1N4005GA0
1N4005GA0
    TAIWANSEMICONDUCTOR(台湾半导体)
    1A,600V,STD.GLASS PASSIVATED REC
1N4005GA0 数据手册
1N4001G - 1N4007G Taiwan Semiconductor CREAT BY ART 1A, 50V - 1000V Glass Passivated Rectifiers FEATURES - Glass passivated chip junction - High current capability, Low VF - High reliability - High surge current capability - Low power loss, high efficiency - Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC - Halogen-free according to IEC 61249-2-21 definition MECHANICAL DATA Case: DO-204AL (DO-41) DO-204AL (DO-41) Molding compound, UL flammability classification rating 94V-0 Part No. with suffix "H" means AEC-Q101 qualified Packing code with suffix "G" means green compound (halogen-free) Terminal: Pure tin plated leads, solderable per JESD22-B102 Meet JESD 201 class 2 whisker test Weight: 0.33 g (approximately) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) PARAMETER SYMBOL 1N 1N 1N 1N 1N 1N 1N 4001G 4002G 4003G 4004G 4005G 4006G 4007G UNIT Maximum repetitive peak reverse voltage VRRM 50 Maximum RMS voltage VRMS 35 70 140 280 420 560 700 V Maximum DC blocking voltage VDC 50 100 200 400 600 800 1000 V Maximum average forward rectified current IF(AV) 1 A Peak forward surge current, 8.3 ms single half sine-wave superimposed on rated load IFSM 30 A VF 1.0 V Maximum instantaneous forward voltage (Note 1) @1A Maximum reverse current @ rated VR TJ=25 °C TJ=125 °C Typical junction capacitance (Note 2) Typical thermal resistance Operating junction temperature range Storage temperature range IR 100 200 400 5 100 600 800 1000 V μA CJ 10 pF RθJA 80 °C/W TJ - 55 to +150 °C TSTG - 55 to +150 °C Note1: Pulse Test with PW=300μs, 1% Duty Cycle Note2: Measured at 1 MHz and Applied Reverse Voltage of 4.0V D.C. Document Number: DS_D1410021 Version: O15 1N4001G - 1N4007G Taiwan Semiconductor CREAT BY ART ORDERING INFORMATION PART NO. PART NO. PACKING CODE PACKING CODE SUFFIX A0 1N400xG (Note 1) PACKAGE PACKING DO-41 3,000 / Ammo box (52mm taping) DO-41 5,000 / 13" Paper reel DO-41 5,000 / 13" Paper reel (Reverse) DO-41 1,000 / Bulk packing SUFFIX R0 H G R1 B0 Note 1: "x" defines voltage from 50V (1N4001G) to 1000V (1N4007G) EXAMPLE PREFERRED PART NO. PART NO. PART NO. 1N4007GHA0G SUFFIX 1N4007G PACKING CODE PACKING CODE H SUFFIX A0 DESCRIPTION AEC-Q101 qualified Green compound G RATINGS AND CHARACTERISTICS CURVES (TA=25°C unless otherwise noted) FIG.1 MAXMUM FORWARD CURRENT DERATING CURVE FIG. 2 MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT PEAK FORWARD SURGE CURRENT(A) AVERAGE FORWARD CURRENT(A) 1.5 1 0.5 0 0 25 50 75 100 125 150 30 25 20 15 10 5 0 1 AMBIENT TEMPERATURE(oC) 10 FIG. 4 TYPICAL REVERSE CHARACTERISTICS FIG. 3 TYPICAL FORWARD CHARACTERISTICS 100 10 REVERSE LREAKAGE CURRENT (μA) INSTANTANEOUS FORWARD CURRENT (A) 100 NUMBER OF CYCLES AT 60 Hz 1 0.1 0.5 0.6 0.7 0.8 0.9 1 1.1 1.2 FORWARD VOLTAGE (V) Document Number: DS_D1410021 1.3 1.4 1.5 TJ=125°C 10 1 TJ=75°C 0.1 TJ=25°C 0.01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Version: O15 1N4001G - 1N4007G Taiwan Semiconductor CREAT BY ART FIG. 5 TYPICAL JUNCTION CAPACITANCE CAPACITANCE (pF) 100 10 f=1.0MHz Vsig=50mVp-p 1 0.1 1 10 100 REVERSE VOLTAGE (V) PACKAGE OUTLINE DIMENSIONS DO-204AL (DO-41) DIM. Unit (mm) Unit (inch) Min Max Min Max A 2.00 2.70 0.079 0.106 B 0.71 0.86 0.028 0.034 C 25.40 - 1.000 - D 4.20 5.20 0.165 0.205 E 25.40 - 1.000 - MARKING DIAGRAM P/N = Specific Device Code G= Green Compound YWW = Date Code F= Document Number: DS_D1410021 Factory Code Version: O15 1N4001G - 1N4007G Taiwan Semiconductor CREAT BY ART Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Document Number: DS_D1410021 Version: O15
1N4005GA0 价格&库存
很抱歉,暂时无法提供与“1N4005GA0”相匹配的价格&库存,您可以联系我们找货
