TFX62.A
TFX62.A
    TAOGLASLIMITED
    825MHz,1.94GHz,2.595GHz HSPA,HSPA+,LTE,WCDMA 扁平插接线 RF 天线 690MHz ~ 960MHz,1.71GHz ~ 2.17GHz,2.5GHz ~ ...
TFX62.A 数据手册
[Model Name] Part No: TFX62.A Description TFX62.A - Cellular Transparent Antenna Features: LTE 690 to 960MHz/1710 to 2170MHz/ 2500 to 2690MHz Worldwide 4G Bands Efficiencies up to 60% Transparent Ultra Low Profile Dimensions: 110mm * 160mm Connector: FAKRA D (M) Violet RoHS & Reach Compliant SPE-22-8-162-A 1. Introduction 2 2. Specification 3 3. Antenna Characteristics 5 4. Radiation Patterns 9 5. Mechanical Drawing 19 6. Packaging 20 Changelog 21 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. 1 SPE-22-8-162-A www.taoglas.com 1. Introduction The TFX62 is a first of its kind, transparent antenna designed to cover worldwide 4G bands. The TFX62 has been expertly engineered by Taoglas with innovation in mind. The transparent flexible antennas are an alternative to standard Flexible PCB antennas where the user may want to install an antenna in a covert area or on a surface they may want to keep semi visible. Typical Applications Include: - Automotive and Commercial Transportation - EV Charging and Parking Bays - Digital Signage and Display screens - Point Of Sale Kiosks The TFX62 is connected via a FAKRA Code D male connector for ease of installation. If a custom connector is required please contact your regional Taoglas customer support team. 2 SPE-22-8-162-A www.taoglas.com 2. Specification Electrical Band B5,8,13,14,18,19,20,26, 27,28,29 B1,2,3,4,9,11,21,24,25, 32,34,35,36,37,39,45, 50,51,70 B7,38,53,69 Frequency (MHz) Average Gain Peak Gain (dBi) (dB) Efficiency (%) 690-960 31.0 -5.08 0.56 1710-2170 44.6 -3.50 2.36 2500-2690 60.2 -2.21 3.29 Impedance Polarization Radiation Pattern Max. input power 50 Ω Linear Omni 2W Mechanical Dimensions 110 x 160mm Weight 5g Material (Housing) ABS/PC Material (Antenna) PET Connector Code D FAKRA (M) Burgundy Environmental Operation Temperature -20°C to 85°C Storage Temperature -20°C to 85°C Relative Humidity Non-condensing TBD°C TBD% RH 3 SPE-22-8-162-A www.taoglas.com 5G/4G Bands Band Number B1 B2 B3 B4 B5 B7 B8 B9* B11 B12 B13 B14 B17 B18 B19 B20 B21 B22* B23* B24 B25 B26 B27* B28 B29 B30 B31 B32 B34 B35 B36 B37 B38 B39 B40 B41 B42 B43 B45 B46 B47 B48 B49 B50 B51 B52 B53 B65 B66 B68 B69 B70 B71 B72 B73 B74 B75 B76 B77 B78 B79 B85 B87 B88 5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA Uplink 1920 to 1980 1850 to 1910 1710 to 1785 1710 to 1755 824 to 849 2500 to 2570 880 to 915 1749.9 to 1784.9 1427.9 to 1447.9 699 to 716 777 to 787 788 to 798 704 to 716 815 to 830 830 to 845 832 to 862 1447.9 to 1462.9 3410 to 3490 2000 to 2020 1626.5 to 1660.5 1850 to 1915 814 to 849 807 to 824 703 to 748 Downlink 2110 to 2170 1930 to 1990 1805 to 1880 2110 to 2155 869 to 894 2620 to 2690 925 to 960 1844.9 to 1879.9 1475.9 to 1495.9 729 to 746 746 to 756 758 to 768 734 to 746 860 to 875 875 to 890 791 to 821 1495.9 to 1510.9 3510 to 3590 2180 to 2200 1525 to 1559 1930 to 1995 859 to 894 852 to 869 758 to 803 717 to 728 2305 to 2315 452.5 to 457.5 2350 to 2360 462.5 to 467.5 1452 to 1496 2010 to 2025 1850 to 1910 1930 to 1990 1910 to 1930 2570 to 2620 1880 to 1920 2300 to 2400 2496 to 2690 3400 to 3600 3600 to 3800 1447 to 1467 5150 to 5925 5855 to 5925 3550 to 3700 3550 to 3700 1432 to 1517 1427 to 1432 3300 to 3400 2483.5 to 2495 1920 to 2010 1710 to 1780 698 to 728 2110 to 2200 2110 to 2200 753 to 783 2570 to 2620 1695 to 1710 663 to 698 451 to 456 450 to 455 1427 to 1470 1995 to 2020 617 to 652 461 to 466 460 to 465 1475 to 1518 1432 to 1517 1427 to 1432 3300 to 4200 3300 to 3800 4400 to 5000 698 to 716 410 to 415 412 to 417 728 to 746 420 to 425 422 to 427 Covered ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓   ✓     ✓ ✓  ✓ ✓ ✓  ✓ ✓    ✓ ✓ ✓       4 SPE-22-8-162-A www.taoglas.com 3. 3.1 Antenna Characteristics Test Setup 5 SPE-22-8-162-A www.taoglas.com 3.2 Return Loss 3.3 VSWR 6 SPE-22-8-162-A www.taoglas.com 3.4 Efficiency 3.5 Average Gain 7 SPE-22-8-162-A www.taoglas.com 3.6 Peak Gain 8 SPE-22-8-162-A www.taoglas.com 4. 4.1 Radiation Patterns Test Setup 9 SPE-22-8-162-A www.taoglas.com 4.2 TFX62.A Patterns at 690 MHz XZ Plane YZ Plane XY Plane 10 SPE-22-8-162-A www.taoglas.com 4.3 TFX62.A Patterns at 825 MHz XZ Plane YZ Plane XY Plane 11 SPE-22-8-162-A www.taoglas.com 4.4 TFX62.A Patterns at 960 MHz XZ Plane YZ Plane XY Plane 12 SPE-22-8-162-A www.taoglas.com 4.5 TFX62.A Patterns at 1710 MHz XZ Plane YZ Plane XY Plane 13 SPE-22-8-162-A www.taoglas.com 4.6 TFX62.A Patterns at 1940 MHz XZ Plane YZ Plane XY Plane 14 SPE-22-8-162-A www.taoglas.com 4.7 TFX62.A Patterns at 2170 MHz XZ Plane YZ Plane XY Plane 15 SPE-22-8-162-A www.taoglas.com 4.8 TFX62.A Patterns at 2500 MHz XZ Plane YZ Plane XY Plane 16 SPE-22-8-162-A www.taoglas.com 4.9 TFX62.A Patterns at 2595 MHz XZ Plane YZ Plane XY Plane 17 SPE-22-8-162-A www.taoglas.com 4.10 TFX62.A Patterns at 2690 MHz XZ Plane YZ Plane XY Plane 18 SPE-22-8-162-A www.taoglas.com 5. Mechanical Drawing 19 SPE-22-8-162-A www.taoglas.com 6. Packaging TBD 20 SPE-22-8-162-A www.taoglas.com Changelog for the datasheet SPE-22-8-162 – TFX62.A Revision: A (Original First Release) Date: Notes: Author: 2022-10-14 First initial Release Gary West Previous Revisions 21 SPE-22-8-162-A www.taoglas.com 22 SPE-22-8-162-A www.taoglas.com
TFX62.A 价格&库存
很抱歉,暂时无法提供与“TFX62.A”相匹配的价格&库存,您可以联系我们找货
TFX62.A
  • 2+273.43802
  • 8+268.29934
  • 16+263.25740
  • 32+258.20336
  • 100+253.16141
库存:216
TFX62.A
    TFX62.A
    • 2+393.12994
    • 8+385.76347
    • 16+340.67828
    • 32+334.05444
    • 100+327.68215
    库存:100
    TFX62.A
    • 1+516.965141+66.86651
    • 10+425.9019010+55.08800
    • 25+403.1565925+52.14602
    • 100+378.16288100+48.91322
    库存:2
