TapeCase Ltd.
1982 Lunt Ave, Elk Grove Village, IL 60007
phone: (847) 299-7880
fax: (847) 299-7804
www.tape case.com
sale s@t apeca se.com
Abrasion Resistant Fiberglass Tape Coated
with Teflon PTFE
134-10
Product Description
This product is a pressure sensitive tape produced from PTFE impregnated glass fabric that is
coated with a “high temperature” silicone adhesive. The PTFE provides a smooth anti-stick
surface while the glass fabric provides strength and dimensional stability.
Application Information
This tape is primarily used in mechanical applications such as heat sealing bars, conveyor belt
coverings and gaskets/seals.
Technical Properties
Property
Backing Material
Backing Thickness (in)
Adhesive System
Adhesive Thickness (in)
Adhesion (oz/in)
Tensile Strength (lb/in)
Elongation (%)
Max Operating Temperature (F)
Test Method
ASTM-D-1000
ASTM-D-3759
ASTM-D-3759
Characteristic
PTFE Glass Cloth
0.010
Silicone
0.002
45
225
5
500
NOTE:
1.
When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface
contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on
substrates containing plasticizers.
2.
The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes
5/15/12
很抱歉,暂时无法提供与“7-36-134-10”相匹配的价格&库存,您可以联系我们找货
