ADCP.12A.01.3000K
ADCP.12A.01.3000K
    TAOGLASLIMITED
    ACTIVE 5.9GHZ DSRC PATCH ANTENNA
ADCP.12A.01.3000K 数据手册
ADCP.12A.01.3000K 4EVX2S %('4%/ (IWGVMTXMSR Active 5.9GHz DSRC Patch Antenna 12*12*4mm on PCB 50*50mm 150mm RG­ 316 SMA(M) *IEXYVIW 5850MHz to 5925MHz band For DSRC and CB2X Applications Transmit and Receive Amplifiers Low­EVM Power Amplifier High­performance Patch Antenna Robust ISO 16750 Compliant Power Input AEC­Q Compliant Manufactured in a IATF16949 approved facility Cable : 150mm RG­316 Connector : SMA(M) Cable & Connector Customizable Dims: 50*50*5 mm SPE­19­98­007­A­PF 1. Introduction 3 2. Specifications 5 3. Antenna Characteristics 6 4. 2D Radiation Patterns 9 5. 3D Radiation Patterns 11 6. Active Antenna Characteristics 12 7. Mechanical Drawing 14 8. Packaging 16 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE­19­8­007/A/PF www.taoglas.com   Introduction The Taoglas ADCP.12A is an embedded ceramic DSRC patch active antenna module. At 50*50*5 mm, it is a high performance, yet compact, 5.5dBi directional antenna designed to operate at 5850 MHz to 5925 MHz for DSRC (Dedicated Short Range Communications) and C­V2X (Cellular Vehicle to Everything) systems. DSRC is the communications media of choice for active safety V2V/V2X (Vehicle to Vehicle and Vehicle to Other) systems, primarily allocated for vehicle safety applications. DSRC supports high speed, low latency, short­ range V2V/V2X wireless communications. The ADCP.12 active antenna features a circularly polarized ceramic patch with high efficiency of 65% and peak gain of 5.5 dBi. The circular polarization enables a more stable system signal strength on moving vehicles. The ADCP.12 enables new, remote placement options for the secondary DSRC antenna. This revolutionary device packages a high­performance 5.9GHz ceramic patch antenna with a high­linearity power amplifier, a robust low­noise amplifier, and transmit/receive switches to provide a fully remote front­end. By including the front­end with the remote antenna, two benefits are found: Higher transmit and receive performance is available by counteracting the coaxial cable losses, and Smaller­diameter coaxial cable can be utilized, reducing total vehicle weight and cost. The Rx/Tx path control comes from the module along with DC supply designed to cover the automotive 9­26 V range. DC and overvoltage protection has also been implemented. This antenna is uniquely suited as the antenna of choice when it comes to V2X automotive applications due to this. SPE­19­8­007/A/PF www.taoglas.com  The ADCP.12 is produced in a TS16949­compliant facility and is fully automotive qualified. For further optimization to customer specific device environments where positioning is off centre or a different ground­plane size, a custom tuned patch antenna can be supplied, subject to NRE and MOQ. The ADCP.12A is supplied with 150mm of RG­316 with an SMA(M) connector, both of which can be customized. Contact your regional Taoglas office for support on how your device. SPE­19­8­007/A/PF www.taoglas.com   Specifications Operation Frequency 5850 MHz 5925 MHz Efficiency >65% >65% Peak Gain +5.5 dBi +5.5 dBi Axial Ratio < 5.5 dB Polarization RHCP Impedance 50 ohms Gain +11 dB Noise Figure 4.3 dB In­band Input P1dB ­8 dBm Gain +27.5 dB In­band Input P1dB (CW) ­5 dBm Input Voltage +9 ~ +26VDC Current Consumption (Receive Mode) 3.5 mA Typical Current Consumption (Tx Mode) 200mA Typical Current Consumption (Idle Mode) 165 uA Typical Ceramic Dimension 12 x 12 x 4 mm PCB Dimension 50 x 50 mm Cable Coax: RG316 Control & Power: 3­conductor 24AWG Operating Temperature ­40°C to +105°C Shock, Vibration ISO 16750 ESD ISO 10605, Contact: 8kV Air: 15kV Power Supply Immunity ISO 16750­2 SPE­19­8­007/A/PF www.taoglas.com   Antenna Characteristics SPE­19­8­007/A/PF www.taoglas.com  SPE­19­8­007/A/PF www.taoglas.com  SPE­19­8­007/A/PF www.taoglas.com   2D Radiation Patterns SPE­19­8­007/A/PF www.taoglas.com  SPE­19­8­007/A/PF www.taoglas.com   3D Radiation Patterns dBi SPE­19­8­007/A/PF www.taoglas.com   Active Circuit Characteristics SPE­19­8­007/A/PF www.taoglas.com  SPE­19­8­007/A/PF www.taoglas.com   Mechanical Drawing (Unit: mm) SPE­19­8­007/A/PF www.taoglas.com  SPE­19­8­007/A/PF www.taoglas.com   Packaging SPE­19­8­007/A/PF www.taoglas.com  [[[XESKPEWGSQ SPE­19­8­007/A/PF www.taoglas.com
ADCP.12A.01.3000K 价格&库存
很抱歉,暂时无法提供与“ADCP.12A.01.3000K”相匹配的价格&库存,您可以联系我们找货
