Synergy 8 in 1 Antenna
Part No:
MA1508.AK.001
Description:
Synergy 8-in-1 Combination antenna with 1*Active GNSS, 4*5G/4G MIMO and
3*Wi-Fi MIMO
Features:
4 x 5G/4G MIMO Antenna
3 x Wi-Fi 2.4GHz/5.8GHz MIMO Antenna
1 x GPS/GLONASS/BeiDou Antenna Front End GNSS SAW Filter
IP67 Rated Waterproof Enclosure
High Efficiency/Peak Gain Outdoor Antenna
Dimensions: Ø161*55mm
Cable: 300mm RG-174 with 4700mm TGC-200
Connectors: SMA(M) for GNSS and 5G/4G / RP-SMA(M) for Wi-Fi
RoHS & REACH Compliant
SPE-20-8-026-A
1.
Introduction
3
2.
Specifications
4
3.
Active Antenna Characteristics
10
4.
16
5.
Radiation Patterns
24
6.
Mechanical Drawing
71
7.
Installation Guidelines
72
8.
Packaging
74
Changelog
75
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-21-8-031-A
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
1.
1.
1.
Introduction
The Taoglas Synergy MA1508 is a 8-in-1 next-generation permanent mount antenna for vehicle roof
applications. It has a fully IP67 rated waterproof robust PC enclosure and base. The 9 antennas inside support
5G/4G, GPS/GLONASS/BeiDou, Wi-Fi (2.4GHz/5GHz). This outstanding patent-pending antenna delivers
powerful MIMO antenna technology for 5G/4G, Wi-Fi 2.4/5.8GHz 802.11n and the emerging 802.11ac, and
an optimized GPS/GLONASS/BeiDou patch antenna for location. The 5G/4G antennas also include backward
compatibility to work at most worldwide 2G and 3G bands.
Introduction
Typical Applications:
– Next Generation OEM Automotive Connectivity
– Multimedia, Navigation and Telematics Systems
– V2V, V2X and Fleet Management Applications
– Real-time HD Video Streaming
– First Net Responder Routers
Introduction
Introduction
The MA1508 is ideal for applications that require highly sophisticated antennas for real-time streaming
applications that demand high-speed video uplink and downlink into the cabin of the vehicle. These
challenges are resolved by the highly efficient, high gain MIMO antennas, with high isolation, all of which is
necessary to achieve the required signal to noise ratio and throughput.
The MA1508 can also be customized for your particular wireless application and frequency band, subject to
NRE and MOQ. There are 8x 300mm RG-174 cables, terminating in SMA(M) connectors for 5G/4G MIMO
4X4, and RP SMA(M) for Wi-Fi MIMO 3X3. There is a 300mm RG-174 cable for GNSS terminating in an SMA(M)
connector.
All cable lengths and connector types are customizable. The Synergy MA1508 can be supplied with low loss
TGC-200 cable extensions for longer cable runs. Contact your regional Taoglas customer services team for
details and support.
SPE-21-8-031-A
www.taoglas.com
3
2.
Specifications
3.
GNSS Frequency Bands Covered
AntennaL1 Characteristics2.
Specifications
L2
L5
L6
GPS/QZSS
1575.42MHz
1227.6MHz
1176.45MHz
1278.75MHz
L5R
L3PT
L2PT
1246MHz
L1CR
1575.42MHz
L1PT
1602MHz
E5a
1176.45MHz
E5b
1201.5MHz
E4
1215MHz
E3
1256MHz
E6
1278.75MHz
E2
1561MHz
L1
1575.42MHz
3. GLONASS
Antenna
Characteristics
1176.45MHz
1201.5MHz
Galileo
4.
Antenna□ Radiation
Patterns3.
Antenna
B1
BeiDou
Characteristics2.
1561MHz
Compass
3.
B3
Specifications
1268.52MHz
E5B(B2)/ E6(B3)
1268.56MHz
E2(B1)
1561MHz
Omnistar
1542.5MHz
WAAS/EGN OS
1575.42MHz
Antenna□ Characteristics2.
SBAS
3.
B2
1207.14MHz
Specifications
GNSS Electrical
Frequency (MHz)
4.
1561
Passive Antenna Efficiency (%)
Passive Antenna Gain at Zenith (dBic)
(Without cable loss)
4.
1602
2.5
2.5
40.02
48.39
44.29
3.75
4.44
4.54
11
15
Antenna
Radiation Patterns3.
VSWR (max.)
2.5 Antenna
Characteristics
4.
1575.42
Axial Ratio (dB)
Antenna
Radiation Patterns20
Polarization
RHCP
Impedance
50Ω
Cable
RG-174
Connector
SMA(M)
Antenna Radiation Patterns3.Antenna
Characteristics
4.
Characteristics2.
SPE-21-8-031-A
Specifications
www.taoglas.com
4
LNA and Filter Electrical Properties
Frequency (MHz)
1561
1575.42
1602
VSWR (max.)
2.0:1
2.0:1
2.0:1
Gain@1.8V (dBic)
28.8 dB
28.8 dB
28 dB
Gain@3.0V (dBic)
29 dB
29 dB
28.3 dB
Gain@5.5V (dBic)
29.6 dB
29.4 dB
28.7 dB
Noise@1.8V (dB)
2.8 dB
2.3 dB
2.8 dB
Noise@3.0V (dB)
2.8 dB
2.2 dB
2.8 dB
Noise@5.5V (dB)
2.9 dB
2.3 dB
2.8 dB
Power consumption@1.8V (mA)
8.7 mA
Power consumption@3.0V (mA)
9.0 mA
Power consumption@5.5V (mA)
11 mA
Total Specification (Through Antenna, SAW Filter and LNA)
Frequency (MHz)
1561
1575.42
1602
Gain@3V (dBic)
31.7 ± 3
32.4 ± 3
32.4 ± 3
Output Impedance
SPE-21-8-031-A
50Ω
www.taoglas.com
5
5G/4G Antenna
Frequency (MHz)
5G NR
Band 71
LTE700
GSM
850/900
617
~698
698
~824
824
~960
5G NR
Band
74,1427
75, 76
~1518
5G NR Band LTE5200/
77, 78, 79 Wi-Fi 5800
DCS
PCS
UMTS1
LTE2600
1710
~1880
1850
~1990
1920
~2170
2300
~2690
3300
~3800
5150
~5925
Efficiency (%)
MIMO 1
5m
30.79
30.39
34.96
39.48
46.48
32.68
32.15
43.45
49.25
49.39
MIMO 2
5m
18.62
31.96
30.24
43.80
42.07
37.06
38.94
44.95
31.36
44.49
MIMO 3
5m
30.07
30.40
32.11
47.07
42.70
34.09
33.14
41.63
49.49
20.60
MIMO 4
5m
21.05
30.90
32.56
38.32
42.80
39.73
38.88
43.70
29.88
48.09
Average Gain (dB)
MIMO 1
5m
-5.12
-5.17
-4.56
-4.04
-3.33
-4.86
-4.93
-3.62
-3.08
-3.06
MIMO 2
5m
-7.30
-4.95
-5.19
-3.59
-3.76
-4.31
-4.10
-3.47
-5.04
-3.52
MIMO 3
5m
-5.22
-5.17
-4.93
-3.27
-3.70
-4.67
-4.80
-3.81
-3.06
-6.86
MIMO 4
5m
-6.77
-5.10
-4.87
-4.17
-3.69
-4.01
-4.10
-3.59
-5.25
-3.18
Peak Gain (dBi)
MIMO 1
5m
-0.08
1.04
2.03
2.94
4.55
2.93
3.20
4.96
5.82
5.90
MIMO 2
5m
-0.58
0.49
1.42
3.76
3.31
2.32
3.75
4.84
3.77
5.89
MIMO 3
5m
0.25
1.44
1.63
3.47
3.77
2.45
3.00
5.06
5.99
5.57
MIMO 4
5m
-0.20
1.13
2.93
2.52
3.61
2.79
3.97
4.76
2.91
6.28
Impedance
50 Ω
Polarization
Linear
Radiation Pattern
Omni
Max. input power
2W
SPE-21-8-031-A
www.taoglas.com
6
Wi-Fi MIMO
Frequency (MHz)
2400~2500
5150~5850
Efficiency (%)
MIMO 1
5m
33.16
42.72
MIMO 2
5m
47.59
47.92
MIMO 3
5m
35.95
35.76
Average Gain (dB)
MIMO 1
5m
-4.79
-3.69
MIMO 2
5m
-3.22
-3.19
MIMO 3
5m
-4.44
-4.47
Peak Gain (dBi)
MIMO 1
5m
2.11
5.78
MIMO 2
5m
3.12
7.03
MIMO 3
5m
2.16
5.30
Impedance
50 Ω
Polarization
Linear
Radiation Pattern
Omni
Max. input power
2W
SPE-21-8-031-A
www.taoglas.com
7
Mechanical
Height
57.47mm
Planner Dimension
Ø160mm
Casing
PC
Cable
0.3m RG-174 with 4.7m TGC-200 for 5G/4G – Fully Customizable
0.3m RG-174 with 4.7m TGC-200 for Wi-Fi – Fully Customizable
0.3m RG174 with 4.7m TGC-200 for GNSS – Fully Customizable
Connector
5G/4G: SMA-Plug – Fully Customizable
Wi-Fi: RP-SMA-Plug – Fully Customizable
GNSS: SMA-Plug – Fully Customizable
Thread
18.23mm
Thread Diameter
M22
Sealant
Rubber Stopper and O-Ring
Weight
2.5Kg
Environmental
Ingress Protection
IP67
Temperature Range
-40°C to 85°C
Humidity
Non-condensing 65°C 95% RH
Cable Pull
RG-174 4 Kg
SPE-21-8-031-A
www.taoglas.com
8
5G/4G Bands
Band Number
5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA
Uplink
Downlink
1
UL: 1920 to 1980
DL: 2110 to 2170
2
UL: 1850 to 1910
DL: 1930 to 1990
3
UL: 1710 to 1785
DL: 1805 to 1880
4
UL: 1710 to 1755
DL: 2110 to 2155
5
UL: 824 to 849
DL: 869 to 894
7
UL: 2500 to 2570
DL:2620 to 2690
8
UL: 880 to 915
DL: 925 to 960
9
UL: 1749.9 to 1784.9
DL: 1844.9 to 1879.9
11
UL: 1427.9 to 1447.9
DL: 1475.9 to 1495.9
12
UL: 699 to 716
DL: 729 to 746
13
UL: 777 to 787
DL: 746 to 756
14
UL: 788 to 798
DL: 758 to 768
17
UL: 704 to 716
DL: 734 to 746 (LTE only)
18
UL: 815 to 830
DL: 860 to 875 (LTE only)
19
UL: 830 to 845
DL: 875 to 890
UL: 832 to 862
DL: 791 to 821
21
UL: 1447.9 to 1462.9
DL: 1495.9 to 1510.9
22
UL: 3410 to 3490
DL: 3510 to 3590
23
UL:2000 to 2020
DL: 2180 to 2200 (LTE only)
24
UL:1625.5 to 1660.5
DL: 1525 to 1559 (LTE only)
25
UL: 1850 to 1915
DL: 1930 to 1995
26
UL: 814 to 849
DL: 859 to 894
27
UL: 807 to 824
DL: 852 to 869 (LTE only)
28
UL: 703 to 748
DL: 758 to 803 (LTE only)
29
UL: -
DL: 717 to 728 (LTE only)
30
UL: 2305 to 2315
DL: 2350 to 2360 (LTE only)
31
UL: 452.5 to 457.5
DL: 462.5 to 467.5 (LTE only)
32
UL: -
DL: 1452 - 1496
35
1850 to 1910
38
2570 to 2620
39
1880 to 1920
40
2300 to 2400
41
2496 to 2690
42
3400 to 3600
43
3600 to 3800
3550 to 3700
48
66
UL: 1710-1780
DL: 2110-2200
71
617 to 698
74/75/76
1427 to 1518
78
3300 to 3800
79
4400 to 5000
Covered
* Covered Bands represent greater than 20% efficiency
SPE-21-8-031-A
www.taoglas.com
9
3.
4. 3.1 Antenna
Radiation
Block Diagram
(ActivePatterns3.
antenna) Antenna
Characteristics
4.
4.
Characteristics
4.
Characteristics
3.2
Passive Antenna Return Loss
4.
4.
4.
4.
Characteristics
4.
SPE-21-8-031-A
www.taoglas.com
10
3.3
3.4
Passive Antenna Average Gain
SPE-21-8-031-A
www.taoglas.com
11
3.5
Passive Antenna Peak Gain
3.6
Passive Antenna Axial Ratio (Zenith is at 0° )
XZ-plane
SPE-21-8-031-A
www.taoglas.com
12
YZ-plane
SPE-21-8-031-A
www.taoglas.com
13
3.7
Active measurements
LNA Gain @ 3.0V
Noise Figure @ 3.0V
SPE-21-8-031-A
www.taoglas.com
14
3.8
Passive Antenna Radiation Patterns
1575.42MHz
XY Plane
XZ Plane
X
Z
Y
SPE-21-8-031-A
YZ Plane
Z
X
Y
www.taoglas.com
15
4.
4.
4.1
Return Loss
5G/4G MIMO
Characteristics
4.
4.
Characteristics
4.
Characteristics
Wi-Fi MIMO
4.
4.
4.
4.
Characteristics
4.
SPE-21-8-031-A
www.taoglas.com
16
4.2
Isolation
5G/4G 1
5G/4G 2
SPE-21-8-031-A
www.taoglas.com
17
5G/4G 3
5G/4G 4
SPE-21-8-031-A
www.taoglas.com
18
Wi-Fi 1
Wi-Fi 2
SPE-21-8-031-A
www.taoglas.com
19
Wi-Fi 3
4.3
Efficiency
5G/4G MIMO
100
LTE1
LTE2
90
LTE3
LTE4
80
70
60
50
40
30
1000
SPE-21-8-031-A
1500
2000
2500
3000
3500
4000
4500
5000
5500
6000(MHz)
www.taoglas.com
Wi-Fi MIMO
100
WiFi1
90
WiFi2
80
WiFi4
70
60
50
40
30
2000 2200 2400 2600 2800 3000 3200 3400 3600 3800 4000 4200 4400 4600 4800 5000 5200 5400 5600 5800 6000
(MHz)
4.4
Average Gain
5G/4G MIMO
(dB)
-5
-10
LTE1
LTE2
LTE3
-15
500
1000
SPE-21-8-031-A
1500
2000
2500
3000
3500
4000
4500
5000
5500
6000 (MHz)
www.taoglas.com
21
Wi-Fi MIMO
WiFi1
WiFi2
-1
WiFi4
-2
(dBi)
-3
-4
-5
-6
-7
2000 2200 2400 2600 2800 3000 3200 3400 3600 3800 4000 4200 4400 4600 4800 5000 5200 5400 5600 5800 6000 (MHz)
4.5
Peak Gain
5G/4G MIMO
10
(dBi)
5
LTE1
LTE2
LTE3
LTE4
-10
500
1000
SPE-21-8-031-A
1500
2000
2500
3000
3500
4000
4500
5000
5500
6000
(MHz)
www.taoglas.com
22
Wi-Fi MIMO
10
WiFi1
WiFi2
(dBi)
WiFi4
5
SPE-21-8-031-A
(MHz)
www.taoglas.com
23
5.
Radiation Patterns
4.
4.
4.
4.
4.
5.1
Test Setup
Y
4.
Antenna Radiation
X Patterns
Z
4.
4.
On 30x30cm Ground Plane
SPE-21-8-031-A
www.taoglas.com
24
5.2
5G/4G MIMO 1 Radiation Pattern
663MHz
XY Plane
XZ Plane
Z
Z
X
Y
SPE-21-8-031-A
YZ Plane
X
Y
www.taoglas.com
25
751MHz
XY Plane
XZ Plane
X
Z
Z
Y
SPE-21-8-031-A
YZ Plane
X
Y
www.taoglas.com
26
880MHz
XY Plane
XZ Plane
Z
Z
X
Y
SPE-21-8-031-A
YZ Plane
X
Y
www.taoglas.com
27
1467MHz
XY Plane
XZ Plane
X
Z
Z
Y
SPE-21-8-031-A
YZ Plane
X
Y
www.taoglas.com
28
1805MHz
XY Plane
XZ Plane
Z
X
Y
SPE-21-8-031-A
YZ Plane
Z
X
Y
www.taoglas.com
29
1920MHz
XY Plane
XZ Plane
Z
Z
X
Y
SPE-21-8-031-A
YZ Plane
X
Y
www.taoglas.com
30
2010MHz
XY Plane
X
Y
SPE-21-8-031-A
XZ Plane
YZ Plane
Z
Z
X
Y
www.taoglas.com
31
2500MHz
XY Plane
XZ Plane
Z
Z
X
Y
SPE-21-8-031-A
YZ Plane
X
Y
www.taoglas.com
32
3300MHz
XY Plane
XZ Plane
X
Z
Z
Y
SPE-21-8-031-A
YZ Plane
X
Y
www.taoglas.com
33
5550MHz
XY Plane
XZ Plane
X
Z
Z
Y
SPE-21-8-031-A
YZ Plane
X
Y
www.taoglas.com
34
5.3
5G/4G MIMO 2 Radiation Pattern
663MHz
XY Plane
XZ Plane
Z
X
Y
SPE-21-8-031-A
YZ Plane
Z
X
Y
www.taoglas.com
35
751MHz
XY Plane
XZ Plane
X
Z
Y
SPE-21-8-031-A
YZ Plane
Z
X
Y
www.taoglas.com
36
880MHz
XY Plane
XZ Plane
X
Z
Y
SPE-21-8-031-A
YZ Plane
Z
X
Y
www.taoglas.com
37
1467MHz
XY Plane
XZ Plane
X
Z
Z
Y
SPE-21-8-031-A
YZ Plane
X
Y
www.taoglas.com
38
1805MHz
XY Plane
XZ Plane
X
Z
Z
Y
SPE-21-8-031-A
YZ Plane
X
Y
www.taoglas.com
39
1920MHz
XY Plane
XZ Plane
X
Z
Y
SPE-21-8-031-A
YZ Plane
Z
X
Y
www.taoglas.com
40
2010MHz
XY Plane
XZ Plane
X
Z
Y
SPE-21-8-031-A
YZ Plane
Z
X
Y
www.taoglas.com
41
2500MHz
XY Plane
XZ Plane
X
Z
Y
SPE-21-8-031-A
YZ Plane
Z
X
Y
www.taoglas.com
42
3400MHz
XY Plane
XZ Plane
X
Z
Z
Y
SPE-21-8-031-A
YZ Plane
X
Y
www.taoglas.com
43
5550MHz
XY Plane
XZ Plane
X
Z
Z
Y
SPE-21-8-031-A
YZ Plane
X
Y
www.taoglas.com
44
5.4
5G/4G MIMO 3 Radiation Pattern
663MHz
XY Plane
X
Y
SPE-21-8-031-A
XZ Plane
YZ Plane
Z
Z
X
Y
www.taoglas.com
45
751MHz
XY Plane
XZ Plane
Z
X
Y
SPE-21-8-031-A
YZ Plane
Z
X
Y
www.taoglas.com
46
880MHz
XY Plane
XZ Plane
Z
X
Y
SPE-21-8-031-A
YZ Plane
Z
X
Y
www.taoglas.com
47
1467MHz
XY Plane
XZ Plane
X
Z
Z
Y
SPE-21-8-031-A
YZ Plane
X
Y
www.taoglas.com
48
1805MHz
XY Plane
XZ Plane
X
Z
Y
SPE-21-8-031-A
YZ Plane
Z
X
Y
www.taoglas.com
49
1920MHz
XY Plane
X
Y
SPE-21-8-031-A
XZ Plane
YZ Plane
Z
Z
X
Y
www.taoglas.com
50
2010MHz
XY Plane
XZ Plane
X
Z
Y
SPE-21-8-031-A
YZ Plane
Z
X
Y
www.taoglas.com
51
2500MHz
XY Plane
XZ Plane
Z
X
Y
SPE-21-8-031-A
YZ Plane
Z
X
Y
www.taoglas.com
52
3300MHz
XY Plane
XZ Plane
X
Z
Z
Y
SPE-21-8-031-A
YZ Plane
X
Y
www.taoglas.com
53
5550MHz
XY Plane
XZ Plane
X
Z
Z
Y
SPE-21-8-031-A
YZ Plane
X
Y
www.taoglas.com
54
5.5
5G/4G MIMO 4 Radiation Pattern
663MHz
XY Plane
XZ Plane
Z
Z
X
Y
SPE-21-8-031-A
YZ Plane
X
Y
www.taoglas.com
55
751MHz
XY Plane
XZ Plane
YZ Plane
X
Z
Z
Y
SPE-21-8-031-A
X
Y
www.taoglas.com
56
880MHz
XY Plane
XZ Plane
YZ Plane
X
Z
Z
Y
SPE-21-8-031-A
X
Y
www.taoglas.com
57
1467MHz
XY Plane
XZ Plane
X
Z
Z
Y
SPE-21-8-031-A
YZ Plane
X
Y
www.taoglas.com
58
1805MHz
XY Plane
XZ Plane
Z
Z
X
Y
SPE-21-8-031-A
YZ Plane
X
Y
www.taoglas.com
59
1920MHz
XY Plane
XZ Plane
Z
X
Y
SPE-21-8-031-A
YZ Plane
Z
X
Y
www.taoglas.com
60
2010MHz
XY Plane
X
Y
SPE-21-8-031-A
XZ Plane
YZ Plane
Z
Z
X
Y
www.taoglas.com
61
2500MHz
XY Plane
XZ Plane
X
Z
Z
Y
SPE-21-8-031-A
YZ Plane
X
Y
www.taoglas.com
62
3300MHz
XY Plane
XZ Plane
X
Z
Z
Y
SPE-21-8-031-A
YZ Plane
X
Y
www.taoglas.com
63
5150MHz
XY Plane
XZ Plane
X
Z
Z
Y
SPE-21-8-031-A
YZ Plane
X
Y
www.taoglas.com
64
5.6
Wi-Fi MIMO 1 Radiation Pattern
2450MHz
XY Plane
XZ Plane
Z
Z
X
Y
SPE-21-8-031-A
YZ Plane
X
Y
www.taoglas.com
65
5550MHz
XY Plane
XZ Plane
Z
X
Y
SPE-21-8-031-A
YZ Plane
Z
X
Y
www.taoglas.com
66
5.7
Wi-Fi MIMO 2 Radiation Pattern
2450MHz
XY Plane
XZ Plane
X
Z
Y
SPE-21-8-031-A
YZ Plane
Z
X
Y
www.taoglas.com
67
5550MHz
XY Plane
XZ Plane
X
Z
Y
SPE-21-8-031-A
YZ Plane
Z
X
Y
www.taoglas.com
68
5.8
Wi-Fi MIMO 3 Radiation Pattern
2450MHz
XY Plane
XZ Plane
X
Z
Y
SPE-21-8-031-A
YZ Plane
Z
X
Y
www.taoglas.com
69
5550MHz
XY Plane
XZ Plane
X
Z
Y
SPE-21-8-031-A
YZ Plane
Z
X
Y
www.taoglas.com
70
6.
Mechanical Drawing (Units: mm)
6.
Packaging5.
6.
Packaging
7.
Application Note6. Packaging5.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-21-8-031-A
Mechanical Drawing
www.taoglas.com
71
7.
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-21-8-031-A
Mechanical Drawing
www.taoglas.com
72
SPE-21-8-031-A
www.taoglas.com
73
8.
Packaging
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
1pc MA1508.AK.001 per PE Bag
Weight: 2.5Kg
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
4pcs MA1508.AK.001 per Carton
Carton Dimensions: 740*370*300mm
Weight: 10.4Kg
6.
Packaging
300mm
7.
740mm
7.
Application Note
7.
7.
370mm
Mechanical
Drawing
6.
Packaging5.
SPE-21-8-031-A
Mechanical Drawing
www.taoglas.com
74
Changelog for the datasheet
SPE-20-8-031 - MA1508.AK.001
Revision: A (Original First Release)
Date:
Notes:
Author:
2021-04-23
Initial Release
Jack Conroy
Previous Revisions
SPE-21-8-031-A
www.taoglas.com
75
www.taoglas.com
©Taoglas
SPE-21-8-031-A
www.taoglas.com
76
很抱歉,暂时无法提供与“MA1508.AK.001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4870.783991+630.14737
- 10+4254.0484310+550.35852
- 国内价格 香港价格
- 1+5077.326311+656.86835
- 5+4899.749845+633.89477
- 国内价格
- 1+3258.77040
- 200+1261.10520
- 500+1216.78200
- 1000+1194.89040
- 国内价格 香港价格
- 1+4157.134681+537.82050
- 10+3671.5499210+474.99900
- 国内价格 香港价格
- 1+4085.869511+528.60072
- 10+3608.6090710+466.85616
- 国内价格 香港价格
- 1+3802.299891+491.91450
