TSF10U60C
TSF10U60C
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    二极管阵列 1 对共阴极 60 V 5A 通孔 TO-220-3 全封装,隔离接片
TSF10U60C 数据手册
TSF10U60C Taiwan Semiconductor 10A, 60V Low VF Trench Schottky Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Patented Trench Schottky technology Excellent high temperature stability Low forward voltage Low power loss/ high efficiency High forward surge capability Compliant RoHS Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● PARAMETER VALUE UNIT IF 10 A VRRM 60 V IFSM 150 A TJ MAX 150 °C Package ITO-220AB Configuration Dual dies Switching mode power supply (SMPS) Adapters Lighting application On-board DC/DC converter MECHANICAL DATA ● ● ● ● ● ● ● Case: ITO-220AB Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Mounting torque: 0.56 N⋅m maximum Polarity: As marked Weight: 1.70g (approximately) ITO-220AB ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TSF10U60C UNIT TSF10U60C Repetitive peak reverse voltage VRRM 60 V Reverse voltage, total rms value VR(RMS) 42 V Isolation voltage from terminal to heatsink t = 1 min VAC 2000 V Forward current Surge peak forward current, 8.3ms single half sinewave superimposed on rated load Critical rate of rise of off-state voltage IF 10 A IFSM 150 A dv/dt 10,000 V/µs Junction temperature TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: F2105 TSF10U60C Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 4 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL IF = 5A, TJ = 25°C Forward voltage per diode (1) IF = 10A, TJ = 25°C VF IF = 5A, TJ = 125°C Reverse current @ rated VR per diode (2) TJ = 25°C TJ = 125°C IR TYP MAX UNIT 0.44 0.48 V 0.54 0.62 V 0.39 0.42 V - 500 µA - 100 mA Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE PACKAGE PACKING TSF10U60C ITO-220AB 50 / Tube 2 Version: F2105 TSF10U60C Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 10 CAPACITANCE (pF) 8 6 4 1000 100 2 0 f=1.0MHz Vsig=50mVp-p 10 25 50 75 100 125 150 0.1 1 CASE TEMPERATURE (°C) TJ=150°C 10 TJ=125°C TJ=100°C 1 0.1 TJ=25°C 0.01 10 20 30 40 50 60 70 80 100 Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.3 Typical Reverse Characteristics 100 10 REVERSE VOLTAGE (V) 90 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 100 10 1 10 UF1DLW TJ=150°C T =125°C J TJ=25°C 0.1TJ=125°C 1 0.01 TJ=25°C TJ=100°C 0.001 0.1 0.4 0.0 0.3 0.2 0.5 0.4 Pulse width 300μs 1% duty cycle Pulse width 0.60.6 0.7 0.8 0.8 0.9 1.0 1 1.2 1.1 FORWARD VOLTAGE (V) 3 (A) AVERAGE FORWARD CURRENT (A) 12 Version: F2105 1.2 TSF10U60C Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS ITO-220AB MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: F2105 TSF10U60C Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: F2105
TSF10U60C 价格&库存
很抱歉,暂时无法提供与“TSF10U60C”相匹配的价格&库存,您可以联系我们找货
TSF10U60C
库存:4
