2CG010BBC14N
2CG010BBC14N
    TAMURA
    GATE DRIVER (CORE, +18/,-2V)
2CG010BBC14N 数据手册
2CG010BBC14N Datasheet Gate Driver Module 2CG010BBC14N ■Overview Gate driver 2CG010BBC14N is a dual channel gate driver designed for IGBT and SiC MOSFET. The high breakdown voltage and low parasitic capacitance make it suitable for gate drives such as SiC MOSFET and IGBT. ■Features ・Ideal for drive of IGBT and SiC MOSFET ・Gate voltage : +18V/-2V ・ALL-IN-ONE (Built-in isolated DC / DC converter and gate drive circuit) ・Low parasitic capacitance (about 12pF) ; highly resistant to common-mode noise. ・Fast response : about 100nsec(typ) ・The isolation for primary-secondary signal used fast response isolator. ・Input-to-Output dielectric withstand voltage : AC5000V ・Output CH1-to-Ouput CH2 dielectric withstand voltage : AC4000V ・Input-to-Output insulation distance : 14mm (clearance), 16mm(creepage) (As for Gate driver module PCB) ・Output CH1-to-Output CH2 insulation distance : 7mm (clearance), 12mm(creepage) ・DC/DC converter input voltage :13~28V ・Signal input voltage : 3.3V,5V ・Overload protection (DC/DC converter) ・Overheat protection (DC/DC converter) ・Half bridge mode (Gate drive circuit) ・Desaturation protection (Gate drive circuit) ・Soft turn-off function (Gate drive circuit) ・Fault signal output function (Gate drive circuit) ・Miller function (Gate drive circuit) ・Under-voltage lockout(UVLO) (Gate drive circuit) ・Insulating moistureproof coating ・Safety standards:UL508(file no.E243511) (DC/DC converter only) ・Reinforced isolation according to IEC 60664-1 (IEC61800-5-1, IEC62477-1, IEC62109-1, etc.) ・UL compliant (UL1741, UL508, etc.) ■Application Industrial inverter, power conditioner, etc … ■Module information Part number Output voltage Miller clamp Status 2CG010BBC11N +15V/-10V Yes Active 2CG010BBC12N +15V/-15V Yes Active 2CG010BBC13N +18V/-4V Yes Active 2CG010BBC14N +18V/-2V Yes Active 1 / 6 TAMURA CORPORATION TMRDM0068EN Rev.1.01 Nov. 2021 2CG010BBC14N Datasheet ■Circuit Image Product DST2 24 Power supply (VIN+) 1 VIN+ Ground (VIN-) 2 VIN- Power supply (VCC) 3 VCC 4 DTC1 5 DTC2 6 ALM1 7 ALM2 8 MODE 9 RTC 10 INA 11 INB Alarm output (CH1 Gate) Alarm output (CH2 Gate) Signal input (CH1 Gate) Signal input (CH2 Gate) Ground (GND) 12 GND Power module VO2+ 27 VGH2 28 VGL2 29 STO2 MCL2 E/S2 VO2- 30 31 26 25 DST1 20 VO1+ 17 VGH1 16 VGL1 15 STO1 MCL1 E/S1 VO1- 14 13 18 19 ■Pin Connection Input Output Pin No. Name CH Function Pin No. Name CH 1 VIN+ Common Power supply for DC/DC converter(+) 13 MCL1 1 Miller clamp pin 2 VIN- Common Power supply for DC/DC converter(ー) 14 STO1 1 Soft turn off pin 3 VCC - Power supply for drive circuit 15 VGL1 1 Gate OFF side pin 4 DTC1 1 Dead time adjustment 16 VGH1 1 Gate ON side pin 5 DTC2 2 Dead time adjustment 17 VO1+ 1 DC/DC converter output pin 6 ALM1 1 Alarm signal output 18 E/S1 1 Emitter・source connection pin 7 ALM2 2 Alarm signal output 19 VO1- 1 DC/DC converter output pin 8 MOD - Mode select 20 DST1 1 Desaturation protection pin 9 RTC - Recovery time of protection circuit control 21 NONE - None 10 INA 1 Control input A 22 NONE - None 11 INB 2 Control input B 23 NONE - None 12 GND - Ground for drive circuit 24 DST2 2 Desaturation protection pin 25 VO2- 2 DC/DC converter output pin 26 E/S2 2 Emitter・source connection pin 27 VO2+ 2 DC/DC converter output pin 28 VGH2 2 Gate ON side pin 29 VGL2 2 Gate OFF side pin 30 STO2 2 Soft turn off pin 31 MCL2 2 Miller clamp pin 2 / 6 TAMURA CORPORATION Function TMRDM0068EN Rev.1.01 Nov. 2021 2CG010BBC14N Datasheet ■Internal Block Diagram VIN+ VINVCC VO2+ DST2 VGH2 VGL2 STO2 MCL2 E/S2 VO2- DESAT detection INB LOGIC ALM2 Isolator 1k Soft-turn off Miller Clamp LOGIC RTC Timer DC/DC converter COM1 VIN+ DTC1 Gate Drive Ch2 VO1+ VO1- VIN- DTC2 Overheat protection MOD 1k VO2+ COM2 Overload protection Direct / Halfbridge VO2- Gate Drive Ch1 VO1+ DESAT detection INA LOGIC ALM1 Isolator 1k DST1 VGH1 VGL1 STO1 MCL1 E/S1 VO1- Soft-turn off Miller Clamp GND ■I/O Condition Table No. Status Input VO+ DST2 DST1 MCL2 MCL1 MOD INB 1 VOx+ UVLO UVLO 2 ES-VOx- short 3 Output(CH2) X X X INA ALM2 VGH2 VGL2 STO2 MCL2 ALM1 VGH1 VGL1 STO1 MCL1 X X X X L Hi-Z Hi-Z X X X X X L Hi-Z SD SD SD SD SD SD - H L - L - - - - - Hi-Z Hi-Z L L Hi-Z - L - L L - L - - - - - Hi-Z Hi-Z L L L - - ○ - L - H L - H (Direct ○ L - H - L L - Hi-Z Hi-Z 7 Mode) ○ L - L - L L - Hi-Z Hi-Z ○ L - H - L H - Hi-Z ○ L L L L H L X Hi-Z Hi-Z ○ L L H L H H L Hi-Z ○ L L L H H H H Hi-Z Hi-Z 12 ○ - Hi-Z - L L - L - 13 Desaturation ○ - Hi-Z - H L - H - 14 protection1 ○ - Hi-Z - L H H L ○ - Hi-Z - H H H H (Half-bridge Mode) 15 16 ○ Hi-Z - L - L L - 17 Desaturation ○ Hi-Z - H - L H - 18 protection2 ○ Hi-Z - L - H H H ○ Hi-Z - H - H H L 19 Hi-Z L L operation 11 L L X 6 operation Hi-Z Hi-Z - 5 9 L X ○ 10 L X Normal Normal L ○ 4 8 Output(CH1) H H - - - Hi-Z H L L Hi-Z - - - - - L L L - - - - - - - - - - Hi-Z Hi-Z L L L Hi-Z Hi-Z Hi-Z Hi-Z Hi-Z L L L Hi-Z Hi-Z Hi-Z L L L L L L Hi-Z - - - - Hi-Z Hi-Z - - - - - - - - - - - - - - L L L L - - L Hi-Z - - L L - L Hi-Z - Hi-Z Hi-Z L Hi-Z Hi-Z Hi-Z Hi-Z L L Hi-Z Hi-Z L H Hi-Z Hi-Z Hi-Z Hi-Z Hi-Z Hi-Z L Hi-Z Hi-Z Hi-Z Hi-Z L L L L Hi-Z L L L Hi-Z - - - - - - - - - - - - - - Hi-Z Hi-Z ○ : Vox+ UVLO > UVLO, X : Don't care, SD:Shut down 3 / 6 TAMURA CORPORATION TMRDM0068EN Rev.1.01 Nov. 2021 2CG010BBC14N Datasheet ■Absolute Maximum Ratings Item Symbol Min Max Unit VIN -0.3 28 Vdc VCC,VSG -0.3 5.5 V VCC, RTC, MOD, INA, INB VALM -0.3 28 V ALM1, ALM2 ALM1, ALM2 Input voltage for DC/DC converter Input-side signal voltage Input-side signal maximum current IALM - 5 mA DESAT pin input voltage VDESAT -0.3 VGH+0.3 V Miller clamp pin input voltage VCLAMP VGL-0.3 VGH+0.3 V Maximum gate current IGPEAK - 43 A DC/DC converter output power POUT - 3.2 W Switching frequency Operating temperature range FSW - 200 kHz VIN=13.5-18V TOP -40 85 ℃ VIN=18-26.4V TOP -40 75 ℃ Operating humidity RHOP 20 95 %RH Storage temperature range TSTG -40 90 ℃ RHSTG 5 95 %RH Storage humidity Conditions・Note Between VIN+ to VIN- Per output circuit See the permissible frequency curve See the permissible frequency curve No condensation No condensation ■Recommended Operating Conditions Item Symbol Min Max Unit Input voltage range for DC/DC converter VIN 13.5 26.4 Vdc VCC,VSG 3 5.5 Vdc N - 2 - Logic high level input voltage VSGH VCC x0.7 - V MOD, INA, INB Logic low level input voltage VSGL - VCC x0.3 V MOD, INA, INB Input-side signal voltage range Driver circuit number Source current of control signal Maximum gate drive capability ISG 5 - mA MOD, INA, INB VSG=5V 200 kHz) QMAX - 550 nC Gate current (ave) = 110mA Reference value ( 30 kHz) QMAX - 5000 nC Gate current (ave) = 150mA Reference value QG - 5000 nC tINMSK 60 - ns ( Maximum gate drive capability Conditions・Note Maximum gate charge amount Minimum input pulse width ■Permissible frequency curve Total gate charge (Qg) vs permissible frequency curve 6000 5000 Qg[nC] 4000 3000 2000 Ta:-40~+85℃ / VIN = 13.5~18V Ta:-40~+75℃ / VIN = 18~26.4V 1000 Ta:-40~+60℃ / VIN = 13.5~26.4V 0 0 4 / 6 50 100 Frequency[kHz] 150 200 TAMURA CORPORATION TMRDM0068EN Rev.1.01 Nov. 2021 2CG010BBC14N Datasheet ■Electrical Specification (Vin=24V, Vcc=5V.Ta=25℃, Unless otherwise specified) Item Symbol Min Typ Max Unit VSTART IIN Conditions・Note - - 13 V - 0.35 - A Fsw=30kHz / Test load: 250nF PSTBY - 1 - W No load VSGH VCC x0.7 - - V MOD, INA, INB / Guaranteed by design Logic low level input voltage VSGL - - VCC x0.3 V MOD, INA, INB / Guaranteed by design Logic pull-down resistance RSGD - 1000 - Ω MOD, INA, INB Gate ON side pin / output voltage(+) VGH,VO+ 17 18 19 V No load Gate OFF side pin / output voltage(-) VGL,VO- -3 -2 -1 V No load Miller clamp voltage VCLAMP - 1.2 - V ICLAMP=500mA, Guaranteed by design Miller clamp ON threshold voltage VCLPON - VGL+2 - V Turn ON time tPON - 100 - ns Turn OFF time tPOFF - 100 - ns tDEAD - 4.1 - us Symbol Min Typ Max Unit DC/DC converter Start-up voltage Input current Standby power Logic inputs Logic high level input voltage Gate driver output Delay time Dead time Half bridge mode ■Protection Item Conditions・Note DC/DC converter Overload protection - 8.4 - - W Auto recovery Overheat protection - 120 - 150 ℃ Auto recovery, Internal temperature Output voltage(H) UVLO OFF voltage VUVLOGHH 13.2 13.5 13.8 V Guaranteed by design Output voltage(H) UVLO ON voltage VUVLOGHL 12.2 12.5 12.8 V Guaranteed by design DESAT charge current IDESAT 200 240 280 uA Guaranteed by design DESAT detection voltage VDESAT 6.0 6.35 7.0 V Guaranteed by design DESAT detection filter time tDSTFIL - 400 - ns DSTxpin open DESAT detection time tDSTOUT - 450 - ns DSTxpin open VALML - - 0.5 V IALM=5mA Gate driver Alarm signal output L voltage Alarm signal output time Restart time Soft turn off duration 5 / 6 tALM - 650 - ns tRESTART - 110 - ms tSTO - 4 - us TAMURA CORPORATION TMRDM0068EN Rev.1.01 Nov. 2021 2CG010BBC14N Datasheet ■Insulation Item Specification Conditions・Note Between Input-Output Dielectric withstand voltage AC5000V 1min, Cutoff 2mA Insulation resistance 100MΩ or more DC500V Partial discharge extinction volt. 1768Vpeak or more According to EN50178/IEC 60270 Common-mode transient immunity (CMTI) 70kV/us Minimum clearance distances 14mm Minimum creepage distances 16mm As for Gate driver module PCB Dielectric withstand voltage AC4000V 1min, Cutoff 2mA Insulation resistance 100MΩ or more DC500V Partial discharge extinction volt. 1700Vpeak or more According to EN50178/IEC 60270 Minimum clearance distances 7mm Minimum creepage distances 12mm Between CH1-CH2 As for Gate driver module PCB ■Storage Conditions Item Storage temperature Min Max Unit -25 60 ℃ Conditions・Note A packing state ※If you want to use past the long period there is a concern that the solder non-wetting by terminal oxidation to occur. Therefore, please use from taking enough tests. ■Recommended Soldering Condition ・Flow soldering condition : 255±3℃ Less than 3sec Temperature of preheating 110℃~130℃ End temperature of preheating 110℃±10℃ ・Soldering condition of hand work : 360℃(MAX) Less than 3sec ■Usage Cautions ● Always mount fuse on the plus side of input for ensuring safety because the fuse is not built-in the product. Please select the fuse considering conditions such as steady current, inrush current, and ambient temperature. When using a fuse having large rated current or high capacity input electrolytic condenser, by combining another converter and input line and input electrolytic condenser, fuse may not blow off in the case of abnormality. Do not combine high voltage line and fuse. ● Make sure the rise/fall time of the input signal is 500ns or less. ● This product has DESAT protection for arm short circuit and load short circuit protection. However, even if this protection works, the IGBT may be damaged if abnormally high current occurs due to IGBT's characteristics variations or the load short-circuit mode during parallel operation. To ensure safety, be sure to check the short-circuit current at the unit in which this product is integrated, and evaluate whether it can protect under the condition that there is no damage to the IGBT. ● The coating material is applied to the product, so it may appear to be partially whitened. This does not affect the characteristics of the product. 6 / 6 TAMURA CORPORATION TMRDM0068EN Rev.1.01 Nov. 2021 CONFIDENTIAL/Preliminary 2CG Series Outline Drawing ■Outline Dimensional Drawing Unit: mm Note: 1. The dimensional tolerance without directions is ± 0.5mm. ■Product Weight 45.0g(typ) 1 / 1 TAMURA CORPORATION TMRDM0069EN Rev.1.01 Aug, 2021 Important Notice ■Important Notice ● This information and product are subject to change without prior notice for the purpose of improvements, etc. Ensure that you are in possession of the most up-to-date information when using this product. ● The operation examples and circuit examples shown in this document are for reference purposes only, and TAMURA Corporation disclaims all responsibility for any violations of industrial property rights, intellectual property rights and any other rights owned by TAMURA Corporation or third parties that these may entail. ● The circuit examples and part constants listed in this document are provided as reference for the verification of characteristics. You are to perform design, verification, and judgment at your own responsibility, taking into account the various conditions. ● TAMURA has evaluated the efficiency and performance of this product in a usage environment determined by us. Depending on your usage environment or usage method, there is the possibility that this product will not perform sufficiently as shown in the specifications, or may malfunction. When applying this product to your devices or systems, please ensure that you conduct evaluations of their state when integrated with this product. You are responsible for judging its applicability. TAMURA bears no responsibility whatsoever for any problems with your devices, systems or this product which are caused by your usage environment or usage method. ● TAMURA Corporation constantly strives to improve quality and reliability, but malfunction or failures are bound to occur with some probability in power products. To ensure that failures do not cause accidents resulting in injury or death, fire accidents, social damage, and so on, you are to thoroughly verify the safety of their designs in devices and/or systems, at your own responsibility. ● This product is intended for use in consumer electronics (electric home appliances, business equipment, Information equipment, communication terminal equipment, measuring devices, and so on.) If considering use of this product in equipment or devices that require high reliability (medical devices, transportation equipment, traffic signal control equipment, fire and crime prevention equipment, aeronautics and space devices, nuclear power control, fuel control, in-vehicle equipment, safety devices, and so on), please consult a TAMURA sales representative in advance. Do not use this product for such applications without written permission from TAMURA Corporation. ● This product is intended for use in environments where consumer electronics are commonly used. It is not designed for use in special environments such as listed below, and if such use is considered, you are to perform thorough safety and reliability checks at your own responsibility. ・ Use in liquids such as water, oil, chemical solutions, or organic solvents, and use in locations where the product will be exposed to such liquids. ・ Use that involves exposure to direct sunlight, outdoor exposure, or dusty conditions. ・ Use in locations where corrosive gases such as salt air, C12, H2S, NH3, SO2, or NO2, are present. ・ Use in environments with strong static electricity or electromagnetic radiation. ・ Use that involves placing inflammable material next to the product. ・ Use of this product either sealed with a resin filling or coated with resin. ・ Use of water or a water soluble detergent for flux cleaning. ・ Use in locations where condensation is liable to occur. ● This product is not designed to resist radiation. ● This product is not designed to be connected in series or parallel. Do not operate this product in a series, parallel, or N+1 redundant configuration. ● Do not use or otherwise make available the TAMURA products or the technology described in this document for any military purposes, including without limitation, for the design, development, use, stockpiling or manufacturing of mass destruction weapons (e.g. nuclear, chemical, or biological weapons or missile technology products). When exporting and re-exporting the products or technology described in this document, you should comply with the applicable export control laws and regulations and follow the procedures required by such laws and regulations including, without limitation, Japan -Foreign Exchange and Foreign Trade Control Law and U.S.- Export Administration Regulations. The TAMURA products and related technology should not be used for or incorporated into any products or systems whose manufacture, use, or sale is prohibited under any applicable domestic or foreign laws or regulations. ● Please contact your TAMURA sales office for details as to environmental matters such as the RoHS compatibility of product. Please use TAMURA products in compliance with all applicable laws and regulations that regulate the inclusion or use of controlled substances, including without limitation, the EU RoHS Directive. TAMURA assumes no liability for damages or losses occurring as a result of your noncompliance with applicable laws and regulations. ● TAMURA assumes no liability for damages or losses incurred by you or third parties as a result of unauthorized use of TAMURA products. ● This document and any information herein may not be reproduced in whole or in part without prior written permission from TAMURA. 1 / 1 TAMURA CORPORATION TMRDM0055EN Rev.1.01 June, 2021
2CG010BBC14N 价格&库存
很抱歉,暂时无法提供与“2CG010BBC14N”相匹配的价格&库存,您可以联系我们找货
2CG010BBC14N
  • 120+746.11902120+96.59156
