1.625-36-134-10
1.625-36-134-10
    TAPECASE
    134-10 NATURAL ABRASION RESISTAN
1.625-36-134-10 数据手册
TapeCase Ltd. 1982 Lunt Ave, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Abrasion Resistant Fiberglass Tape Coated with Teflon PTFE 134-10 Product Description This product is a pressure sensitive tape produced from PTFE impregnated glass fabric that is coated with a “high temperature” silicone adhesive. The PTFE provides a smooth anti-stick surface while the glass fabric provides strength and dimensional stability. Application Information This tape is primarily used in mechanical applications such as heat sealing bars, conveyor belt coverings and gaskets/seals. Technical Properties Property Backing Material Backing Thickness (in) Adhesive System Adhesive Thickness (in) Adhesion (oz/in) Tensile Strength (lb/in) Elongation (%) Max Operating Temperature (F) Test Method ASTM-D-1000 ASTM-D-3759 ASTM-D-3759 Characteristic PTFE Glass Cloth 0.010 Silicone 0.002 45 225 5 500 NOTE: 1. When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers. 2. The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes 5/15/12
1.625-36-134-10
1. 物料型号:文档中没有明确提供物料型号。 2. 器件简介:该产品是一种由PTFE浸渍玻璃布制成的压敏胶带,涂有“高温”硅酮胶。PTFE提供光滑的防粘表面,而玻璃布提供强度和尺寸稳定性。 3. 引脚分配:文档中没有提及引脚分配,因为它描述的是一种胶带,不是电子元件。 4. 参数特性: - 基材材料:PTFE玻璃布 - 基材厚度:0.010英寸 - 胶粘系统:硅酮 - 胶粘厚度:0.002英寸 - 粘附力:45盎司/英寸(ASTM-D-1000) - 拉伸强度:225磅/英寸(ASTM-D-3759) - 伸长率:5%(ASTM-D-3759) - 最大工作温度:500°F 5. 功能详解:胶带主要用于机械应用,如热封条、传送带覆盖物和垫圈/密封件。 6. 应用信息:主要用于机械应用,例如热封条、传送带覆盖物和垫圈/密封件。 7. 封装信息:文档中没有提供封装信息,因为它不是电子元件。
1.625-36-134-10 价格&库存
很抱歉,暂时无法提供与“1.625-36-134-10”相匹配的价格&库存,您可以联系我们找货
