6-36-134-3
6-36-134-3
    TAPECASE
    134-3 NATURAL ABRASION RESISTANT
6-36-134-3 数据手册
TapeCase Ltd. 1982 Lunt Ave, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Abrasion Resistant Fiberglass Tape Coated with Teflon PTFE 134-3 Product Description This product is a pressure sensitive tape produced from PTFE impregnated glass fabric that is coated with a “high temperature” silicone adhesive. The PTFE provides a smooth anti-stick surface while the glass fabric provides strength and dimensional stability. Application Information This tape is primarily used in mechanical applications such as heat sealing bars, conveyor belt coverings and gaskets/seals. Technical Properties Property Backing Material Backing Thickness (in) Adhesive System Adhesive Thickness (in) Adhesion (oz/in) Tensile Strength (lb/in) Elongation (%) Max Operating Temperature (F) Test Method ASTM-D-1000 ASTM-D-3759 ASTM-D-3759 Characteristic PTFE Glass Cloth 0.003 Silicone 0.002 40 70 5 500 NOTE: 1. When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers. 2. The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes 5/15/12
6-36-134-3 价格&库存
很抱歉,暂时无法提供与“6-36-134-3”相匹配的价格&库存,您可以联系我们找货
    库存:100
