2RB010CB
2RB010CB
    TAMURA
    评估板
2RB010CB 数据手册
2RB010CB Datasheet Evluation board for Gate Driver Module 2RB010CB ■Overview Evaluation board for Gate driver 2CG series/2DMB series. The power module of the SiC MOSFET/IGBT can be driven simply by mounting a Gate resistor. ■Features ・Ideal for evaluation of 2CG series/2DMB series ・Gate voltage : Open (lead resistor mounting possible) ・Built-in DC5V regulator for Vcc (Vcc input voltage range: 13.5 to 26.4V) ・Additional circuit for DESAT protection ・Soft turn-off resistor : 50Ω For more information on the 2CG series/2DMB series, please refer to the 2DMB series Datasheets and Application notes. The example of application circuits and parts value which are indicated to this application note aim at assistance of a design. Therefore, external parts variation or user operating conditions are not fully taken into consideration. Please take parts variation, operating conditions into consideration when designing. ■Series information 1 / 6 Part number Miller clamp Active clamp CN301 VSD Status 2RB010CB None 2RB020BB Yes None Straight 10V Active None Right angle 5V Active TAMURA CORPORATION TMRDM0082EN Rev.1.01 Nov. 2021 2RB010CB Datasheet ■Circuit Image Product CN302 VDP SCP GP EP CN301 Connecter Power supply (VIN+) Power module 1,3 VIN(+) CH/DH Pull-up resistor Power supply (VIN-) 2,4 VIN(-) Power supply (VCC) GH 5,7 VCC 6,8 GND 9 ALM2 10 GND 11 INB 12 GND 13 ALM1 14 GND 15 INA 16 GND 17 MOD 18 GND 19 RTC 20 GND Alarm output (Low-side Gate) Signal input (Low-side Gate) Alarm output (High-side Gate) Signal input (High-side Gate) Ground (GND) EH/SH GL EL/SL VDN SCN GN EN Lead CN303 T1 T2 ■Internal Block Diagram CN302 VDP SCP GP EP CN301 VIN+ VCC INB INA MOD RTC Act ive Clamp circuit Regulator Dead time Control circuit ALM2 ALM1 CH/DH CH/DH Desaturation circuit VIN- 2CGxxxxBC1xN 2DMBxxxxxCC Rsto GH GH Rg(ON) Rg(OFF) EH/SH EH/SH Desaturation circuit Act ive Clamp circuit Rg(ON) GL GL Rsto Rg(OFF) EL/SL EL/SL GND VDN SCN GN EN CN303 T1 T2 ※2CGxxxxBC1xN and 2DMBxxxxCC is not implemented 2 / 6 TAMURA CORPORATION TMRDM0082EN Rev.1.01 Nov. 2021 2RB010CB Datasheet ■Pin Connection Input CN301 : RA-H201TD (JST) Name Pin No. Function Pin No. Name Function 1 VIN(+) Power supply for DC/DC converter(+) 2 VIN(-) Power supply for DC/DC converter(-) 3 VIN(+) Power supply for DC/DC converter(+) 4 VIN(-) Power supply for DC/DC converter(-) 5 VCC Power supply for drive circuit 6 GND Ground for drive circuit 7 VCC Power supply for drive circuit 8 GND Ground for drive circuit Alarm signal output 2 (Low side) 10 GND Ground for drive circuit Control input B (Low side) 12 GND Ground for drive circuit 9 ALM2 11 INB 13 ALM1 Alarm signal output 1 (High side) 14 GND Ground for drive circuit 15 INA Control input A (High side) 16 GND Ground for drive circuit 17 MOD Mode select 18 GND Ground for drive circuit 19 RTC Recovery time of protection circuit control 20 GND Ground for drive circuit ※Reference receptacle : RA-S201T (JST) Output Connection on the power module CN302 : B4B-XH-2 (JST) For Gate connection Name CH Function Pin No. Name CH/DH 1 Drain/Collector connection, High side 1 VDP Output pin of DC/DC converter, High side Function CH/DH 1 Drain/Collector connection, High side 2 SCP Short circuit detection pin, High side GH 1 Gate connection, High side 3 GP Gate connection, High side 4 EP Source/Emitter connection, High side GH 1 Gate connection, High side EH/SH 1 Source/Emitter connection, High side EH/SH 1 Source/Emitter connection, High side GL 2 Gate connection, Low side CN303 : B4B-XH-2 (JST) For Gate connection GL 2 Gate connection, Low side Pin No. EL/SL 2 Source/Emitter connection, Low side 1 EN Source/Emitter connection, Low side T1 - Thermistor pin connection 2 GN Gate connection, Low side T2 - Thermistor pin connection 3 SCN Short circuit detection pin, Low side 4 VDN Output pin of DC/DC converter, Low side ※Reference receptacle:XHP-4 (JST) Name Function ※Reference receptacle:XHP-4 (JST) 3 / 6 TAMURA CORPORATION TMRDM0082EN Rev.1.01 Nov. 2021 2RB010CB Datasheet ■Absolute Maximum Ratings Item Symbol Min Max Unit VCC -0.3 28 Vdc Input voltage for Gate driver Other input voltage - - - V VSD 0 1700 V VIN=13.5-18V TOP -40 85 ℃ VIN=18-26.4V TOP -40 75 ℃ RHOP 20 95 %RH TSTG -40 90 ℃ RHSTG 5 95 %RH Short circuit detection pin voltage Operating temperature range Operating humidity Storage temperature range Storage humidity Conditions・Note Between VCC to GND According to the data sheet of each model See the permissible frequency curve No condensation No condensation ■Recommended Operating Conditions Item Symbol Min Max Unit VCC 13.5 26.4 Vdc N - 2 - Symbol Min Typ Max Unit Conditions・Note Ω No mounting / Lead resistor can be mounted. Input voltage range for gate driver Driver circuit number Conditions・Note ■Electrical Specification Item Gate resistor Auxiliary gate capacitor Rg(ON) - OPEN - Rg(OFF) - OPEN - Cge - OPEN - nF Symbol Min Typ Max Unit VSD ■Protection Item Short circuit detection voltage - 10 - V Short circuit detection filter time tSHORTFIL - 3.6 - us Alarm signal response time tALM - 0.2 - us Soft turn-off resistance RSTO - 10 - Ω Conditions・Note Collector open ■Insulation 4 / 6 Item Specification - - TAMURA CORPORATION Conditions・Note According to the data sheet of each model TMRDM0082EN Rev.1.01 Nov. 2021 2RB010CB Datasheet ■Parts list Input side Symblo Description Part No. C351,352 Capacitor OPEN (SMD/1608) C361,362 Capacitor OPEN (SMD/1608) R352,353 Resistor OPEN (SMD/1608) R355,356 Resistor OPEN (SMD/1608) Description Part No. Manufacture TOSHIBA Output side Symblo D301-303,320-323,340 Diode CMF05 D304,324 Capacitor RB160VAM-60 ROHM C301,321 Capacitor 120pF 50V MURATA C302,322 Capacitor OPEN (SMD/1608) - C307,327 Capacitor OPEN (SMD/1608) - C308,328 Capacitor OPEN(1608) - R301-304,321-324 Resistor OPEN (Lead) - R305,306,325,326 Resistor 100Ω 0.25W(SMD/3216) - R307,327 Resistor 0Ω (SMD/1608) - R308,328 Resistor 10kΩ 0.125W(2012) - R309,329 Resistor OPEN(1608) - R310,330 Resistor 100Ω 0.1W(SMD/1608) - R404,424 Resistor OPEN(1608) - JC301,321 Resistor OPEN (SMD/1608) - ■Storage Conditions Item Storage temperature Min Max Unit -25 60 ℃ Conditions・Note A packing state ※If you want to use past the long period there is a concern that the solder non-wetting by terminal oxidation to occur. Therefore, please use from taking enough tests. ■Recommended Soldering Condition ・Soldering condition of hand work 5 / 6 : 360℃(MAX) Less than 5sec TAMURA CORPORATION TMRDM0082EN Rev.1.01 Nov. 2021 2RB010CB Datasheet ■Usage Cautions ● Make sure the rise/fall time of the input signal is 500ns or less. Also, keep input wiring as far as possible from noise sources. To prevent malfunction due to noise, a high signal voltage within the recommended range is recommended. ● Please do not apply excessive stress to this product when attaching to the device power module. ● This product has DESAT protection for arm short circuit and load short circuit protection. However, even if this protection works, the device may be damaged if abnormally high current occurs due to the device's characteristics variations or the load short-circuit mode during parallel operation. To ensure safety, be sure to check the short-circuit current at the unit in which this product is integrated, and evaluate whether it can protect under the condition that there is no damage to the device. 6 / 6 TAMURA CORPORATION TMRDM0082EN Rev.1.01 Nov. 2021 CONFIDENTIAL/Preliminary 2RB Series Outline Drawing ■Outline Dimensional Drawing Unit: mm Note: 1. The dimensional tolerance without directions is ± 0.5mm. ■Product Weight 34.0g(typ) 1 / 1 TAMURA CORPORATION TMRDM0080EN Rev.1.01 Oct, 2021 Important Notice ■Important Notice ● This information and product are subject to change without prior notice for the purpose of improvements, etc. Ensure that you are in possession of the most up-to-date information when using this product. ● The operation examples and circuit examples shown in this document are for reference purposes only, and TAMURA Corporation disclaims all responsibility for any violations of industrial property rights, intellectual property rights and any other rights owned by TAMURA Corporation or third parties that these may entail. ● The circuit examples and part constants listed in this document are provided as reference for the verification of characteristics. You are to perform design, verification, and judgment at your own responsibility, taking into account the various conditions. ● TAMURA has evaluated the efficiency and performance of this product in a usage environment determined by us. Depending on your usage environment or usage method, there is the possibility that this product will not perform sufficiently as shown in the specifications, or may malfunction. When applying this product to your devices or systems, please ensure that you conduct evaluations of their state when integrated with this product. You are responsible for judging its applicability. TAMURA bears no responsibility whatsoever for any problems with your devices, systems or this product which are caused by your usage environment or usage method. ● TAMURA Corporation constantly strives to improve quality and reliability, but malfunction or failures are bound to occur with some probability in power products. To ensure that failures do not cause accidents resulting in injury or death, fire accidents, social damage, and so on, you are to thoroughly verify the safety of their designs in devices and/or systems, at your own responsibility. ● This product is intended for use in consumer electronics (electric home appliances, business equipment, Information equipment, communication terminal equipment, measuring devices, and so on.) If considering use of this product in equipment or devices that require high reliability (medical devices, transportation equipment, traffic signal control equipment, fire and crime prevention equipment, aeronautics and space devices, nuclear power control, fuel control, in-vehicle equipment, safety devices, and so on), please consult a TAMURA sales representative in advance. Do not use this product for such applications without written permission from TAMURA Corporation. ● This product is intended for use in environments where consumer electronics are commonly used. It is not designed for use in special environments such as listed below, and if such use is considered, you are to perform thorough safety and reliability checks at your own responsibility. ・ Use in liquids such as water, oil, chemical solutions, or organic solvents, and use in locations where the product will be exposed to such liquids. ・ Use that involves exposure to direct sunlight, outdoor exposure, or dusty conditions. ・ Use in locations where corrosive gases such as salt air, C12, H2S, NH3, SO2, or NO2, are present. ・ Use in environments with strong static electricity or electromagnetic radiation. ・ Use that involves placing inflammable material next to the product. ・ Use of this product either sealed with a resin filling or coated with resin. ・ Use of water or a water soluble detergent for flux cleaning. ・ Use in locations where condensation is liable to occur. ● This product is not designed to resist radiation. ● This product is not designed to be connected in series or parallel. Do not operate this product in a series, parallel, or N+1 redundant configuration. ● Do not use or otherwise make available the TAMURA products or the technology described in this document for any military purposes, including without limitation, for the design, development, use, stockpiling or manufacturing of mass destruction weapons (e.g. nuclear, chemical, or biological weapons or missile technology products). When exporting and re-exporting the products or technology described in this document, you should comply with the applicable export control laws and regulations and follow the procedures required by such laws and regulations including, without limitation, Japan -Foreign Exchange and Foreign Trade Control Law and U.S.- Export Administration Regulations. The TAMURA products and related technology should not be used for or incorporated into any products or systems whose manufacture, use, or sale is prohibited under any applicable domestic or foreign laws or regulations. ● Please contact your TAMURA sales office for details as to environmental matters such as the RoHS compatibility of product. Please use TAMURA products in compliance with all applicable laws and regulations that regulate the inclusion or use of controlled substances, including without limitation, the EU RoHS Directive. TAMURA assumes no liability for damages or losses occurring as a result of your noncompliance with applicable laws and regulations. ● TAMURA assumes no liability for damages or losses incurred by you or third parties as a result of unauthorized use of TAMURA products. ● This document and any information herein may not be reproduced in whole or in part without prior written permission from TAMURA. 1 / 1 TAMURA CORPORATION TMRDM0055EN Rev.1.01 June, 2021
2RB010CB 价格&库存
很抱歉,暂时无法提供与“2RB010CB”相匹配的价格&库存,您可以联系我们找货
