33-5242-6-10-05-PC0
33-5242-6-10-05-PC0
    TALLYSMANWIRELESS
    GPS/ GLONASS SMART ANTENNA, MAGN
33-5242-6-10-05-PC0 数据手册
TALLYSMAN - PART NUMBER ORDERING GUIDE For all Embedded Antennas Part Number Structure : Assigned by Tallysman for custom tuned antennas Connector 33-aaaa-xx-yyyy-zz Product Valid Connectors 00 = SMA straight male (plug) 01 = TNC female 02 = MCX straight male (plug) 03 = MMCX straight male (plug) 04 = SMB straight male (plug) 05 = MCX right angle male (plug) 06 = MMCX right angle male (plug) cable length in mm 10 = SMA Right Angle ** 11 = Reverse polarity SMA** 12 = Waterproof SMA** 13 = SSMA ** 20 = SMA Female 35 = MMBX (RG174 cable)** 22 = R/A QMA** 36 = MMBX (RG316 cable)** 23 = SMP** 37 = R/A male SMB** 24 = SMC Male 25 = SMC Straight Female 15 = TNC male (plug) 26 = SMB Straight Female 16 = N-Type Male** 27 = MCX Female Straight 17 = BNC Male** 28 = SSMCX Straight Plug** 08 = H.FL (female)** (micro-coax cable) 18 = FME** 29 = R/A SSMCX Plug ** 09 = U.FL (micro-coax cable) 19 = MMCX Female 30 = SMB with Overmold** 33 = MMCX straight male (Cinch Connectivity) ** 34x = FAKRA (replace “x” with colour code)** Cable length tolerances: 5m: ±50mm Maximum cable lengths: 5m for RG174 , 1450mm for micro-coax ** Premiums apply. Please check with your Distributor For the TW2000 Family of Products Part Number Structure : Connector 33-2aaa-xx-yyyy Product cable length in mm Valid Connectors Without Cable: 07 = SMA female (jack) bulkhead With Cable (max length 5m): 00 = SMA straight male (plug) 01 = TNC female 02 = MCX straight male (plug) 03 = MMCX straight male (plug) 04 = SMB straight male (plug) 05 = MCX right angle male (plug) 06 = MMCX right angle male (plug) 10 = SMA Right Angle ** 11 = Reverse polarity SMA** 12 = Waterproof SMA** 13 = SSMA ** 15 = TNC male (plug) 16 = N-Type Male** 17 = BNC Male** 18 = FME** 19 = MMCX Female 31 = SMC R/A Female ** 20 = SMA Female 35 = MMBX (RG174 cable)** 22 = R/A QMA** 23 = SMP** 37 = R/A male SMB** 24 = SMC Male 25 = SMC Straight Female 26 = SMB Straight Female 27 = MCX Female Straight 28 = SSMCX Straight Plug** 29 = R/A SSMCX Plug ** 30 = SMB with Overmold** 33 = MMCX straight male (Cinch Connectivity)** 34x = FAKRA (replace “x” with colour code)** ** Premiums apply. Please check with your Distributor NOTE: To order any of the TW2000 antennas with NO MAGNETS, add “NM” after the Product (eg. 33-2410NM-00-3000). To add Adhesive Tape to the bottom of the same, add “AT” after the Product Name (eg. 33-2410AT-07). If you desire both, then use NMAT, eg. 33-2410NMAT-07. Cable length tolerances: 5m: ±50mm Maximum cable length = 5m Page 1 of 6 November 2019 TALLYSMAN - PART NUMBER ORDERING GUIDE For the TW3000 Family of Products For TW3865, TW3870E, TW3872E, TW3967 & TW3972E - refer to Page 1 Embedded Antennas Part Number Structure : Modifier cable length in mm 4 digits (if applicable) Connector 33-3aaabb-xx-yy-zzzz Product radome shape and colour Valid Connectors Without Cable: 01 = TNC female 14 = N-Type female With Cable (max length 5m): 00 = SMA straight male (plug) 01 = TNC female 02 = MCX straight male (plug) 03 = MMCX straight male (plug) 04 = SMB straight male (plug) 05 = MCX right angle male (plug) 06 = MMCX right angle male (plug) 10 = SMA Right Angle ** 11 = Reverse polarity SMA** 12 = Waterproof SMA** 13 = SSMA ** 15 = TNC male (plug) 16 = N-Type Male** 17 = BNC Male** 18 = FME** 19 = MMCX Female NMO = NMO mount 20 = SMA Female 31 = SMC R/A Female ** 22 = R/A QMA** 35 = MMBX (RG174 cable)** 23 = SMP** 24 = SMC Male 37 = R/A male SMB** 25 = SMC Straight Female 26 = SMB Straight Female 27 = MCX Female Straight 28 = SSMCX Straight Plug** 29 = R/A SSMCX Plug ** 30 = SMB with Overmold** 33 = MMCX straight male (Cinch Connectivity)** 34x = FAKRA (replace “x” with colour code)** ** Premiums apply. Please check with your Distributor Modifiers: ST = short thread AJ = Anti-Jamming configuration** Cable length tolerances: 5m: ±50mm Maximum cable length = 5m Radome Codes: 00 = Dark grey Conical 10 = Dark grey low profile 20 = Red low profile 01 = White Conical 11 = White low profile For AJ Antennas: W = White G=Grey (For TW3142, TW3442, TW3742, and TW3752 only) For the TW4000 Family of Products Part Number Structure : Connector 33-4aaa-xx-yyyy Product Valid Connectors 00 = SMA straight male (plug) 01 = TNC female 02 = MCX straight male (plug) 03 = MMCX straight male (plug) 04 = SMB straight male (plug) 05 = MCX right angle male (plug) 06 = MMCX right angle male (plug) 10 = SMA Right Angle ** 11 = Reverse polarity SMA** cable length in mm (max length 5000mm) 12 = Waterproof SMA** 13 = SSMA ** 15 = TNC male (plug) 16 = N-Type Male** 17 = BNC Male** 18 = FME** 19 = MMCX Female 20 = SMA Female 22 = R/A QMA** 31 = SMC R/A Female ** 23 = SMP** 35 = MMBX (RG174 cable)** 24 = SMC Male 25 = SMC Straight Female 37 = R/A male SMB** 26 = SMB Straight Female 27 = MCX Female Straight 28 = SSMCX Straight Plug** 29 = R/A SSMCX Plug ** 30 = SMB with Overmold** 33 = MMCX straight male (Cinch Connectivity) ** 34x = FAKRA (replace “x” with colour code)** ** Premiums apply. Please check with your Distributor NOTE: To order any of the TW4000 antennas with NO MAGNETS, add “NM” after the Product (eg. 33-4421NM-00-3000). To add Adhesive Tape to the bottom of the same, add “AT” after the Product Name (eg. 33-4421AT-00-3000). If you desire both, then add them together, eg. 33-4421NMAT-00-3000 Cable length tolerances: 5m: ±50mm Page 2 of 6 November 2019 TALLYSMAN - PART NUMBER ORDERING GUIDE For the TW5340 / TW5341 Part Number Structure : radome type and colour 33-534w- x-yy-zz Product Cable Length w = Type 0 = standard 1 = non-magnetic x = Voltage and interface: 1 = 5V, RS232 2 = 5V, CMOS 3 = 3.3V, CMOS 4 = 5V, RS232 6 = 12-36V, RS232 Radome Codes (yy): 00 = Dark grey Conical 10 = Dark grey low profile 01 = White Conical 11 = White low profileRa- 00 = Dark grey Conical 10 = Dark grey low profile 01 = White Conical 11 = White low profile dome Codes (yy): Cable Length (zz) For the TW5342 / TW5242 For TW5342 : 33-5342-6-10-05 -ccc (ccc custom configuration to be assigned by Tallysman) For TW5242: 33-5242-6-10-05 -ccc (ccc custom configuration to be assigned by Tallysman) 6 = 12-36V, RS232, 10 = Dark grey low profile radome 05 = 5m cable For the VP6000 Family of Products Part Number Structure : 33-6abbcd-ee-gg a = Covered Frequencies: 0 = All GNSS frequencies + L-Band (1525 - 1559 MHz) 2 = L1/L2, G1/G2, B1/B2, E1 + L-Band 3= L1/L2/L5, G1/G2/G3, B1/B2, E1/E5a+b c = Base Type 0 = Standard base d = Options bb = LNA Gain 35 = 35dB 50 = 50dB 0 = No options ee = connector types: 01 = TNC Female 14 = N-Type Female ** ** Premiums apply. Please check with your Distributor. gg = radome: 01 = White Conical Example: 33-605000-01-11 11 = White Flat top Is an antenna which covers all GNSS frequencies + L-Band, provides, 50 dB of gain, uses a standard base, with a TNC female connector and a white flat top radome. Page 3 of 6 November 2019 TALLYSMAN - PART NUMBER ORDERING GUIDE For the VC6000 Family of Products Part Number Structure : Where x= 33-VC6xyy-zz 1 = All GNSS Signals yy= 35 = 35dB amplifier 50 = 50dB amplifier zz= 01 = TNC (f ) connector 14 = N-Type connector PN for short SCIGN Radome = 24-0053-0 For Housed Helical Family of Products Part Numbers : HC600: 33-HC600 HC771: 33-HC771-28 (28dB LNA) HC871: 33-HC871-28 (28dB LNA) HC872: 33-HC872-28 ( for 28dB LNA) 33-HC872-35 (for 35dB LNA) HC882: 33-HC882-28 ( for 28dB LNA) 33-HC882-35 (for 35dB LNA) HC975: 33-HC975-28 ( for 28dB LNA) 33-HC975-35 (for 35dB LNA) For Embedded Helical Family of Products Part Numbers: HC600E: 33-HC600E-xx-yyyy HC771E: 33-HC771E-xx-yyyy HC871E: 33-HC871E-28 -xx-yyyy (28dB LNA) 33-HC871E-35-xx-yyyy (35dB LNA) HC872E: 33-HC872E-28-xx-yyyy (28dB LNA) 33-HC872E-35-xx-yyyy (35dB LNA) HC882E: 33-HC882E-28-xx-yyyy (28dB LNA) 33-HC882E-35-xx-yyyy (35dB LNA) HC975E: 33-HC975E-28-xx-yyyy (28dB LNA) 33-HC975E-35-xx-yyyy (35dB LNA) Where xx= connector type (refer to Page 1 Embedded section for options) Where yyyy = cable length in mm (refer to Page 1 Embedded section for options) Page 4 of 6 November 2019 TALLYSMAN - PART NUMBER ORDERING GUIDE For the TW7000 Family of Products Part Number Structure : Connector 33-7aaa-xx-yyyy Product cable length in mm Valid Connectors Without Cable: 07 = SMA female (jack) bulkhead With Cable (max length 5m): 00 = SMA straight male (plug) 01 = TNC female 02 = MCX straight male (plug) 03 = MMCX straight male (plug) 04 = SMB straight male (plug) 05 = MCX right angle male (plug) 06 = MMCX right angle male (plug) 10 = SMA Right Angle ** 11 = Reverse polarity SMA** 12 = Waterproof SMA** 13 = SSMA ** 15 = TNC male (plug) 16 = N-Type Male** 17 = BNC Male** 18 = FME** 19 = MMCX Female 31 = SMC R/A Female ** ** Premiums apply. Please check with your Distributor 20 = SMA Female 35 = MMBX (RG174 cable)** 22 = R/A QMA** 23 = SMP** 37 = R/A male SMB** 24 = SMC Male 25 = SMC Straight Female 26 = SMB Straight Female 27 = MCX Female Straight 28 = SSMCX Straight Plug** 29 = R/A SSMCX Plug ** 30 = SMB with Overmold** 33 = MMCX straight male (Cinch Connectivity) ** 34x = FAKRA (replace “x” with colour code)** NOTE: To order any of the TW7000 antennas with NO MAGNETS, add “NM” after the Product (eg. 33-7970NM-00-3000). To add Adhesive Tape to the bottom of the same, add “AT” after the Product Name (eg. 33-7970AT-07). If you desire both, then use NMAT, eg. 33-7970NMAT-07. Cable length tolerances: 5m: ±50mm Maximum cable length = 5m For the TW8000 Family of Products Part Number Structure : Connector 33-8aaa-xx-yyyy Product Valid Connectors 00 = SMA straight male (plug) 01 = TNC female 02 = MCX straight male (plug) 03 = MMCX straight male (plug) 04 = SMB straight male (plug) 05 = MCX right angle male (plug) 06 = MMCX right angle male (plug) 10 = SMA Right Angle ** 11 = Reverse polarity SMA** cable length in mm (max length 5000mm) 12 = Waterproof SMA** 13 = SSMA ** 15 = TNC male (plug) 16 = N-Type Male** 17 = BNC Male** 18 = FME** 19 = MMCX Female 20 = SMA Female 22 = R/A QMA** 23 = SMP** 35 = MMBX (RG174 cable)** 24 = SMC Male 25 = SMC Straight Female 37 = R/A male SMB** 26 = SMB Straight Female 27 = MCX Female Straight 28 = SSMCX Straight Plug** 29 = R/A SSMCX Plug ** 30 = SMB with Overmold** 33 = MMCX straight male (Cinch Connectivity)** ** Premiums apply. Please check with your Distributor NOTE: To order any of the TW8000antennas with NO MAGNETS, add “NM” after the Product (eg. 33-8829NM-00-3000). To add Adhesive Tape to the bottom of the same, add “AT” after the Product Name (eg. 33-8829AT-00-3000). If you desire both, then add them together, eg. 33-8829NMAT-00-3000 Cable length tolerances: 5m: ±50mm Page 5 of 6 November 2019 TALLYSMAN - PART NUMBER ORDERING GUIDE For the VeroStar Family of Products Part Number Structure : Connector 33-60aa-xx-yz Product radome/base Valid Connectors 01 = TNC female Radome Codes (y): W = White Basae Codes (z): R = Red Page 6 of 6 November 2019
33-5242-6-10-05-PC0 价格&库存
很抱歉,暂时无法提供与“33-5242-6-10-05-PC0”相匹配的价格&库存,您可以联系我们找货
