ESR (at 25℃ and 120Hz) See the standard ratings table (at 25℃, 100~300KHz) Dissipation Factor (Tanδ) See the standard ratings table (at 25℃, 120Hz) Leakage Current ※1 See the standard ratings table.(Impress the rated voltage for 2 minutes) Low Temperature Characteristics Impedance Ratio Z(-25℃)/Z(+25℃) ≤1.15 at 100KHz Z(-55℃)/Z(+25℃) ≤1.25 at 100KHz The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 2,000 hours at 105°C Endurance Capacitance change ≦ ±20% of the initial value ESR ≦ 150% of the specified value Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 60℃ 90 to 95% RH Damp Heat (Steady State) ※1 ※2 Capacitance change ≦ ±20% of the initial value ESR ≦ 150% of the specified value Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦ specified value In case of some problems for measured values, measure after applying rated voltage for 120 minutes at105°C ESR should be measured at both of the terminal ends closest to the capacitor body ◆DIMENSIONS ◆Marking Case Size ФD  PART NUMBER SYSTEM L α A B C W P 0557 5×5.7 5 5.7 0.3 5.3 5.3 5.9 0.5~0.8 1.4 6343 6.3×4.3 6.3 4.3 +0.4 6.6 -0.3 6.6 7.3 0.5~0.8 2.1 6357 6.3×5.7 6.3 5.7 0.3 6.6 6.6 7.3 0.5~0.8 2.1 0867 8×6.7 8 6.7 0.3 8.3 8.3 9 0.7~1.1 3.2 0897 8×9.7 8 9.7 0.5 8.3 8.3 9 0.7~1.1 3.2 1077 10×7.7 10 7.7 0.5 10.3 10.3 11 0.7~1.1 4.6 10C4 10×12.4 10 12.4 0.5 10.3 10.3 11 0.7~1.1 4.6 ≦6.3Ф ≧8Ф CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS VSP ◆ Series Standard Ratings Rated Voltage (Vdc) 2.5(0E) 4(0G) 6.3(0J) 10(1A) 16(1C) 25(1E) Rated Capacitance (μF) Case Size ФD×L (mm) ESR 100~300KHz (mΩ max) Rated Ripple Current 105℃,100KHz (mArms max) Tan δ max Leakage Current (μA max) 180 5×5.7 21 2670 0.12 300 VSP0E181MCB0557 330 5×5.7 15 3150 0.12 300 VSP0E331MCB0557 330 6.3×4.3 17 3500 0.12 413 VSP0E331MCB6343 330 6.3×4.3 12 3500 0.12 700 VSP0E331MCB6343E 390 6.3×5.7 15 3160 0.12 344 VSP0E391MCB6357 560 6.3×5.7 16 3600 0.12 420 VSP0E561MCB6357 560 6.3×5.7 10 3870 0.12 500 VSP0E561MCB6357E 680 8×6.7 13 4100 0.12 510 VSP0E681MCB0567 2700 10×12.4 12 5070 0.12 2025 VSP0E272MCB10C4 330 6.3×5.7 15 3160 0.12 396 VSP0G331MCB6357 1500 8×12.7 12 4700 0.12 1800 VSP0G152MCB08C7 100 5×5.7 24 2500 0.12 300 VSP0J101MCB0557 120 5×5.7 24 2500 0.12 300 VSP0J121MCB0557 220 5×5.7 12 3500 0.12 700 VSP0J221MCB0557 220 6.3×4.3 17 3160 0.12 693 VSP0J221MCB6343 220 6.3×4.3 18 3000 0.12 500 VSP0J221MCB6343L 220 6.3×5.7 15 3160 0.12 416 VSP0J221MCB6357 330 6.3×5.7 17 3600 0.12 624 VSP0J331MCB6357 470 8×12.7 15 3950 0.12 888 VSP0J471MCB08C7 560 6.3×9 10 4700 0.12 706 VSP0J561MCB6309 330 8×12.7 17 3950 0.12 990 VSP1A331MCB08C7 100 6.3×5.7 24 2490 0.12 320 VSP1C101MCB6357 180 8×9.7 16 3890 0.12 576 VSP1C181MCB0897 270 6.3×9 9 5300 0.12 864 VSP1C271MCB6309 270 8×9.7 16 3890 0.12 864 VSP1C271MCB0897 47 6.3×5.7 30 2500 0.12 588 VSP1E470MCB6357 100 8×9.7 24 3300 0.12 500 VSP1E101MCB0897 120 8×9.7 22 3500 0.12 600 VSP1E121MCB0897 Part Number CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS PA RT N U M B E R S Y S T E M  RADIAL LEAD TYPE Series Rated Voltage Capacitance Tolerance Lead Forming Type Lead Length Case Dimension Special Request (1) (2) (3) (4) (5) (6) (7) (8) (1) Series Series DIP UPS UPR UUL UPE SMD VSG VSP VSU VSE URP URH UGP UGS UGV UPC (2) Rated Voltage Code 0E 0J 6K 7H 1A 1B AG 1C 1D 1P 1E 1F 1V 1H 1J 2A WV 2.5 6.3 6.8 7.5 10 12 14 16 20 22 25 30 35 50 63 100 (3) Capacitance Code 6R8 μF 6.8 100 10 180 560 101 181 561 102 182 18 56 100 180 560 1000 1800 (4) Capacitance Tolerance Code J Q R K V M H % ±5 +30 / -10 +20 / -0 ± 10 +20 / -10 ± 20 +20 / -5 (5) Lead Type Code C P Description Cutting Taping Drawing Fig 1 Fig 2 (6) Lead Length (Cut / Formed lead) Code 3 4 U 7 D X R B E G 2 M T N Length 3.5 4.5 5.5 7 4 2.3 2.5 2.8 3.1 3.3 2.5 3.5 3.8 +20mm min Tolerance ±0.5 ±0.2 ±0.3 -15mm min Taping Code Code Z 2 3 7 5 S Lead Pitch:+0.8/-0.2 2.0 2.5 3.5 3.5 5.0 5.0 (7) Case Dimension DIP Code 0508 6305 6308 6311 0807 0808 0811 0816 0820 1012 1016 1020 Size 5×8 6.3×5 6.3×8 6.3×11 8×7 8×8 8×11 8×16 8×20 10×12 10×16 10×20 SMD Code 0557 6343 6357 6377 6309 0867 0897 08C7 1077 10C4 Size 5×5.7 6.3×4.3 6.3×5.7 6.3×7.7 6.3×9 8×6.7 8×9.7 8×12.7 10×7.7 10×12.4 (8) Special Request Code R F L D Description High Rated ripple current Endurance Low Leakage Current Low Dissipation Factor Code U E --- --- Description Convex Rubber Low ESR --- --- CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS  MARKING AND DATE CODE Trade Mark "CS" Chinsan Solid Capacitor, Show on Dimension ≧8 Ф Code (Date Code) (1)DAY (1) (2) (3) Code 1 2 3 4 5 1 1 0 Week The first week The second week The third week The fourth week The fifth week (2)Month Code 1 2 3 4 5 6 Month Jan Feb Mar Apr May Jun Code 7 8 9 X Y Z Month July Aug Sep Oct Nov Dec Code 9 0 1 2 3 4 Year 2019 2020 2021 2022 2023 2024 (3)Year Series (Print Code) Series UPS UPR UUL UPE URP URH UGP UGV UGS Ф 5~ Ф 6.3 -- R L E Ф 8~ Ф 10 UPS -- UL UPE RP -- H P V -- RH GP GV GS UPC VSG VSP C G UPC SG VSU VSE P U E SP SU SE CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS SMD CARRIER TAPE DUMENTIONS Item Dimension Code 5057 (5x5.7) 6343 (6.3x4.3) 6357 (6.3x5.7) 6377 (6.3x7.7) 6309 (6.3x9) 0867 (8x6.7) 0897 (8x9.7) 08C7 (8x12.7) 1077 (10x7.7) 10C4 (10x12.4)  W ±0.3 16 16 16 16 16 24 24 24 24 24 A ±0.2 5.6 7.0 7.0 7.0 7.0 8.7 8.7 8.7 10.7 10.7 B ±0.2 5.6 7.0 7.0 7.0 7.0 8.7 8.7 8.7 10.7 10.7 F ±0.1 7.5 7.5 7.5 7.5 7.5 11.5 11.5 11.5 11.5 11.5 P ±0.1 12 12 12 12 12 12 16 16 16 16 T ±0.2 6.2 4.7 6.2 8.2 10.0 7.2 10.3 13.2 8.3 13.0 SMD REEL DIMENTIONS AND PACKING QUANTITY Case Code Quantity per reel Quantity per Box※ 5057 1200 12000 6343 1500 15000 6357 1200 12000 6377 1000 10000 6309 800 8000 0867 1000 7000 0897 500 3500 08C7 400 2800 1077 500 3500 10C4 400 2800 ※ This may change according to a delivered quantity W 17.5 25.3
VSP0E561MCB6357E
物料型号: - 系列代码:VSP - 额定电压:2.5V至25V - 容值:从180uF到2700uF不等 - 尺寸:5x5.7mm到10x12.4mm
器件简介: - 这些电容器具有超低的等效串联电阻(ESR),在高频范围内表现优异。 - 它们能够承受高纹波电流,并在105°C下经过2000小时的测试。
引脚分配: - 引脚类型:切割型(Cutting)和卷曲型(Taping) - 引脚长度:有多种选项,如3.5mm、4.5mm、5.5mm等,具体取决于型号。
参数特性: - 工作电压范围:2.5V至25V - 电容公差:M级,20%(在25°C和120Hz时) - ESR:在25°C和100-300KHz时,具体值见标准额定表 - 损耗角正切(Tanδ):在25°C和120Hz时,具体值见标准额定表 - 漏电流:在额定电压下施加2分钟,具体值见标准额定表
功能详解: - 低温特性:在-25°C和-55°C时的阻抗比不超过1.15和1.25(在100KHz时) - 耐久性:在105°C下,施加额定纹波电流2000小时后,电容变化、ESR、损耗角正切和漏电流均满足特定要求。
应用信息: - 这些电容器适用于需要高可靠性和稳定性的应用,如电源、通信设备等。
封装信息: - 提供了多种封装尺寸,如0557(5x5.7mm)、6343(6.3x4.3mm)、6357(6.3x5.7mm)等。 - 还提供了SMD卷带的尺寸和每卷的数量,以及每箱的数量。
特殊请求: - 可以提供高额定纹波电流、耐久性、低漏电流和低损耗角正切的特殊要求。
标记和日期代码: - 包括商标(Chinsan)、系列代码、额定电容、额定电压等信息。
SMD载带尺寸: - 提供了不同封装尺寸的SMD载带的详细尺寸。
SMD卷盘尺寸和包装数量: - 列出了不同封装尺寸的卷盘尺寸和每卷、每箱的数量。
VSP0E561MCB6357E 价格&库存
很抱歉,暂时无法提供与“VSP0E561MCB6357E”相匹配的价格&库存,您可以联系我们找货
