Taiwan Chinsan Electronic Ind., Co., Ltd.
Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan
http://www.chinsan.com/products/
TEL: +886 2 2995 0535
VW
Series
Capacitor For Over Voltage Application
Load life 2,000 hours at 105℃
SPECIFICATIONS
Performance Characteristics
Item
Category Temperature Range
-25 ~ +105℃
Working Voltage Range
160 ~ 450Vdc
Capacitance Range
22 ~ 680 μF
Capacitance Tolerance
±20% (at 25℃ and 120Hz)
Dissipation Factor
(tanδ)
(at 25℃, 120Hz)
Leakage Current
Low Temperature Characteristics
Impedance Ratio(MAX)
Charge and Discharge
Rated Voltage (V)
tanδ(Max)
160 ~ 250
0.12
I=0.02CV or 3000 μA whichever is smaller
I : Leakage current (μA) C : Rated capacitance (μF)
Impress the rated voltage for 2 minutes
V : Rated voltage (V)
Rated voltage (V)
160~250
400
420 ~ 450
Z(-25℃)/Z(+20℃)
3
5
6
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 25℃ after subjected to charge and
discharge test with the voltage waveform shown below at room temperature(15 to 35℃)
Number of
Voltage waveform
Frequency
cycles
≦ ±20% of the
Capacitance change
initial value
≦ 200% of the
Dissipation factor(tanδ)
200million
specified value
5Hz
times
Leakage current
≦ specified value
Endurance
The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with
the rated ripple current is applied for 2,000 hours at 105°C.
≦ ±20% of the initial value
Capacitance change
≦ 200% of the specified value
Leakage current
≦ specified value
Shelf Life
The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for
1,000 hours at 105℃ without voltage applied.
Capacitance change
Leakage current
Others
400 ~ 450
0.15
Conforms to JIS-C-5101-4 (1998), characteristic W
DIMENSIONS (mm)
ФD
ФD
Фd
F
0.6
5.0
a
L + 1.5 Max
10
12.5
ФD + 0.5 Max
0.6
5.0
≤ 35 L+1.5Max
≥ 40 L+2.0 Max
PART NUMBER SYSTEM( Example : 450V 150µF )
V W 2 W 1 5 1 M N N 1 8 4 5
Special Request
Size code(1845 : 18×45)
Lead length code
Lead forming Type code
Capacitance tolerance code(M:±20%)
Capacitance code (150μF)
Voltage code (450V)
Series code (VW)
16
18
0.8
7.5
0.8
7.5
L + 1.5 Max
Aluminum Electrolytic Capacitor
Customer
Digi-Key
SERIES
VW
NO.:
FIG-1
FIG-2
Tolerance
No.
CHINSAN
Part No.
Customer Capacitance
Part No.
(uF)
2022-03-25
PUBLISH DATE
On rated
Working
Capacitance Voltage
(Vdc)
Surge
Voltage
(Vdc)
Rated
Rated
Category
Tanδ
Leakage
Ripple
Ripple
ESR
Impedance
Temp
@ 25℃
Current
Current
Current
@25℃
@20℃
Range
(120Hz)
(uA)
(Max)
(2 min.)
(mA rms) (mA rms) (mΩ max/ (mΩ max/
@ 105℃ @ 105℃
120Hz
100kHz
120Hz)
100kHz)
Dimensions (mm)
Endurance
Appearance
@ 105℃
(Hours)
Drawing
DΦ L
26
a
d
F
No
1
VW2W680MNN1626AES
68 µF
±20%
450 V
-25~+105
700
900
500
2000
16
/ 7.5
FIG-1
2
VW2W121MNN18N3A4E
120 µF
±20%
450 V
-25~+105
775
450
2000
18 31.5 /
/ 7.5
FIG-1
3
VW2S121MNN1830EF3J
120 µF
±20%
420 V
-25~+105
870
1200
400
3000
18
30
/ 7.5
FIG-1
4 VW2W101MNN1825A4EF3
100 µF
±20%
450 V
-25~+105
900
300
3000
18
25
/ 7.5
FIG-1
5
VW2S680MNN1625EF3
68 µF
±20%
420 V
-25~+105
580
400
3000
16
25
/ 7.5
FIG-1
6
VW2W181MCM1845A4E
180 µF
±20%
450 V
-25~+105
1200
420
2000
18
45
/ 7.5
FIG-2
※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test.
REMARKS:
APPROVED BY
CHECKED BY
PREPARED BY
张洪斌
曾爱娥
梁慧妍
Sleeve Color: Black.
Suffix F3 indicates the life of the capacitor is 3000 hrs.
很抱歉,暂时无法提供与“VW2S680MNN1625EF3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+9.57960
- 200+3.82320
- 400+3.69360
- 1000+3.62880
