ENOCEAN-MANGOH
ENOCEAN-MANGOH
    SIERRAWIRELESS
    EnOcean 转 FX30,mangOH 接口 FX30,mangOH 平台评估扩展板
ENOCEAN-MANGOH 数据手册
Talon EnOcean for Sierra mangOH/FX30 “SMART VIEW”IoTbyExpansion Talon Communications EnOcean Gateway: Self Powered IoT Sensors EnOcean IoT Expansion The mangOH EnOcean Expansion Board brings Self Powered Sensor connectivity to the Sierra Wireless mangOH IoT platform in a small QSFP+ form factor. The Talon EnOcean extender offers easy integration into the mangOH and FX30 platforms and is targeted as a simple, flexible, and low-cost expansion solution. A variety of EnOcean sensor devices can easily be connected to mangOH/FX30 platform. Talon’s EnOcean Expansion Board includes options for built in Chip antenna or u.fl connector for FX30 applications. FX30 kit includes FX30 Faceplate and u.fl to SMA cable. Development Environment The Sierra mangOHTM IoT platform is based on Legato open source Linux which is designed to simplify embedded IoT development. Legato has everything you need to connect the IoT quickly: - Programming language APIs – dev tools and APIs to easily write software components and specify how apps will use them. - Target runtime environment – set of daemon processes cooperatively implement execution sandboxes, secure IPC, fault monitoring. - Development and build tools – target, host, and build tools to create apps ready for deployment to your devices. EnOcean IoT Module Features Features • 902 MHz North America Version • 868 MHz European Version • Certifications include: FCC, IC, CE/RED, ARIB • EnOcean Alliance (ISO/IEC 14543-3-1X) • On board Chip Antenna or u.fl coax connector • 125Kbps OTA Data Rate • Active Current 25mA, Sleep 50uA • Simple UART Interface - Documentation and automated tests – documentation and automated tests ready to use. Applications With the intuitive suite of EnOcean development tools it is a straightforward process to create code to receive sensor data and act as a Gateway Controller or Repeater. Easily connect mangOH or FX30 to a wide variety of EnOcean batteryless devices including: • • • • • • Light Switches Temperature & Humidity Sensors Occupancy and Motion Detection Key Card Switch Load Controllers – 16A 10V for fans, pumps etc. Magnetic Contact Switches Physical • 45.0mm x 22.3mm x 1.0mm QSFP+ form factor • -40oC to +85oC Operation • +3.3v or +5.0v Operation • RoHS Compliant For more information please contact: Email: sales@taloncom.com This information is subject to change without notice. Version 10/2019
ENOCEAN-MANGOH 价格&库存
很抱歉,暂时无法提供与“ENOCEAN-MANGOH”相匹配的价格&库存,您可以联系我们找货
