TSI10L200CW
TSI10L200CW
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-262-3,长引线,I²Pak,TO-262AA
    二极管阵列 1 对共阴极 200 V 5A 通孔 TO-262-3,长引线,I²Pak,TO-262AA
TSI10L200CW 数据手册
TSI10L200CW Taiwan Semiconductor 10A, 200V Trench Schottky Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Patented Trench Schottky technology Excellent high temperature stability Low forward voltage Low power loss/ high efficiency High forward surge capability RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 10 A VRRM 200 V IFSM 100 A TJ MAX 150 °C 2 Package TO-262 (I PAK) Configuration Dual dies ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converter MECHANICAL DATA ● ● ● ● ● ● 2 Case: TO-262 (I PAK) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 1A whisker test Polarity: As marked Weight: 1.60g (approximately) 2 TO-262 (I PAK) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TSI10H200CW UNIT TSI10H200CW Repetitive peak reverse voltage VRRM 200 V Reverse voltage, total rms value VR(RMS) 140 V IF 10 A IFSM 100 A dv/dt 10,000 V/µs Junction temperature TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Critical rate of rise of off-state voltage 1 Version: B2104 TSI10L200CW Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 5 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL IF = 5A, TJ = 25°C Forward voltage per diode IF = 10A, TJ = 25°C (1) IF = 5A, TJ = 125°C VF IF = 10A, TJ = 125°C Reverse current @ rated VR per diode (2) TJ = 25°C TJ = 125°C IR TYP MAX UNIT 0.84 0.90 V 0.92 0.98 V 0.72 0.78 V 0.80 0.86 V - 50 µA - 5 mA Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE TSI10L200CW PACKAGE 2 TO-262 (I PAK) 2 PACKING 50 / Tube Version: B2104 TSI10L200CW Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 10 CAPACITANCE (pF) 8 6 4 100 2 f=1.0MHz Vsig=50mVp-p 10 0 25 50 75 100 125 0.1 150 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 10 TJ=150°C 0.1 TJ=125°C 0.01 TJ=100°C 0.001 0.0001 TJ=25°C 0.00001 10 20 30 40 50 60 70 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 1 10 80 90 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 100 10 10 1 0.1 UF1DLW TJ=150°C TJ=125°C TJ=125°C TJ=25°C (A) AVERAGE FORWARD CURRENT (A) 12 TJ=100°C 1 TJ=25°C 0.01 0.1 0.001 0.2 0.3 Pulse width 300μs 1% duty cycle Pulse width 0.4 0.4 0.5 0.6 0.6 0.8 0.7 0.8 1.0 0.9 1.2 1 1.1 FORWARD VOLTAGE (V) 3 Version: B2104 1.2 TSI10L200CW Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS 2 TO-262 (I PAK) MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: B2104 TSI10L200CW Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: B2104
TSI10L200CW 价格&库存
很抱歉,暂时无法提供与“TSI10L200CW”相匹配的价格&库存,您可以联系我们找货
