32-0164-01
32-0164-01
    TALLYSMANWIRELESS
    1 TO 4 SMART SPLITTER TNC
32-0164-01 数据手册
TW164 TW164 1-to-4 Port Smart Power GNSS Signal Splitter Frequency Coverage: Full GNSS Spectrum Overview The Tallysman TW164 is a profe ssional-grade full GNSS band signal splitte r that connects one ante nna up to four re ce ive rs, and supports GPS/QZSS-L1/L2/L5, QZSS-L6, GLONASS-G1/G2/G3, Be iDou-B1/B2/B2a/B3, Galile o-E1/E5a/E5b/E6, NavIC-L5, and LBand correction services. GNSS has be come a critical compone nt in safe ty, se curity, timing, and infrastructure applications, all of which re quire ve ry high availability. As a re sult, re silie nt fault-tolerant components are essential to avoid service interruptions. The design of first-generation GNSS signal splitters suffered from a single point of failure: only one attache d re ce ive r powe re d the splitte r and the ante nna. If this re ce ive r faile d or was unplugged, all attached receivers also failed. Tallysman’s curre nt-ge ne ration TW164 Smart Powe r GNSS signal splitte r provide s two additional key features: First, it acce pts powe r from all attache d GNSS re ce ive rs and se le cts powe r from a receiver using the following protocol. Port #1 is given priority if its voltage is within the specified range (3.3 - 12.5 VDC). Howe ve r, if port #1’s re ce ive r is disconne cte d or if its re ce ive r powe r goes below the under-voltage or above the over-voltage specification, the TW164 will switch to the next port in numerical order, as long as its power and voltage are within the expected range. The switching and port selection is, therefore, deterministic. Second, if the antenna fails and does not draw current, the TW164 will provide all connectors with a current draw lower than 1 mA, indicating an antenna fault. The TW164 offe rs the be st in-class pe rformance in te rms of noise figure , isolation, and linearity. In addition, it is packaged in a robust, compact, lightweight, and water-proof (IP67) corrosion-protected aluminum housing. The TW164 is available with e ithe r TNC or type -N conne ctors and offe rs standard gain to compensate for signal-splittingloss. It is recommended that unused ports should be terminated with a 50 Ohm load. Applications Features Benefits • GNSS signal distribution • GNSS receiver testing • High-availability applications • Network and infrastructure timing • Accepts power from all attached receivers • Automatically switches on power failure of one receiver • Antenna failure detection/indication • Rugged military-grade aluminum enclosure • Amplification to compensate for signal-splitting loss • Very low noise figure • IP67-compliant • Allows up to four GNSS receivers to share a single antenna • Fits in-line with antenna cable • Robust package • Ideal for harsh environments About Tallysman: With global headquarters and manufacturing in Ottawa, Canada, Tallysman is a leading manufacturer of high-precision antennas and components for Global Navigation Satellite System (GNSS) applications. Tallysman’s mission is to support the needs of a new generation of positioning systems by delivering unprecedented antenna precision at competitive prices. Learn more at www.tallysman.com Revision: 1.0 Contact us: info@tallysman.com T: +1 613 591-3131 TW164 1-to-4 Port Smart Power GNSS Signal Splitter Frequency Coverage: Full GNSS Spectrum Electrical Specifications - Tested at 25°C unless othwerwise specified Minimum Typical Maximum Units Frequency Range Bandwidth supported Conditions / Description 1100 - 1700 MHz Gain Measured within range: -40 °C to 85 °C -1.0 0.0 1.0 dB Impedance - - 50.0 - Ω Noise Figure All Receiver Ports - 3.6 4.0 dB Output Isolation - 42.0 - - dB Input/Output SWR - - 1.3:1 | 1.1:1 1.5:1 | 1.2:1 ratio Input Gain Compression Point (P1dB) Gain = 0 dB -20.0 -17.0 -14.0 dBm 3rd Order Intercept (IIP3) Gain = 0 dB -10.0 -7.0 -4.0 dBm RF Input (Damage Threshold) Maximum RF Input without damage - - 5.0 dBm Amplitude Balance Between Ports - 0.1 0.5 dB Phase Balance Between Ports - 2.0 5.0 degrees (°) DC In DC input on any port 3.3 - 12.5 VDC Receiver Over-voltage - 12.7 14.9 16.9 VDC Receiver Under-voltage - 2.3 2.5 2.8 VDC Splitter Current Current consumed by splitter - 15.0 25.0 mA Antenna Through Current Maximum current provided to the antenna - - 230.0 mA Antenna to Ports 1.0 1.4 2.0 ns Adajcent Ports 0.0 0.3 0.5 ns Opposite Ports 0.0 0.5 1.0 ns Parameter Group Delay Variation Mechanical Diagram Mechanicals Size 117.0 mm (l.) x 111.6 mm (w.) x 38.0 mm (h.) Weight 405 g (type-N connectors) or 280 g (TNC connectors) Connectors 5x TNC (female) or 5x type-N (female) Enclosure military-grade corrosion-protected aluminum (6061-T6) Evironmental Operating Temperature -40 °C to 85 °C Storage Temperature -50 °C to 95 °C Vibration - Shock - Salt Fog - IEC 60529 - IP Rating IEC-60529- IP67 (enclosure) Compliance RoHS, REACH and WEEE, EN60950-1, RED / CE Certified MIL-STD-810, FCC Part 15B and R&TTE equivalent. Ordering Information Warranty Parts and Labour 3-year standard warranty Part Number 32-0164-xx where xx = connector: 14 = type-N (female) | 01 = TNC (female) Please refer to our Ordering Guide to review available radomes and connectors at: https://www.tallysman.com/resource/tallysman-ordering-guide/ © 2019 Tallysman Inc. All rights reserved. Tallysman, the “When Precision Matters” tag line and the Tallysman logo are trademarks or registered trademarks of Tallysman Inc. and/or its affiliates in Canada and certain other countries. All other trademarks mentioned in this document are the property of their respective owners. The information presented is subject to change without notice. Tallysman assumes no responsibility for any errors or omissions in this document. Tallysman Wireless Inc. hereby disclaims any or all warranties and liabilities of any kind. Revision: 1.0 www.tallysman.com
32-0164-01 价格&库存
很抱歉,暂时无法提供与“32-0164-01”相匹配的价格&库存,您可以联系我们找货
