TSF30L100C – TSF30L200C
Taiwan Semiconductor
30A, 100V - 200V Trench Schottky Rectifier
FEATURES
KEY PARAMETERS
Patented Trench Schottky technology
Excellent high temperature stability
Low forward voltage
Low power loss/ high efficiency
High forward surge capability
Compliant RoHS
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
30
A
VRRM
100 - 200
V
IFSM
160
A
TJ MAX
150
°C
Package
ITO-220AB
Configuration
Dual dies
Switching mode power supply (SMPS)
Adapters
Lighting application
On-board DC/DC converter
MECHANICAL DATA
Case: ITO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Mounting torque: 0.56 N⋅m maximum
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Repetitive peak reverse voltage
VRRM
TSF30L
100C
TSF30L
100C
100
Reverse voltage, total rms value
VR(RMS)
70
PARAMETER
SYMBOL
Marking code on the device
TSF30L
120C
TSF30L
120C
120
TSF30L
150C
TSF30L
150C
150
84
105
TSF30L
UNIT
200C
TSF30L
200C
200
V
140
V
IF
30
A
IFSM
160
A
dv/dt
10,000
V/µs
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
Forward current
Surge peak forward current, 8.3ms single
half sine-wave superimposed on rated load
Critical rate of rise of off-state voltage
1
Version: C2105
THERMAL PERFORMANCE
PARAMETER
SYMBOL
Junction-to-case thermal resistance
TSF30L100C
TSF30L120C
TSF30L150C
TSF30L200C
TYP
UNIT
4.0
°C/W
4.5
°C/W
RӨJC
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
TSF30L100C
TSF30L120C
TSF30L150C
Forward voltage per diode
(1)
IF = 15A, TJ = 25°C
TSF30L200C
VF
TSF30L100C
TSF30L120C
TSF30L150C
IF = 15A, TJ = 125°C
TSF30L200C
Reverse current @ rated VR per
(2)
diode
TSF30L100C
TSF30L120C
T = 25°C
TSF30L150C J
TSF30L200C
TSF30L100C
TSF30L120C
T = 125°C
TSF30L150C J
TSF30L200C
TYP
MAX
UNIT
0.73
0.80
V
0.80
0.88
V
0.84
0.92
V
0.86
0.96
V
0.64
0.70
V
0.67
0.76
V
0.70
0.78
V
0.73
0.81
V
250
µA
100
µA
25
mA
15
mA
IR
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
TSF30LxC
ITO-220AB
50 / Tube
Notes:
1. “x” defines voltage from 100V(TSF30L100C) to 200V(TSF30L200C)
2
Version: C2105
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
30
TSF30L100C-120C
TSF30L100C
TSF30L150C-200C
10
TSF30L120C
TSF30L150C
100
TSF30L200C
5
f=1.0MHz
Vsig=50mVp-p
10
25
50
75
100
125
150
0.1
1
CASE TEMPERATURE (°C)
TJ=150°C
1
TJ=125°C
TJ=100°C
0.1
0.01
TJ=25°C
0.001
10
INSTANTANEOUS REVERSE CURRENT (mA)
INSTANTANEOUS FORWARD CURRENT (A)
100
10
40
50
60
70
100
Fig.4 Typical Forward Characteristics
80
90
100
100 10
TSF30L100C
UF1DLW
1
10
TJ=150°C
TJ=125°C
TJ=125°C
TJ=25°C
0.1
TJ=25°C
1
TJ=100°C
0.01
0.1
0.001
0.1
Pulse width 300μs
1% duty cycle
Pulse width
0.3
0.3
0.4
0.5
0.5
0.6
0.7
0.7
0.8
0.9
0.9
1
1.1
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
FORWARD VOLTAGE (V)
Fig.5 Typical Reverse Characteristics
Fig.6 Typical Forward Characteristics
Fig.3 Typical Reverse Characteristics
TSF30L100C
10
REVERSE VOLTAGE (V)
100
TSF30L120C
10
TJ=150°C
1
0.1
TJ=100°C
TJ=125°C
0.01
TJ=25°C
0.001
0.0001
10
40
50
60
70
80
90
100
3
(A)
15
1000
1.1
1.2
1.1
1.2
100 10
TSF30L120C
UF1DLW
1
TJ=150°C
10
TJ=125°C
TJ=125°C
TJ=25°C
0.1
TJ=25°C
1
TJ=100°C
0.01
0.1
0.001
0.1
(A)
25
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
35
Pulse width 300μs
1% duty cycle
Pulse width
0.3
0.3
0.4
0.5
0.7
0.5
0.6 VOLTAGE
0.7
0.8
FORWARD
(V)
0.9
0.9
1
1.1
Version: C2105
1
TJ=125°C
0.1
TJ=100°C
0.01
0.001
TJ=25°C
0.0001
40
50
60
70
80
90 100
TSF30L150C
10
UF1DLW
1
TJ=150°C
TJ=125°C
TJ=125°C
TJ=25°C
0.1
TJ=25°C
1
TJ=100°C
0.01
0.1
0.001
0.1
Pulse width 300μs
1% duty cycle
Pulse width
0.3
0.3
0.4
0.5
0.5
0.6
0.7
0.7
0.8
0.9
0.9
1.1
1
1.1
FORWARD VOLTAGE (V)
Fig.9 Typical Reverse Characteristics
Fig.10 Typical Forward Characteristics
10
TSF30L200C
1
0.1
TJ=150°C
TJ=125°C
0.01
TJ=100°C
0.001
0.0001
TJ=25°C
0.00001
10
40
50
60
70
80
90 100
(A)
TJ=150°C
100 10
100 10
TSF30L200C
10
UF1DLW
1
TJ=150°C
TJ=125°C
TJ=125°C
0.1
TJ=25°C
1
TJ=100°C
0.01
0.1
0.001
0.1
TJ=25°C
Pulse width 300μs
1% duty cycle
Pulse width
0.3
0.3
0.4
0.5
0.5
0.6
0.7
0.7
0.8
0.9
0.9
1
1.1
1.1
FORWARD VOLTAGE (V)
4
1.2
(A)
TSF30L150C
10
10
Fig.8 Typical Forward Characteristics
Fig.7 Typical Reverse Characteristics
Version: C2105
1.2
PACKAGE OUTLINE DIMENSIONS
ITO-220AB
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: C2105
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: C2105
很抱歉,暂时无法提供与“TSF30L150C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+16.429901+2.11147
- 50+7.8641350+1.01065
- 100+7.02929100+0.90336
- 500+5.56446500+0.71511
- 1000+5.057111000+0.64991
- 2000+4.696852000+0.60361
- 5000+4.615715000+0.59319
