TSI20H100CW – TSI20H200CW
Taiwan Semiconductor
20A, 100V - 200V Trench Schottky Rectifier
FEATURES
KEY PARAMETERS
Patented Trench Schottky technology
Excellent high temperature stability
Low forward voltage
Low power loss/ high efficiency
High forward surge capability
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
A
VRRM
100 - 200
V
IFSM
150
A
TJ MAX
150
°C
2
Package
TO-262 (I PAK)
Configuration
Dual dies
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converter
MECHANICAL DATA
2
Case: TO-262 (I PAK)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 1A whisker test
Polarity: As marked
Weight: 1.60g (approximately)
2
TO-262 (I PAK)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Repetitive peak reverse voltage
VRRM
TSI20H
100CW
TSI20H
100CW
100
Reverse voltage, total rms value
VR(RMS)
70
PARAMETER
SYMBOL
Marking code on the device
Forward current
Surge peak forward current, 8.3ms single half
sine wave superimposed on rated load
Critical rate of rise of off-state voltage
TSI20H
120CW
TSI20H
120CW
120
TSI20H
150CW
TSI20H
150CW
150
84
105
TSI20H
UNIT
200CW
TSI20H
200CW
200
V
140
V
IF
A
IFSM
150
A
dv/dt
10,000
V/µs
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
1
Version: E2104
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
3.8
°C/W
Junction-to-case thermal resistance
RӨJC
2.8
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
TYP
MAX
UNIT
0.57
V
0.62
V
0.72
V
TSI20H200CW
0.77
V
TSI20H100CW
0.67
0.79
V
0.78
0.87
V
0.81
0.90
V
0.83
0.93
V
0.50
V
0.53
V
0.58
V
TSI20H200CW
0.62
V
TSI20H100CW
0.59
0.68
V
0.63
0.72
V
0.66
0.75
V
0.68
0.78
V
200
µA
100
µA
25
mA
15
mA
TSI20H100CW
TSI20H120CW
TSI20H150CW
TSI20H120CW
TSI20H150CW
Forward voltage per diode
(1)
IF = 10A, TJ = 25°C
TSI20H200CW
VF
TSI20H100CW
TSI20H120CW
TSI20H150CW
TSI20H120CW
TSI20H150CW
Reverse current @ rated VR
(2)
per diode
IF = 5A, TJ = 25°C
TSI20H200CW
TSI20H100CW
TSI20H120CW
TSI20H150CW
TSI20H200CW
TSI20H100CW
TSI20H120CW
TSI20H150CW
TSI20H200CW
IF = 5A, TJ = 125°C
IF = 10A, TJ = 125°C
TJ = 25°C
IR
TJ = 125°C
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
TSI20HxCW
PACKAGE
2
TO-262 (I PAK)
PACKING
50 / Tube
Notes:
1. "x" defines voltage from 100V (TSI20H100CW) to 200V (TSI20H200CW)
2
Version: E2104
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
TSI20H100CW
CAPACITANCE (pF)
15
10
1000
TSI20H120CW
TSI20H150CW
100
TSI20H200CW
5
f=1.0MHz
Vsig=50mVp-p
10
75
100
125
0.1
150
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
100
10
TJ=150°C
1
TJ=125°C
0.1
TJ=100°C
0.01
0.001
TJ=25°C
0.0001
10
40
50
60
70
80
90 100
10010
TSI20H100CW
10
UF1DLW
1
0.1
TJ=150°C
TJ=125°C
TJ=125°C
TJ=25°C
0.01
0.1
0.001
0.1
0.3
Pulse width 300μs
1% duty cycle
Pulse width
0.3
0.4
TSI20H120CW
TJ=150°C
1
TJ=125°C
TJ=100°C
0.01
0.001
TJ=25°C
10
40
50
60
70
80
90
0.5
0.6
0.7
0.7
0.8
0.9
0.9
1.1
1
1.1
1.2
1.1
1.2
Fig.6 Typical Forward Characteristics
100
0.0001
0.5
FORWARD VOLTAGE (V)
Fig.5 Typical Reverse Characteristics
0.1
TJ=25°C
TJ=100°C
1
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
10
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
TSI20H100CW
10
(A)
25
100
10010
TSI20H120CW
10
UF1DLW
1
0.1
TJ=150°C
TJ=125°C
TJ=125°C
TJ=100°C
1
TJ=25°C
0.01
0.1
0.1
0.001
0.3
TJ=25°C
(A)
AVERAGE FORWARD CURRENT (A)
25
Pulse width 300μs
1% duty cycle
Pulse width
0.3
0.4
0.5
0.5
0.6
0.7
0.7
0.8
0.9
0.9
1.1
1
FORWARD VOLTAGE (V)
3
Version: E2104
Fig.8 Typical Forward Characteristics
TJ=150°C
1
TJ=125°C
0.1
TJ=100°C
0.01
0.001
TJ=25°C
0.0001
10
40
50
60
70
80
90 100
100 10
TSI20H150CW
10
UF1DLW
1
TJ=150°C
TJ=125°C
TJ=100°C
1
0.01
0.1
0.001
0.1
0.3
TJ=25°C
Pulse width 300μs
1% duty cycle
Pulse width
0.3
0.4
TSI20H200CW
TJ=150°C
TJ=125°C
0.01
TJ=100°C
0.001
TJ=25°C
0.0001
10
40
50
60
70
80
0.5
0.6
0.7
0.7
0.8
0.9
0.9
1.1
1
1.1
1.2
1.1
1.2
Fig.10 Typical Forward Characteristics
10
0.1
0.5
FORWARD VOLTAGE (V)
Fig.9 Typical Reverse Characteristics
1
TJ=25°C
TJ=125°C
0.1
90 100
100 10
TSI20H200CW
10
1
0.1
UF1DLW
TJ=150°C
TJ=125°C
TJ=125°C
TJ=100°C
1
0.01
0.1
0.001
0.1
0.3
TJ=25°C
(A)
TSI20H150CW
(A)
10
Fig.7 Typical Reverse Characteristics
TJ=25°C
Pulse width 300μs
1% duty cycle
Pulse width
0.3
0.4
0.5
0.5
0.6
0.7
0.7
0.8
0.9
0.9
1.1
1
FORWARD VOLTAGE (V)
4
Version: E2104
PACKAGE OUTLINE DIMENSIONS
2
TO-262 (I PAK)
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: E2104
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: E2104
很抱歉,暂时无法提供与“TSI20H120CW”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 4000+11.176384000+1.43462
