[Model Name]
Part No:
TFX257.A
Description
Wi-Fi Transparent Antenna
Features:
Wi-Fi (including Wi-Fi 6) 2.4-2.5, 4.9-5.8, 5.9-7.125GHz
Transparent – Ultra Low Profile
Dimensions: 32mm * 114mm
Connector: FAKRA Code I (M) Beige
RoHS & Reach Compliant
SPE-22-8-163-A
1.
Introduction
2
2.
Specification
3
3.
Antenna Characteristics
4
4.
Radiation Patterns
8
5.
Mechanical Drawing
18
6.
Packaging
19
Changelog
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the
right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to
this document and the information contained herein. Reproduction, use or disclosure to third parties without express
permission is strictly prohibited.
1
SPE-22-8-163-A
www.taoglas.com
1.
Introduction
The TFX257 is a first of its kind, transparent antenna designed to cover the entire spectrum of Wi-Fi bands.
The TFX257 has been expertly engineered by Taoglas with innovation in mind. The transparent flexible
antennas are an alternative to standard Flexible PCB antennas where the user may want to install an antenna
in a covert area or on a surface they may want to keep semi visible.
Typical Applications Include:
- Automotive and Commercial Transportation
- EV Charging and Parking Bays
- Digital Signage and Display screens
- Point Of Sale Kiosks
The TFX257 is connected via a FAKRA Code I male connector for ease of installation. If a custom connector is
required please contact your regional Taoglas customer support team.
2
SPE-22-8-163-A
www.taoglas.com
2.
Specification
Electrical
Band
Frequency
(MHz)
Average Gain
Peak Gain (dBi)
(dB)
Efficiency (%)
Wi-Fi 2
2400-2500
55.3
-2.58
4.59
Wi-Fi 5
5150-5850
41.6
-3.81
3.58
Wi-Fi 6
5925-7125
31.0
-5.09
2.04
Impedance
Polarization
Radiation
Pattern
Max. input
power
50 Ω
Linear
Omni
2W
Mechanical
Dimensions
32 x 114mm
Weight
5g
Material (Housing)
ABS/PC
Material (Antenna)
PET
Connector
Code I FAKRA (M) Beige
Environmental
Operation Temperature
-20°C to 85°C
Storage Temperature
-20°C to 85°C
Relative Humidity
Non-condensing TBD°C TBD% RH
3
SPE-22-8-163-A
www.taoglas.com
3.
3.1
Test Setup
4
SPE-22-8-163-A
www.taoglas.com
3.2
Return Loss
3.3
VSWR
5
SPE-22-8-163-A
www.taoglas.com
3.4
Efficiency
3.5
Average Gain
6
SPE-22-8-163-A
www.taoglas.com
3.6
Peak Gain
7
SPE-22-8-163-A
www.taoglas.com
4.
Radiation Patterns
4.1
Test Setup
8
SPE-22-8-163-A
www.taoglas.com
4.2
TFX257.A Patterns at 2400 MHz
XZ Plane
YZ Plane
XY Plane
9
SPE-22-8-163-A
www.taoglas.com
4.3
TFX257.A Patterns at 2450 MHz
XZ Plane
YZ Plane
XY Plane
10
SPE-22-8-163-A
www.taoglas.com
4.4
TFX257.A Patterns at 2500 MHz
XZ Plane
YZ Plane
XY Plane
11
SPE-22-8-163-A
www.taoglas.com
4.5
TFX257.A Patterns at 5150 MHz
XZ Plane
YZ Plane
XY Plane
12
SPE-22-8-163-A
www.taoglas.com
4.6
TFX257.A Patterns at 5500 MHz
XZ Plane
YZ Plane
XY Plane
13
SPE-22-8-163-A
www.taoglas.com
4.7
TFX257.A Patterns at 5850 MHz
XZ Plane
YZ Plane
XY Plane
14
SPE-22-8-163-A
www.taoglas.com
4.8
TFX257.A Patterns at 5925 MHz
XZ Plane
YZ Plane
XY Plane
15
SPE-22-8-163-A
www.taoglas.com
4.9
TFX257.A Patterns at 6525 MHz
XZ Plane
YZ Plane
XY Plane
16
SPE-22-8-163-A
www.taoglas.com
4.10
TFX257.A Patterns at 7125 MHz
XZ Plane
YZ Plane
XY Plane
17
SPE-22-8-163-A
www.taoglas.com
5.
Mechanical Drawing
18
SPE-22-8-163-A
www.taoglas.com
6.
Packaging
TBD
19
SPE-22-8-163-A
www.taoglas.com
Changelog for the datasheet
SPE-22-8-163 – TFX257.A
Revision: A (Original First Release)
Date:
Notes:
Author:
2022-10-14
Initial Release
Gary West
Previous Revisions
SPE-22-8-163-A
www.taoglas.com
21
SPE-22-8-163-A
www.taoglas.com
很抱歉,暂时无法提供与“TFX257.A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 3+188.90982
- 12+185.42761
- 24+181.86077
- 47+178.37856
- 100+174.89635
