P6KE250A-01R0
P6KE250A-01R0
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-15(DO-204AC)
    TVS DIODE
P6KE250A-01R0 数据手册
P6KE SERIES Taiwan Semiconductor CREAT BY ART 600W, 6.8V - 440V Transient Voltage Suppressor FEATURES - Excellent clamping capability - Low dynamic impedance - 600W surge capability at 10 / 1000 μs waveform - Fast response time: Typically less than 1.0ps from 0 volt to VBR for unidirectional and 5.0ns for bidirectional - Typical IR less than 1μA above 10V - UL recognized file # E-326243 - Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC - Halogen-free according to IEC 61249-2-21 DO-204AC (DO-15) MECHANICAL DATA Case: DO-204AC (DO-15) Molding compound: UL flammability classification rating 94V-0 Part No. with suffix "H" means AEC-Q101 qualified Packing code with suffix "G" means green compound (halogen-free) Terminal: Pure tin plated leads, solderable per JESD22-B102 Meet JESD 201 class 2 whisker test Weight: 0.4g (approximately) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) SYMBOL VALUE UNIT Peak power dissipation at TA=25°C, Tp=1ms (Note 1) PPK 600 W Steady state power dissipation at TL=75°C lead lengths .375", 9.5mm (Note 2) PD 5 W Peak forward surge current, 8.3 ms single half sine-wave superimposed on rated load (Note 3) IFSM 100 A TJ - 55 to +175 °C TSTG - 55 to +175 °C PARAMETER Operating junction temperature range Storage temperature range Note 1: Non-repetitive current pulse per fig. 3 and derated above TA=25°C per fig. 2 Note 2: Mounted on 5 x 5 mm copper pads to each terminal Note 3: 8.3ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per minute maximum Devices for Bipolar Applications 1. For bidirectional use C or CA suffix for types P6KE6.8 - types P6KE440 2. Electrical characteristics apply in both directions ORDERING INFORMATION PART NO. P6KExxxx (Note 1) PART NO. SUFFIX PACKING CODE PACKING CODE SUFFIX A0 H R0 G B0 PACKAGE PACKING DO-15 1,500 / Ammo box DO-15 3,500 / 13" Paper reel DO-15 1,000 / Bulk packing Note 1: "xxxx" defines voltage from 6.8V (P6KE6.8) to 440V (P6KE440) EXAMPLE EXAMPLE PART NO. P6KE56AHA0G PART NO. P6KE56A PART NO. SUFFIX H PACKING CODE A0 PACKING CODE SUFFIX G DESCRIPTION AEC-Q101 qualified Green compound Version: M1602 P6KE SERIES Taiwan Semiconductor CREAT BY ART RATINGS AND CHARACTERISTICS CURVES (TA=25°C unless otherwise noted) FIG. 1 PEAK PULSE POWER RATING CURVE FIG.2 PULSE DERATING CURVE PEAK PULSE POWER(PPP) or CURRENT(IPPM) DERATING IN PERCENTAGE(%) PPPM, PEAK PULSE POWER, KW 100 Non-repetitive pulse waveform shown in fig.3 10 1 0.1 0.1 1 10 100 1000 10000 125 100 75 50 25 0 0 tp, PULSE WIDTH, (μs) Peak value IPPM 100 Half value-IPPM/2 80 10/1000μs waveform as defined by R.E.A. 60 40 20 td 0 0 0.5 1 1.5 2 2.5 3 3.5 4 t, TIME ms IFSM, PEAK FORWARD SURGE CURRENT (A) PEAK PULSE CURRENT (%) 120 75 100 125 150 175 200 FIG. 4 MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT UNIDIRECTIONAL ONLY Pulse width(td) is defined as the point where the peak current decays to 50% of IPPM tr=10μs 50 TA, AMBIENT TEMPERATURE (°C) FIG. 3 CLAMPING POWER PULSE WAVEFORM 140 25 100 8.3ms single half sine wave 10 1 10 100 NUMBER OF CYCLES AT 60 Hz FIG. 5 TYPICAL JUNCTION CAPACITANCE CJ, JUNCTION CAPACITANCE (pF) A 10000 VR=0 1000 100 f=1.0MHz Vsig=50mVp-p Measured at stand-off voltage,Vwm 10 1 10 100 V(BR), BREAKDOWN VOLTAGE (V) Version: M1602 P6KE SERIES Taiwan Semiconductor CREAT BY ART General Part Number Nominal Voltage Breakdown Voltage Test Stand-Off (Note 1) Current Voltage VBR (V) (V) Min Max Maximum Maximum Maximum Maximum Reverse Leakage Peak Surge Clamping Voltage Temperature @ VWM Current @ IPPM Coefficient IPPM Vc of VBR (A) (V) (%/°C) IT VWM IR (mA) (V) (μA) (Note 2) P6KE6.8 6.8 6.12 7.48 10 5.50 1000 58.0 10.8 0.057 P6KE6.8A 6.8 6.46 7.14 10 5.80 1000 60.0 10.5 0.057 P6KE7.5 7.5 6.75 8.25 10 6.05 500 53.0 11.7 0.061 P6KE7.5A 7.5 7.13 7.88 10 6.40 500 55.0 11.3 0.061 P6KE8.2 8.2 7.38 9.02 10 6.63 200 50.0 12.5 0.065 P6KE8.2A 8.2 7.79 8.61 10 7.02 200 52.0 12.1 0.065 P6KE9.1 9.1 8.19 10.00 1 7.37 50 45.0 13.8 0.068 P6KE9.1A 9.1 8.65 9.55 1 7.78 50 47.0 13.4 0.068 P6KE10 10 9.00 11.00 1 8.10 10 42.0 15.0 0.073 P6KE10A 10 9.50 10.5 1 8.55 10 43.0 14.5 0.073 P6KE11 11 9.90 12.1 1 8.92 1 38.0 16.2 0.075 P6KE11A 11 10.5 11.6 1 9.40 1 40.0 15.6 0.075 P6KE12 12 10.8 13.2 1 9.72 1 36.0 17.3 0.078 P6KE12A 12 11.4 12.6 1 10.2 1 37.0 16.7 0.078 P6KE13 13 11.7 14.3 1 10.5 1 33.0 19.0 0.081 P6KE13A 13 12.4 13.7 1 11.1 1 34.0 18.2 0.081 P6KE15 15 13.5 16.5 1 12.1 1 28.0 22.0 0.084 P6KE15A 15 14.3 15.8 1 12.8 1 29.0 21.2 0.084 P6KE16 16 14.4 17.6 1 12.9 1 26.0 23.5 0.086 P6KE16A 16 15.2 16.8 1 13.6 1 28.0 22.5 0.086 P6KE18 18 16.2 19.8 1 14.5 1 23.0 26.5 0.088 P6KE18A 18 17.1 18.9 1 15.3 1 25.0 25.5 0.088 P6KE20 20 18.0 22.0 1 16.2 1 21.0 29.1 0.090 P6KE20A 20 19.0 21.0 1 17.1 1 22.0 27.7 0.090 P6KE22 22 19.8 24.2 1 17.8 1 19.0 31.9 0.092 P6KE22A 22 20.9 23.1 1 18.8 1 20.0 30.6 0.092 P6KE24 24 21.6 26.4 1 19.4 1 18.0 34.7 0.094 P6KE24A 24 22.8 25.2 1 20.5 1 19.0 33.2 0.094 P6KE27 27 24.3 29.7 1 21.8 1 16.0 39.1 0.096 P6KE27A 27 25.7 28.4 1 23.1 1 16.8 37.5 0.096 P6KE30 30 27.0 33.0 1 24.3 1 14.0 43.5 0.097 P6KE30A 30 28.5 31.5 1 25.6 1 15.0 41.4 0.097 P6KE33 33 29.7 36.3 1 26.8 1 13.0 47.7 0.098 P6KE33A 33 31.4 34.7 1 28.2 1 13.8 45.7 0.098 P6KE36 36 32.4 39.6 1 29.1 1 12.0 52.0 0.099 P6KE36A 36 34.2 37.8 1 30.8 1 12.6 49.9 0.099 P6KE39 39 35.1 42.9 1 31.6 1 11.1 56.4 0.100 P6KE39A 39 37.1 41.0 1 33.3 1 11.6 53.9 0.100 P6KE43 43 38.7 47.3 1 34.8 1 10.0 61.9 0.101 P6KE43A 43 40.9 45.2 1 36.8 1 10.6 59.3 0.101 P6KE47 47 42.3 51.7 1 38.1 1 9.2 67.8 0.101 P6KE47A 47 44.7 49.4 1 40.2 1 9.7 64.8 0.101 P6KE51 51 45.9 56.1 1 41.3 1 8.5 73.5 0.102 P6KE51A 51 48.5 53.6 1 43.6 1 8.9 70.1 0.102 P6KE56 56 50.4 61.6 1 45.4 1 7.8 80.5 0.103 P6KE56A 56 53.2 58.8 1 47.8 1 8.1 77.0 0.103 P6KE62 62 55.8 68.2 1 50.2 1 7.0 89.0 0.104 P6KE62A 62 58.9 65.1 1 53.0 1 7.4 85.0 0.104 Version: M1602 P6KE SERIES Taiwan Semiconductor CREAT BY ART General Part Number Nominal Voltage Breakdown Voltage Test Stand-Off (Note 1) Current Voltage VBR (V) (V) Min Max Maximum Maximum Maximum Maximum Reverse Leakage Peak Surge Clamping Voltage Temperature @ VWM Current @ IPPM Coefficient IPPM Vc of VBR (A) (V) (%/°C) IT VWM IR (mA) (V) (μA) (Note 2) P6KE68 68 61.2 74.8 1 55.1 1 6.4 98.0 0.104 P6KE68A 68 64.6 71.4 1 58.1 1 6.8 92.0 0.104 P6KE75 75 67.5 82.5 1 60.7 1 5.8 108 0.105 P6KE75A 75 71.3 78.8 1 64.1 1 6.1 103 0.105 P6KE82 82 73.8 90.2 1 66.4 1 5.3 118 0.105 P6KE82A 82 77.9 86.1 1 70.1 1 5.5 113 0.105 P6KE91 91 81.9 100 1 73.7 1 4.8 131 0.106 P6KE91A 91 86.5 95.5 1 77.8 1 5.0 125 0.106 P6KE100 100 90 110 1 81.0 1 4.3 144 0.106 P6KE100A 100 95 105 1 85.5 1 4.5 137 0.106 P6KE110 110 99 121 1 89.2 1 3.9 158 0.107 P6KE110A 110 105 116 1 94.0 1 4.1 152 0.107 P6KE120 120 108 132 1 97.2 1 3.6 173 0.107 P6KE120A 120 114 126 1 102 1 3.8 165 0.107 P6KE130 130 117 143 1 105 1 3.3 187 0.107 P6KE130A 130 124 137 1 111 1 3.5 179 0.107 P6KE150 150 135 165 1 121 1 2.9 215 0.108 P6KE150A 150 143 158 1 128 1 3.0 207 0.108 P6KE160 160 144 176 1 130 1 2.7 230 0.108 P6KE160A 160 152 168 1 136 1 2.8 219 0.108 P6KE170 170 153 187 1 138 1 2.5 244 0.108 P6KE170A 170 162 179 1 145 1 2.6 234 0.108 P6KE180 180 162 198 1 146 1 2.4 258 0.108 P6KE180A 180 171 189 1 154 1 2.5 246 0.108 P6KE200 200 180 220 1 162 1 2.1 287 0.108 P6KE200A 200 190 210 1 171 1 2.2 274 0.108 P6KE220 220 198 242 1 175 1 1.8 344 0.108 P6KE220A 220 209 231 1 185 1 1.9 328 0.108 P6KE250 250 225 275 1 202 1 1.7 360 0.110 P6KE250A 250 237 263 1 214 1 1.8 344 0.110 P6KE300 300 270 330 1 243 1 1.4 430 0.110 P6KE300A 300 285 315 1 256 1 1.5 414 0.110 P6KE350 350 315 385 1 284 1 1.2 504 0.110 P6KE350A 350 332 368 1 300 1 1.3 482 0.110 P6KE400 400 360 440 1 324 1 1.0 574 0.110 P6KE400A 400 380 420 1 342 1 1.1 548 0.110 P6KE440 440 396 484 1 356 1 1.0 631 0.110 P6KE440A 440 418 462 1 376 1 1.04 602 0.110 Notes: 1. VBR measure after IT applied for 300μs, IT=square wave pulse or equivalent. 2. Surge current waveform per figure. 3 and derate per figure. 2. 3. For bipolar types having VWM of 10 volts and under, the IR limit is doubled. 4. All terms and symbols are consistent with ANSI/IEEE C62.35. Version: M1602 P6KE SERIES Taiwan Semiconductor CREAT BY ART PACKAGE OUTLINE DIMENSIONS DO-204AC (DO-15) DIM. Unit (mm) Unit (inch) Min Max Min Max A 2.60 3.60 0.102 0.142 B 0.70 0.90 0.028 0.035 C 25.40 - 1.000 - D 5.80 7.60 0.228 0.299 E 25.40 - 1.000 - MARKING DIAGRAM P/N = Specific Device Code G= Green Compound YWW = Date Code F= Factory Code Note: Cathode band for uni-directional products only Version: M1602 P6KE SERIES Taiwan Semiconductor CREAT BY ART Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Version: M1602
P6KE250A-01R0 价格&库存
很抱歉,暂时无法提供与“P6KE250A-01R0”相匹配的价格&库存,您可以联系我们找货
