1N4001G - 1N4007G
Taiwan Semiconductor
CREAT BY ART
1A, 50V - 1000V Glass Passivated Rectifiers
FEATURES
- Glass passivated chip junction
- High current capability, Low VF
- High reliability
- High surge current capability
- Low power loss, high efficiency
- Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
- Halogen-free according to IEC 61249-2-21 definition
MECHANICAL DATA
Case: DO-204AL (DO-41)
DO-204AL (DO-41)
Molding compound, UL flammability classification rating 94V-0
Part No. with suffix "H" means AEC-Q101 qualified
Packing code with suffix "G" means green compound (halogen-free)
Terminal: Pure tin plated leads, solderable per JESD22-B102
Meet JESD 201 class 2 whisker test
Weight: 0.33 g (approximately)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted)
PARAMETER
SYMBOL
1N
1N
1N
1N
1N
1N
1N
4001G 4002G 4003G 4004G 4005G 4006G 4007G
UNIT
Maximum repetitive peak reverse voltage
VRRM
50
Maximum RMS voltage
VRMS
35
70
140
280
420
560
700
V
Maximum DC blocking voltage
VDC
50
100
200
400
600
800
1000
V
Maximum average forward rectified current
IF(AV)
1
A
Peak forward surge current, 8.3 ms single half sine-wave
superimposed on rated load
IFSM
30
A
VF
1.0
V
Maximum instantaneous forward voltage (Note 1)
@1A
Maximum reverse current @ rated VR
TJ=25 °C
TJ=125 °C
Typical junction capacitance (Note 2)
Typical thermal resistance
Operating junction temperature range
Storage temperature range
IR
100
200
400
5
100
600
800
1000
V
μA
CJ
10
pF
RθJA
80
°C/W
TJ
- 55 to +150
°C
TSTG
- 55 to +150
°C
Note1: Pulse Test with PW=300μs, 1% Duty Cycle
Note2: Measured at 1 MHz and Applied Reverse Voltage of 4.0V D.C.
Document Number: DS_D1410021
Version: O15
1N4001G - 1N4007G
CREAT BY ART
ORDERING INFORMATION
PART NO.
PART NO.
PACKING CODE
PACKING CODE
SUFFIX
A0
1N400xG
(Note 1)
PACKAGE
PACKING
DO-41
3,000 / Ammo box (52mm taping)
DO-41
5,000 / 13" Paper reel
DO-41
5,000 / 13" Paper reel (Reverse)
DO-41
1,000 / Bulk packing
SUFFIX
R0
H
G
R1
B0
Note 1: "x" defines voltage from 50V (1N4001G) to 1000V (1N4007G)
EXAMPLE
PREFERRED
PART NO.
PART NO.
PART NO.
1N4007GHA0G
SUFFIX
1N4007G
PACKING CODE
PACKING CODE
H
SUFFIX
A0
DESCRIPTION
AEC-Q101 qualified
Green compound
G
RATINGS AND CHARACTERISTICS CURVES
FIG.1 MAXMUM FORWARD CURRENT
DERATING CURVE
FIG. 2 MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
PEAK FORWARD SURGE CURRENT(A)
AVERAGE FORWARD CURRENT(A)
1.5
1
0.5
50
75
100
125
150
30
25
10
5
AMBIENT TEMPERATURE(oC)
10
FIG. 4 TYPICAL REVERSE CHARACTERISTICS
FIG. 3 TYPICAL FORWARD CHARACTERISTICS
100
10
REVERSE LREAKAGE CURRENT (μA)
INSTANTANEOUS FORWARD CURRENT (A)
100
NUMBER OF CYCLES AT 60 Hz
1
0.1
0.5
0.6
0.7
0.8
0.9
1
1.1
1.2
FORWARD VOLTAGE (V)
1.3
1.4
1.5
TJ=125°C
10
1
TJ=75°C
0.1
TJ=25°C
0.01
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Version: O15
1N4001G - 1N4007G
CREAT BY ART
FIG. 5 TYPICAL JUNCTION CAPACITANCE
CAPACITANCE (pF)
100
10
f=1.0MHz
Vsig=50mVp-p
1
0.1
1
10
100
REVERSE VOLTAGE (V)
PACKAGE OUTLINE DIMENSIONS
DO-204AL (DO-41)
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
2.00
2.70
0.079
0.106
B
0.71
0.86
0.028
0.034
C
25.40
1.000
D
4.20
5.20
0.165
0.205
E
25.40
1.000
MARKING DIAGRAM
P/N =
Specific Device Code
G=
Green Compound
YWW = Date Code
F=
Factory Code
Version: O15
1N4001G - 1N4007G
CREAT BY ART
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: O15
很抱歉,暂时无法提供与“1N4003GA0”相匹配的价格&库存,您可以联系我们找货
