23-0067-0
23-0067-0
    TALLYSMANWIRELESS
    ALUMINUM GROUND PLANE
23-0067-0 数据手册
Affordable Precision GNSS Antennas What is your application? We can help! Precision OEM and Housed: Single, Dual, Triple and Full-Band antennas with optional L-Band support Accutenna®, Helical, VeroStar™, and VeraPhase® Technologies www.tallysman.com E: info@tallysman.com ■ T: +1 613 591-3131 Accutenna® Technology 5 4 3 2 1 0 -1 -2 -3 -4 Provides low axial ratio and high multipath signal rejection. Suitable for the most demanding applications Features • Lightweight Single, Dual, Triple, and L-Band Corrections -5 -4 -3 -2 -1 0 1 X (mm) 2 3 Y (mm) Tight Phase Centre 4 0 • Patented Accutenna® Technology -5 • Pre-filtering options available -10 -15 • Antenna customization (tuning, cables, connectors, radomes) -20 -25 -30 • Short lead times -35 -40 Learn More: accutenna.tallysman.com -45 -150 -100 -50 0 50 ϴ (degrees) 100 150 Right and Left CP Magnitude in dB on 60 Phi Cuts Great X-Pol Rejection • Very low-current options TW1700 Series TW1800 Series TW2000 Series TW3000 Series Embedded Single Band Antennas Embedded Dual Band Antennas Single Band Antennas Single, Dual, and Triple Band Antennas TW3000 Series TW4000 Series TW7000 Series TW8000 Series Embedded Single, Dual, and Triple Band Antennas Single Band Antennas Dual and Triple Band Antennas Dual Band Antennas www.tallysman.com Helical Technology Unprecedented performance in a lightweight, military grade IP69K compliant form factor Features • Provides Single, Dual, Triple, and L-Band coverage • Extremely lightweight (5g (OEM) - 37g) • Novel Helical element • Excellent axial ratio HC600 HC871 HC975 Iridium Antenna Dual Band Antenna Triple Band Antenna + L-Band • Low noise amplifier and pre-filter Learn More: helical.tallysman.com • Embedded models coming soon Model HC600 HC771 HC871 HC872 HC882 HC975 Frequencies Iridium L1, G1, E1, B1 L1/L2, G1/G2, E1, B1 L1/L2, G1/G2, E1, B1, L-Band Corrections L1/L2, G1/G2/G3, E1/E5b, B1/B2, L-Band Corrections L1/L2/L5, G1/G3, E1/E5a/E5b, B1/B2/B2a, L-Band Corrections Mounting Surface Mount / Direct Screw Surface Mount / Direct Screw Surface Mount / Direct Screw Surface Mount / Direct Screw Surface Mount / Direct Screw Surface Mount / Direct Screw VeroStar™ Technology Precise, accurate, robust, lightweight survey grade antenna Features • Patent pending innovative Full Band Antenna element VeroStar™ Full Band and L-Band Antenna • Models provide full GNSS Band and L-Band support • Excellent radiating pattern with low roll-off for excellent low elevation tracking • Tight Phase Centre (±2 mm) • Excellent axial ratio for improved multipath rejection • Innovative low-noise amplifier with superior out of band filtering • Waterproof with IP69K compliance • Embedded models coming soon E: info@tallysman.com ■ T: +1 613 591-3131 Learn More: verostar.tallysman.com Model VSP600L VSP610 VSP620 VSP630 VSP650L Frequencies All Bands, L-Band Corrections L1, G1, E1, B1 L1/L2, G1/G2, E1, B1 L1/L2/L5, G1/G3, E1/E5a/E5b, B1/B2/B2a L1/L5, G1, E1/E5a, B1/B2a, L-Band Corrections Mounting Pole / Pipe Pole / Pipe Pole / Pipe Pole / Pipe Pole / Pipe VeraPhase® Technology Features • Patented Full GNSS Bandwidth Antenna • ± 35-50dB gain models available • Extremely tight phase centre variation (±1 mm) and excellent PCV repeatability • TNC or N connector • Exceptionally low axial ratio from Zenith to Horizon (< 2dB) resulting in excellent multipath rejection • Innovative low noise amplifier and filter to mitigate Ligado and LTE Model VP6000 VP6100 VP6200 VP6300 VP6000 Series VeraPhase® Antennas Frequencies L1/L2/L5, G1/G2/G3, E1/E5a/E5b/E6, B1/B2/B2a/B3, L6, L5, L-Band Corrections L1/L2/L5, G1/G2/G3, E1/E5a/E5b/E6, B1/B2/B2a/B3, L6, L5 L1/L2, G1/G2/G3, E1/E5b, B1/B2, L-Band Corrections L1/L2/L5, G1/G2/G3, E1/E5a/E5b, B1/B2 Mounting Standard Survey Mount Standard Survey Mount Standard Survey Mount Standard Survey Mount VeraChoke® Technology Features • Efficient VeraPhase Antenna element • 50dB LNA gain • Three dimensional choke ring to mitigate multipath • N-Type connector • Available with or without SCIGN radome • Extremely tight phase centre variation (±0.5 mm) and excellent PCV repeatability Model VC6050 VC6050 VeraChoke® Antenna Frequencies L1/L2/L5, G1/G2/G3, E1/E5a/E5b/E6, B1/B2/B2a/B3, L6, L5, L-Band Corrections Mounting Standard Survey Mount Learn More: vera.tallysman.com About Tallysman: With global headquarters and manufacturing in Ottawa, Canada, Tallysman is a leading manufacturer of high-precision antennas and components for Global Navigation Satellite System (GNSS) applications. Tallysman’s mission is to support the needs of a new generation of positioning systems by delivering unprecedented antenna precision at competitive prices. Learn more at www.tallysman.com Contact us: info@tallysman.com T: +1 613 591-3131 © 2019 Tallysman Inc. All rights reserved. Tallysman, the “When Precision Matters” tag line and the Tallysman logo are trademarks or registered trademarks of Tallysman Inc. and/or its affiliates in Canada and certain other countries. All other trademarks mentioned in this document are the property of their respective owners. The information presented is subject to change without notice. Tallysman assumes no responsibility or any errors or omissions in this document. Tallysman Wireless Inc. hereby disclaims any or all warranties and liabilities of any kind. Tallysman-Product-Brochure-EN-v6.0 EN www.tallysman.com
23-0067-0 价格&库存
很抱歉,暂时无法提供与“23-0067-0”相匹配的价格&库存,您可以联系我们找货
