VW2W181MCM1845A4E
VW2W181MCM1845A4E
    CHINSAN(金山)
    插件
    180 µF 450 V 铝电解电容器 径向,Can 420 毫欧 @ 120Hz 105°C 时为 2000 小时
VW2W181MCM1845A4E 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 VW    Series Capacitor For Over Voltage Application Load life 2,000 hours at 105℃ SPECIFICATIONS Performance Characteristics Item Category Temperature Range -25 ~ +105℃ Working Voltage Range 160 ~ 450Vdc Capacitance Range 22 ~ 680 μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Charge and Discharge Rated Voltage (V) tanδ(Max) 160 ~ 250 0.12 I=0.02CV or 3000 μA whichever is smaller I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 2 minutes V : Rated voltage (V) Rated voltage (V) 160~250 400 420 ~ 450 Z(-25℃)/Z(+20℃) 3 5 6 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25℃ after subjected to charge and discharge test with the voltage waveform shown below at room temperature(15 to 35℃) Number of Voltage waveform Frequency cycles ≦ ±20% of the Capacitance change initial value ≦ 200% of the Dissipation factor(tanδ) 200million specified value 5Hz times Leakage current ≦ specified value Endurance The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 2,000 hours at 105°C. ≦ ±20% of the initial value Capacitance change Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ specified value Shelf Life The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 1,000 hours at 105℃ without voltage applied. ≦ ±20% of the initial value Capacitance change Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Others  400 ~ 450 0.15 Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD ФD Фd F 0.6 5.0 a L + 1.5 Max 10 12.5 ФD + 0.5 Max 0.6 5.0 ≤ 35 L+1.5Max ≥ 40 L+2.0 Max  PART NUMBER SYSTEM( Example : 450V 150µF ) V W 2 W 1 5 1 M N N 1 8 4 5 Special Request Size code(1845 : 18×45) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (150μF) Voltage code (450V) Series code (VW) 16 18 0.8 7.5 0.8 7.5 L + 1.5 Max Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ Aluminum Electrolytic Capacitor Customer Digi-Key SERIES VW NO.: FIG-1 FIG-2 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ @ 105℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ (Hours) Drawing DΦ L 26 a d F No 1 VW2W680MNN1626AES / 68 µF ±20% 450 V / -25~+105 / / 700 / 900 500 2000 16 / / 7.5 FIG-1 2 VW2W121MNN18N3A4E / 120 µF ±20% 450 V / -25~+105 / / 775 / / 450 2000 18 31.5 / / 7.5 FIG-1 3 VW2S121MNN1830EF3J / 120 µF ±20% 420 V / -25~+105 / / 870 1200 / 400 3000 18 30 / / 7.5 FIG-1 4 VW2W101MNN1825A4EF3 / 100 µF ±20% 450 V / -25~+105 / / 900 / / 300 3000 18 25 / / 7.5 FIG-1 5 VW2S680MNN1625EF3 / 68 µF ±20% 420 V / -25~+105 / / 580 / / 400 3000 16 25 / / 7.5 FIG-1 6 VW2W181MCM1845A4E / 180 µF ±20% 450 V / -25~+105 / / 1200 / 420 / 2000 18 45 / / 7.5 FIG-2 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Suffix F3 indicates the life of the capacitor is 3000 hrs.
VW2W181MCM1845A4E 价格&库存
很抱歉,暂时无法提供与“VW2W181MCM1845A4E”相匹配的价格&库存,您可以联系我们找货
