GROVE_IOT
GROVE_IOT
    SIERRAWIRELESS
    Grove 转 mangOH 接口 mangOH 平台评估扩展板
GROVE_IOT 数据手册
Talon Grove IoT Expansion Sierra mangOH “SMART VIEW” by Talon for Communications IoT Sensor Interface for mangOH Grove IoT Expansion The mangOH Grove Expansion Board brings Seeed Studio Grove connectivity to the Sierra Wireless mangOH IoT platform in a small QSFP+ form factor. The Talon Grove extender offers easy integration into the mangOH and FX30 platforms and is targeted as a simple, flexible, and low-cost expansion solution. By making use of standard Grove connectors and pinout, the rich variety of Grove peripheral modules can easily be connected to mangOH platform devices. The Grove Expansion Board includes on-board voltage conversion to connect 3.3V or 5V devices to the mangOH internal 1.8V logic, and supports the full selection of I2C, UART, digital I/O and analog interfaces. Grove IoT Module Features Development Environment The Sierra mangOHTM IoT platform is based on Legato open source Linux which is designed to simplify embedded IoT development. Legato has everything you need to connect the IoT quickly: - Programming language APIs – dev tools and APIs to easily write software components and specify how apps will use them. - Target runtime environment – set of daemon processes cooperatively implement execution sandboxes, secure IPC, fault monitoring. - Development and build tools – target, host, and build tools to create apps ready for deployment to your devices. - Documentation and automated tests – documentation and automated tests ready to use. Applications The use of standardized Grove connectors and pinouts offers a proven, low risk option to connect a wide variety of Grove devices to the Sierra mangOH IoT platform, including: • I/O devices such as LEDs, buttons, encoders, touch sensors • LCD and OLED displays • Motion detection: 3 or 6-axis gyro, compass, accelerometer • Communication expansion: WiFi, NFC, BLE • Sensors: temperature / humidity, moisture, dust, gas • Servo control and motor drivers Features • On-board voltage level translation to connect 3.3V or 5.0V Grove modules to mangOH internal 1.8V logic • 3.3V or 5.0V power delivery to Grove modules • Selectable voltage: can choose 3.3V or 5.0V interface and power delivery with single jumper • 7 Standard Grove interface connections: • 4 Digital • 1 Analog • 1 UART • 1 I2C • Buffered analog and I2C interfaces • Optional (not populated by default) on-board EEPROM memory and push button Physical • 45.0mm x 22.3mm x 1.0mm QSFP+ form factor • -40oC to +85oC Operation • +3.3v or +5.0v Operation • RoHS Compliant For more information please contact: Email: sales@taloncom.com This information is subject to change without notice. Version 10/2019
GROVE_IOT 价格&库存
很抱歉,暂时无法提供与“GROVE_IOT”相匹配的价格&库存,您可以联系我们找货
