TS15P06G-K C2G
TS15P06G-K C2G
    TAIWANSEMICONDUCTOR(台湾半导体)
    SIP4
    BRIDGE RECT 1P 800V 15A TS-6P
TS15P06G-K C2G 数据手册
TS15P05G-K - TS15P07G-K Taiwan Semiconductor 15A, 600V - 1000V Glass Passivated Bridge Rectifier FEATURES ● ● ● ● ● KEY PARAMETERS Glass passivated junction Ideal for printed circuit board High surge current capability UL Recognized File # E-326243 Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC APPLICATIONS ● ● ● ● Switching mode power supply (SMPS) Adapters TV Monitor PARAMETER VALUE UNIT IF 15 A VRRM 600 - 1000 V IFSM 240 A TJ MAX 150 °C Package TS-6P Configuration Quad MECHANICAL DATA ● ● ● ● ● ● Case: TS-6P Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Polarity: As marked Mounting torque: 0.92 N⋅m maximum Weight: 6.5 g (approximately) TS-6P ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Repetitive peak reverse voltage VRRM TS15P 05G-K TS15P 05G 600 Reverse voltage, total rms value VR(RMS) 420 PARAMETER SYMBOL Marking code on the device Forward current Surge peak forward current, 8.3 ms single half sine-wave superimposed on rated load per diode Rating of fusing ( t
TS15P06G-K C2G 价格&库存
很抱歉,暂时无法提供与“TS15P06G-K C2G”相匹配的价格&库存,您可以联系我们找货
